legotech7 Samba Member
Joined: May 09, 2009 Posts: 879 Location: North Carolina
Posted: Sun Sep 06, 2020 2:02 pm Post subject: Gas tank filler sleeve,,... |
I have the gas tank filler neck located on the driver side of the hood. The filler neck sticks out quite a bit, but for the time being I would like to put a rubber sleeve to cover the hole, Just don't know where I might get it. Something similar to this perhaps?
Here's my buggy, hope you can see the hole...
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sun Sep 06, 2020 4:17 pm Post subject: Re: Gas tank filler sleeve,,... |
Do an internet search for "gas filler grommet" and take your pick. I see many listed with inner and outer diameters. Measure what you have and see what fits. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Mon Sep 07, 2020 8:58 am Post subject: Re: Gas tank filler sleeve,,... |
I'll have to take better measurements. Future improvements is to cut the neck down and add a filler door..I really don't like the neck sticking out so far.Thanks for info... |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Sep 07, 2020 10:58 am Post subject: Re: Gas tank filler sleeve,,... |
In that location if you shorten neck it will slosh out gas like mad.... Probably best thing to do is put filler near top of tank....
Posted: Mon Sep 07, 2020 11:35 am Post subject: Re: Gas tank filler sleeve,,... |
Dale M. Really?... But I've seen them in that location on many other buggy's. I need to know for sure before I start cutting thing up.... |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Mon Sep 07, 2020 11:38 am Post subject: Re: Gas tank filler sleeve,,... |
Ya, that's kind of butt ugly on such a nice clean Buggy! |
Posted: Mon Sep 07, 2020 4:09 pm Post subject: Re: Gas tank filler sleeve,,... |
legotech7 wrote: |
Just as soon as you pull out fuel nozzle, because top if tank is higher than top of filler, if not pretty damn close....
The old tape measure will tell....
Dael _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Mon Sep 07, 2020 5:22 pm Post subject: Re: Gas tank filler sleeve,,... |
Mmmm food for thought.. Thanks... |
gtrplyr Samba Member
Joined: November 10, 2014 Posts: 101 Location: kansas
Posted: Mon Sep 07, 2020 6:15 pm Post subject: Re: Gas tank filler sleeve,,... |
What Dale said, he knows. It's a lot of work to relocate a filler but you will be much happier. Just went through this myself. And mine ain't pretty!
Posted: Tue Sep 08, 2020 5:31 am Post subject: Re: Gas tank filler sleeve,,... |
gtrplyr, OK, when you cover that hole would you mind taking pics sand posting of how your doing it?. Its a mighty big hole to fix after its all said and done...This is all new to me.. Thanks... |
Posted: Tue Sep 08, 2020 5:33 am Post subject: Re: Gas tank filler sleeve,,... |
No doubt Dale seems the go to guy for all this information. Very much appreciated for sure.. |
Q-Dog Samba Member
Posted: Tue Sep 08, 2020 6:55 am Post subject: Re: Gas tank filler sleeve,,... |
With the hood off, just look at the tank and the angle it is mounted and you will understand why you can't shorten that filler when in the lower location.
I would sand and paint the filler neck and the gas cap, find a nice rubber grommet, and enjoy the car as is. _________________ Brian
'69 Dune Buggy
'70 Beetle |
Powaypete Samba Member
Joined: February 26, 2019 Posts: 71 Location: San Diego (Poway), CA
Posted: Tue Sep 08, 2020 6:59 am Post subject: Re: Gas tank filler sleeve,,... |
When you move the filler neck to the top (very highly recommended), fill in the old hole. If you can't match the paint color, it's a candidate for a racing stripe (it will make you go faster too). _________________ David
We're all here because we're not all there. |
Posted: Tue Sep 08, 2020 7:35 am Post subject: Re: Gas tank filler sleeve,,... |
Thanks guys. Like I said for the time being, I will use the rubber sleeve, and make it pretty until then. I ordered a sleeve for a 67 bus, witch I understand will work in the situation.. |
EVfun Samba Member
Posted: Tue Sep 08, 2020 8:39 am Post subject: Re: Gas tank filler sleeve,,... |
Dale M. wrote: |
Dale |
Doesn't the '61-'67 tank have a sealed gas cap and a separate vent line? If so, run the vent line up so it goes above and behind the tank, then back down the right side, and finally exiting below and forward of the tank on the right. That makes it roll over resistant and should keep the gas from making it out when braking and turning.
That is a very traditional location for the gas filler, using the stock gas tank. I would suggest a fitting grommet and perhaps a little paint and polish detail for it. Run it with pride. _________________
Wildthings wrote: |
Posted: Tue Sep 08, 2020 9:20 am Post subject: Re: Gas tank filler sleeve,,... |
legotech7 wrote: |
Thanks for the kudos, but I'm just another fish in the barrel trying to get something that has good appearance... I struggled for weeks on how to do the fuel filler thing....
It was around 2000 when the concept of high tank fillers and fuel doors came into concept, guess I was just with some of the first to accept concept.... Have not seem better concept since...
Posted: Fri Sep 18, 2020 12:12 pm Post subject: Re: Gas tank filler sleeve,,... |
Well I finally got the filler neck grommet for my tank. Kinda like the one I have pictured here at the top. Except its a lot more flat. Its from a 67 bus. It will cover the hole in the hood. It has a groove in the middle, and it is tight slipping it in around that . Does anyone have any tips as to how to slip that grommet in that hole. I was thinking perhaps some w-d40 and maybe a small screw driver and ride it along somehow. Thought I'd ask here first. Don't want to end up scratching up the hood try... Any ideas? Thanks ahead...
It looks exactly like this one, with the groove in the middle.
joescoolcustoms Samba Member
Posted: Fri Sep 18, 2020 12:40 pm Post subject: Re: Gas tank filler sleeve,,... |
legotech7 wrote: |
I use a paint stir stick sanded a little so it does not dig into the rubber. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Fri Sep 18, 2020 12:57 pm Post subject: Re: Gas tank filler sleeve,,... |
I'll try that, but its pretty tight... |
Posted: Sat Sep 19, 2020 5:36 am Post subject: Re: Gas tank filler sleeve,,... |
EVfun.thanks for the venting advise, I just might do that. |
