Hardware sizes
Page: Previous  1, 2, 3, 4
myersmanxed
myersmanxed is offline
PostPosted: Fri May 05, 2017 2:14 pm    Post subject: Re: Hardware sizes Reply with quote
Where can I get M10-1.5x30 bolts with a 14mm head? These are used on the rear wheel oil seal holders on my buggy. Can't seem to find these anywhere. These are KAMAX 10K.
If anyone has some for sale, please let me know. Stupidly stripped the heads on mine.
Any help is greatly appreciated.
Bob Loblaw
Bob Loblaw is offline
PostPosted: Fri May 05, 2017 2:44 pm    Post subject: Re: Hardware sizes Reply with quote
Part# 311.501.325
A quick Google shows used ones for sale at Aircooled.net and Karmannghia.com
Or I can get brand new OE VW bolts out of the classic centre in Germany. About $5 ea.
sent from a phone using poor grammar and spelling
c21darrel
c21darrel is offline
PostPosted: Fri May 05, 2017 3:26 pm    Post subject: Re: Hardware sizes Reply with quote
My local Ace hardware has an amazing selection of Metric nuts/bolts
GhiaBuild
1967 DC build
avoll
avoll is offline
PostPosted: Sat Sep 02, 2017 2:26 am    Post subject: Engine Deck lid bolt Reply with quote
Anyone know what the bolt is that connects your deck lid to the bus? Its a 78 trasport bus.
Takes one bolt on the left side.
Thank you in advance.
HITE
HITE is offline
PostPosted: Thu Dec 21, 2017 4:52 am    Post subject: Re: Hardware sizes Reply with quote
Looking for the odd size screw that goes into the head for the air deflectors. (Underneath betweeen the push rods and head itself on 411 motor for bay window bus) Anyone know size for search?
Victordlt43
Victordlt43 is offline
PostPosted: Thu Feb 01, 2018 11:15 pm    Post subject: Re: Hardware sizes Reply with quote
Can anyone tell me what size is the front lower shock mount on a lower 64 or later trailing arm? I’m guessing 10mm but not sure of tread pitch
tandemtwins
tandemtwins is offline
PostPosted: Sat Mar 16, 2019 4:41 pm    Post subject: Re: Hardware sizes Reply with quote
The nut and/or bolt on my 73 Beetle's distributor clamp is stripped. Is there a standard nut and bolt size for a replacement, or do I just need to buy the whole clamp assembly?
Pruneman99
Pruneman99 is offline
PostPosted: Sat Mar 16, 2019 6:46 pm    Post subject: Re: Hardware sizes Reply with quote
The bolt is captured in the clamp so it won't spin when you tighten the nut. If never tried to remove one, but I'd imagine it would be difficult to do and ruin the clamp.
Grab a new clamp. They are pretty cheap. You can get a OG one from the classified here.
The clamp just needs to be snug, not torqued down tight enough to bend the crap out of it or strip the nut. I find so many bent up and I can't figure it out.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Mar 16, 2019 6:53 pm    Post subject: Re: Hardware sizes Reply with quote
The bolt is a M6, not sure of the length.
if you replace the clamp get a original German and not aftermarket. The aftermarket ones are soft and then tend to bend and alter the timing.
If you can't find one locally, PM me as I have a bunch of them.
Glenn
Member #1009
#BlueSquare
tandemtwins
PostPosted: Wed Mar 20, 2019 5:44 pm    Post subject: Re: Hardware sizes Reply with quote
Does the screw that holds the points in a 009 distributor have a name, or size designation, to where I might find a replacement in a local hardware store? (The groove on the head of the screw is starting to round... and I'd like to replace the screw with a new one before trouble strikes!)
ivwshane
ivwshane is offline
PostPosted: Thu Oct 31, 2019 7:34 pm    Post subject: Re: Hardware sizes Reply with quote
I've never been to this part of the forum but hopefully this info helps.
This applies to a 77 type IV engine but it could cover other type IV model years.
Sizes are either exact or the closest sizes currently available new. Most hardware can/was purchased from boltdepot, belmetric, and fastenal.
