The Aufgeladen Ghia
Page: Previous  1, 2, 3 ... 43, 44, 45, 46  Next
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Sep 08, 2020 1:20 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
xzener wrote:
SHE'S ALIVE!!! And no exhaust leak when revving it. Very Happy
Cheers...here's to a nice little whine. Wink
John.
Inchpincher61
Inchpincher61 is offline
PostPosted: Tue Sep 08, 2020 12:36 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Indeed, sounds very clean!
I love the sound of the charger!!! This is sooo good!
xzener
xzener is offline
PostPosted: Tue Sep 08, 2020 3:57 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Thanks guys! Due to the California central valley heat (and smoke), unfortunately the Ghia is grounded. Have some side projects to do while I wait for cooler weather. In the midst of building my own hardline straightener. The fuel line I bought is one big coil, need to straighten it out so I can run it through the car for EFI. Using this video as reference...
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
xzener
xzener is offline
PostPosted: Thu Sep 10, 2020 4:58 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Been watching Hot VWs for almost a year now... The Aufgeladen Ghia made it into the magazine!! It was last year's Feed the Bug 10 event in Madera, CA. Was parked right next to a beautiful 1957 Ragtop Oval, which won Best of Show. My Ghia won Best in Class. It was a fun show, unfortunately this year has been cancelled of course.
djway3474
djway3474 is offline
PostPosted: Fri Sep 11, 2020 1:01 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
I built a 5 wheel tubing straightener and it works great, yours should be even faster. Price of tube goes way down buying coils Very Happy
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Sep 11, 2020 5:50 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
Umm... hard line is not that difficult to straighten or bend by hand. If you just want it straight, put the end on the floor, set a weight on it & unroll the coil.
Besides, not only is the path through the tunnel not straight, once installed, the line will never be seen.
didget69
didget69 is offline
PostPosted: Sat Sep 12, 2020 6:25 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Umm... Wrong, Boomer.
The cool Street racer kids will tell you that the hardline must be ABSOLUTELY straight so that flow is not restricted. You old guys don't know crap. Next thing you'll tell us is that VW sheetmetal repairs can be made with oil barrel metal... Wink
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
xzener
xzener is offline
PostPosted: Mon Sep 14, 2020 7:56 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
Finished my hardline straightener attachment for my vice. It works great! Now to get started on my fuel lines.
xzener
xzener is offline
PostPosted: Tue Sep 15, 2020 9:49 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
Well, with the layer of smoke over the California Central Valley... The temperature was cool enough to take the Ghia out for a spin yesterday. WOOWEE!!! Does this little 1500 get up and go! I have never driven a classic VW with more than 40hp... This feels closer to 80. So fun to drive. Had an issue where the idler pulley came loose but was riding on the alternator pulley. Had enough tension to get me home. Talked to Mick at Joeblow, he said to torque it to 50ft/lbs. Was only hand tightened as much as I could. I may be adjusting the suspension, needs more stability than the air ride can give. Might have to remove air ride all together. Wink With Accuair going out of business, this setup could raise a pretty penny. Will try to post a video on the Ghia cruising around town.
xzener
xzener is offline
PostPosted: Sun Sep 20, 2020 8:04 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Got some odds and ends done. Straightened the fuel lines. Need to get the Ghia on some jack stands so get get to work running them... Just having to much fun driving her. Very Happy
xzener
xzener is offline
PostPosted: Wed Sep 30, 2020 7:50 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Bought the DCOE 40 style ITB... Will bolt right on to the manifold, stacks and air cleaner will bolt on too.
[email protected]
norun99@hotmail.com is offline
PostPosted: Wed Sep 30, 2020 8:41 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
i wonder if the manifold could be flipped so the fuel rail is on the bottom. not sure if that would affect fuel flow. it would probably allow the deck lid to close with out the need for spacers.
didget69
didget69 is offline
PostPosted: Thu Oct 01, 2020 7:06 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
The fuel rail doesn't care if it's located top or bottom...
bnc
TDCTDI
TDCTDI is offline
PostPosted: Thu Oct 01, 2020 7:22 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
Realistically, a modern throttle body from a civic or Jetta bolted directly to the blower eliminate clearance issues. Injectors could be added to the manifold, just above the cylinder head. This would also eliminate fuel separation and pooling.
xzener
xzener is offline
PostPosted: Thu Oct 01, 2020 10:22 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
I plan on using what I have for now, and having fuel cooling the supercharger is a plus. Its been running GREAT as is... Why not simply replace a good working carburetor with an ITB? And with all the added sensors and ability to self tune... Why not?? If I find that this setup is not working as I would like, I will then go a different route.
xzener
xzener is offline
PostPosted: Thu Oct 01, 2020 12:13 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Found a picture in the gallery of how I plan to route the fuel lines. This member is using 3/8" feed, with a 1/4" return... (BTW, the jack stand/dolly combo looks dangerous, I don't recommend that at all)
xzener
xzener is offline
PostPosted: Sun Oct 04, 2020 9:01 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Wasted 3hrs of my life making an adapter for my CB Performance TPS sensor, just to find out it wasn't a CCW operating switch. Ugh... Not to self, check functionality of switches before making custom adapters.
The shaft is an 8mm "D" shape, which is different than the Weber DCOE shaft. Probably need to go to the local FLAP store and test what they have in stock.
xzener
xzener is offline
PostPosted: Mon Oct 05, 2020 10:35 am    Post subject: Re: The Aufgeladen Ghia Reply with quote
Did a bunch of research, and found a YouTube video of a BMW TPS replacement... Looks as though a BMW E36M43 TPS will work. Ordered. This one has the "D" shape so hopefully its a sure fit.
xzener
xzener is offline
PostPosted: Sat Oct 10, 2020 4:02 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Got the TPS issue sorted. Bought a BMW sensor. Just needed a bracket to work properly.
xzener
xzener is offline
PostPosted: Sun Oct 11, 2020 3:22 pm    Post subject: Re: The Aufgeladen Ghia Reply with quote
Running my fuel lines today. I chose to go underneath the passenger side. I ran air ride sensor wires on the driver's side.
I drilled through the brake line bracket running both feed and return lines.
Page 44 of 46
