What did YOU do to your van today?
Page: Previous  1, 2, 3 ... 544, 545, 546 ... 628, 629, 630  Next
KiwiWesty84
KiwiWesty84 is offline
PostPosted: Fri Sep 11, 2020 11:54 pm    Post subject: Re: What did YOU do to your van today? Rats!! Reply with quote
So finally decided I had to remove the dash and open the heater box as no trick was removing the smell from the rat who snuck in while the van was parked up.
Pretty dirty inside even with the rats left overs. Shows why modern cars have the filters.
Also discovered one of the PO’s must have blindly tried to cut in a new stereo and in doing so cut open the heater!
Decided while it was open I might as well start with some sound deadening.
All because of a rat!
Take note of the lovely wiring I am also trying to fix. Many years ago was converted from LHD to RHD.
jlrftype7
jlrftype7 is offline
PostPosted: Sat Sep 12, 2020 10:10 am    Post subject: Re: What did YOU do to your van today? Rats!! Reply with quote
Don’t worry about new, modern vehicles escaping rats and mice. The pollen filters are new homes to all those rodents who ‘ roughed it ‘ with the old heater boxes. We see it all the time.
No matter how tight the intakes are on new HVAC systems, mice still get through.
Take your time, it’s a job, especially sorting out someone else’s wiring... Crying or Very sad
‘84 Tin Top - Hilga....Auto
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Mon Sep 14, 2020 12:48 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Grime on front rims got me started, and a slight sound when first starting a drive and braking, coming from up front. So, I got the wheels off and inspected the rotors and pads, plenty of pad left, and rotors seem thick enough. This is in prep for a ~1000 mile trip this week Wink -- includes Rocky Mountains!!
-bobby
PostPosted: Wed Sep 16, 2020 6:29 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Found 3/16" OD flexible tubing at the farm store. Strung it around the front doors inside the weatherstrip.
Major sound reduction, but perhaps the passenger door needs a bit thinner tube, as it takes a good bang to close now, and I have to push the door in to get the latch to open it from outside. (Like my fridge, I guess) I assume this will 'settle' in a few weeks and not take such a bang, etc. At least the inside door handle works as usual to get out.
Only problem I have now is that I can actually hear my other whistles from the wings or whatnot, and the RWM/Corkins exhaust sound is more pronounced. But, both Mrs. Black and I like the sound of the exhaust a lot so no big deal.
-bobby
andy52
andy52 is offline
PostPosted: Wed Sep 16, 2020 6:38 am    Post subject: Re: What did YOU do to your van today? Reply with quote
almost finished it on the exterior
before
after
before
after
before
after
4Gears4Tires
4Gears4Tires is offline
PostPosted: Wed Sep 16, 2020 8:57 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Sleek and spiffy looking!
'87 Syncro
Ferric Oxyhydroxide Superleggera Edition
andy52
andy52 is offline
PostPosted: Wed Sep 16, 2020 9:10 am    Post subject: Re: What did YOU do to your van today? Reply with quote
hahaha thanks
i wanted it to have a mean look.. but sharp at the same time!
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Wed Sep 16, 2020 1:15 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
@andy52
Nice color. What's it from?
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD
campism
campism is offline
PostPosted: Wed Sep 16, 2020 7:50 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
You got rid of the jail bars?
'87 Westy in Wolfram Grey Metallic
andy52
andy52 is offline
PostPosted: Thu Sep 17, 2020 1:10 am    Post subject: Re: What did YOU do to your van today? Reply with quote
big swifty wrote:
@andy52
its Nardo Grey, its an Audi Sport color very common in RS models
andy52
andy52 is offline
PostPosted: Thu Sep 17, 2020 1:11 am    Post subject: Re: What did YOU do to your van today? Reply with quote
I was supposed to put them back in their place but i lost some pieces so i'll have to buy some parts
is it that necessary?
campism
campism is offline
PostPosted: Thu Sep 17, 2020 4:22 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Not necessary but they are evidently a very desirable accessory.
Good color choice for the van!
randolph57
randolph57 is offline
PostPosted: Fri Sep 18, 2020 3:58 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Updated /changed my Kilometre speedometer to MPH.
I acquired a defective mph speedo a couple of years ago and as i retired yesterday it became my first (of many) van jobs to complete.
Many thanks to Syncroheads excellent write up on a proper fix for defective odometer by dimpling the metal gear and splining the shaft... thanks!
Kilometre reading transferred to miles elasped speedometer.
11BC2
11BC2 is offline
PostPosted: Sun Sep 20, 2020 7:39 am    Post subject: Re: What did YOU do to your van today? Reply with quote
One cool aspect of owning a previous Bundeswehr Doka is repainting it!
A quick rub down with a scotch brite pad and thinner, a few beers later ...VOILA!!!...finished.
KiwiWesty84
PostPosted: Sun Sep 20, 2020 12:22 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Figured I would get in and check out the rear heater area while doing maintenance. Guess the PO decided to remove the core! Fan works but not much point in that.
Now the decision of a new core, storage or subwoofer!
shadetreemech
shadetreemech is offline
PostPosted: Sun Sep 20, 2020 1:02 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Asked VanagonDwellers on Etsy to make me a stripe based on a design I found on an Ancestral Puebloan pottery sherd. I like their work, just couldn't see it on the Van. This morning I found the place:
Dan
'84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY"
Jake de Villiers
Jake de Villiers is offline
PostPosted: Mon Sep 21, 2020 7:07 am    Post subject: Re: What did YOU do to your van today? Reply with quote
That looks really good, Dan!
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
andy52
andy52 is offline
PostPosted: Mon Sep 21, 2020 8:35 am    Post subject: Re: What did YOU do to your van today? Reply with quote
cool!
andy52
andy52 is offline
PostPosted: Mon Sep 21, 2020 8:47 am    Post subject: Re: What did YOU do to your van today? Reply with quote
got the windows tinted
here in europe cant tint all of them but still looks ok
vino de vano
vino de vano is offline
PostPosted: Mon Sep 21, 2020 9:03 am    Post subject: Re: What did YOU do to your van today? Reply with quote
I think you have achieved the ultimate level of black out. Looks fabulous, but for gods sake never paint that aluminum rim, it's just the right amount of flash.
what a long strange trip it's been
Page 545 of 630