Nuts and bolts
Clutch pressure plate
- 8mmx18.5mm 1.25 @6 hex tap
Engine mount
- 8mmx20mm 1.25 @4 serrated flange (fastenal #11115901)
Plenum-case mount
- 8mmx83?mm 1.25 @2 hex tap
EGR
- 6mmx10mm 1.0 @2 pan head
EGR valve
- 6mmx16mm 1.0 @2 hex tap
EGR valve to plenum
- 6mmx55mm 1.0 @2 Allen head cap
Throttle body
- 6mmx25mm 1.0 @2 pan head
EGR/exhaust
- 8mmx30mm 1.25 @2 hex tap
Heat exchanger left
- 6mmx14mm 1.0 @1 serrated flange (fastenal # 11115895-16mm # 111115894-12mm)
Booster fan
- 6mmx15mm 1.0 @2 hex tap
Fan guard
Alternator bracket
- 8mmx18mm 1.25 @2 hex tap
Fan housing
- 6mmx20mm 1.25 @8 pan Phillips
- 8mmx16mm 1.25 @1 hex tap
- 8mmx45mm 1.25 @2 hex tap
- 8mmx45mm 1.25 @1 hex
- 8mmx30mm 1.25 @3 hex tap
Starter bolt
- 10mmx70mm 1.5 @1 hex
Exhaust EGR side
- 8mmx20mm 1.25 @1 hex
Engine carrier bolts
- 8mmx65mm 1.25 @4 hex
Bumper
- 10mmx25mm 1.5 @4 hex tap
Fan hub
- 8mmx30mm 1.25 @1 serrated flange
Transmission (fastenal # 11115903)
- 10mmx75mm 1.5 @1 hex
Transmission mount
- 10mmx45mm 1.5 @2 hex
CV bolts
- 8mmx48mm 12 point
Cooling tin
- 6mmx12mm 1.0 @1 hex tap (fastenal # 0128747)
Cylinder cooling tin
- 5mmx12mm 1.0 @2 hex tap (fastenal # 1138543)
Oil temp plate
- 6mmx10mm 1.0 @2 hex tap (fastenal # 11113804)
Valve lifters
- 7mm nut @8 (fastenal # 0161929)
- 6mm square nut @4 (fastenal # 0161910)
Thermostat
- 8mmx10mm 1.25 @1 hex tap (fastenal # 11552374)
Engine case top
- 8mmx88mm 1.25 @1 hex
- 8mmx93mm 1.25 @1 hex
Alternator tin
- 6mmx30mm 1.0 @1 hex tap (fastenal # 0153965)
Control flaps cable holder
- 4mmx8mm @1 hex tap (fastenal # 0162373)
- 4mm square nut
Fan housing cooling flaps (non stock item and a mod to keep flaps from falling off)
- 1/8" spring e-clips x4 (fastenal # 0401249)
Stud length for cross over pipe
28.5mmx8mmx1.25
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
LAGrunthaner
LAGrunthaner is offline
PostPosted: Mon Nov 04, 2019 6:47 am    Post subject: Re: Hardware sizes Reply with quote
I don't have a type IV engine, but I love bolts and thread sizes. Totally awesome!! I grew up in an old hardware store and sorted thousands of nuts, bolts and screws as the owner would have his helpers dump them in trash cans when they bought out a store. It would take me a full year to sort but a lifetime of education. Unfortunately the majority were US sizes still I loved it.
Nuts and bolts
Engine mount
Plenum-case mount
EGR
EGR valve
EGR valve to plenum
Throttle body
EGR/exhaust
Heat exchanger left
Booster fan
Fan guard
Alternator bracket
Fan housing
Starter bolt
Exhaust EGR side
Bumper
Fan hub
Transmission mount
CV bolts
- 8mmx48mm 12 point
Cooling tin
Oil temp plate
Valve lifters
Thermostat
Engine case top
Alternator tin
- 4mm square nut
28.5mmx8mmx1.25
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
papichuito
papichuito is offline
PostPosted: Fri Nov 22, 2019 4:38 am    Post subject: Re: Hardware sizes Reply with quote
What about the bigger bolts and nuts? Like the flywheel, axle castle nuts, spindles, etc,,,,,,,,,,,, I cat find that anyware.
Jesus Roman
joem32380
joem32380 is offline
PostPosted: Wed Jan 15, 2020 3:08 pm    Post subject: Re: Hardware sizes Reply with quote
58-66 beetle
pedal to tunnel bolts: M10x30 1.50 pitch
wagohn
wagohn is offline
PostPosted: Sun Oct 04, 2020 10:09 am    Post subject: Re: Hardware sizes Reply with quote
Anyone know the size of the bolt that bolts the exhaust bracket to the left side of the engine, under a 76 VW Transporter?
We had a super annoying engine rattle at 1500 rpm every time we changed gear. Turns out this missing bolt allowed the bracket to vibrate against the engine.
Thanks!
1976 VW Transporter, 2.0 FI Engine
Flat4BRM
Flat4BRM is offline
PostPosted: Sun Jan 23, 2022 5:25 pm    Post subject: Reply with quote
roy63 wrote:
here is a question, what is the thread and pitch on the heater control knob on a 63 sedan? mine was damaged by my blaster. I have been unable to find much on this topic.
I'd like to have this info as well. I've got a new control knob assembly and everything works great, but the new knurled cap nut barely goes down halfway (tried the old one and it's the same story). I'd like to chase the threads to clean everything up. This info would be greatly appreciated.
- Most car projects are like stray dogs..you want to keep them all and never let any of them go.
- Built, not bought.
- Street is neat...support your local street rodders!
1966 L41 113 | 1965 L456 151 | 1963 L380 113 | 1954 L227 113 | 1949 L51 11A
Flat4BRM
Flat4BRM is offline
PostPosted: Thu Jan 27, 2022 6:18 pm    Post subject: Re: Hardware sizes Reply with quote
UPDATE:
So I found out the size of said heater control knurled nut:
M20 x 1.0
Hope this helps.
scubasteve321
scubasteve321 is offline
PostPosted: Sat May 28, 2022 11:03 am    Post subject: Re: Hardware sizes Reply with quote
Anyone know the screw size to attach the regulator to the bus body? lost mine aggghhh
Early bay 71
edit; ended up using number 8 by 1/2 inch sheet metal screws, they bit pretty good once tightened down
1971 Campmobile Tin-Top
1971 Campmobile Pop-Top
1974 VW Bus
aa390392
aa390392 is offline
PostPosted: Thu Jun 16, 2022 9:23 am    Post subject: Re: Hardware sizes Reply with quote
Anyone know of the size that fasten the glovebox on an Oval?
Thanks
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
Scorpio101
Scorpio101 is offline
PostPosted: Sat Dec 02, 2023 11:39 am    Post subject: Re: Hardware sizes Reply with quote
Hi
I have 1981 VW Rabbit pickup which I'll convert from fuel injection to carb I I have the mainfold for weber should I buy Carburetor IDF 40 / 36/32 ?
Page 4 of 4
