Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 186 Location: Englewood, New Jersey
Posted: Thu Oct 01, 2020 2:28 pm Post subject: Engine crank handle storage |
I searched but did not find where the crank handle used for manual starting is stored. Looking at kubelwagens it is on the inside of the engine cover, but mounts which way? I know there are some original military 181 around, anyone have a picture? I have a regular '74 181, but came across the handle and drilled an access hole in the tin for it and have the clips that hold it, just which way to mount. Any help is much appreciated. _________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Thu Oct 01, 2020 3:19 pm Post subject: Re: Engine crank handle storage |
Here you go.
Posted: Thu Oct 01, 2020 3:28 pm Post subject: Re: Engine crank handle storage |
Thank you Al...ask and you shall receive. I love the samba. _________________ 74 Thing 1600DP
Semper_Dad Samba Member
Posted: Fri Oct 02, 2020 6:17 am Post subject: Re: Engine crank handle storage |
Thanks Semper...I have a Tamiya Kubelwagen model and that's where they store it. I like the hidden way better, it's no show car. _________________ 74 Thing 1600DP
Posted: Sat Oct 10, 2020 11:28 am Post subject: Re: Engine crank handle storage |
I am not into show cars and being cool at all, and would worry about a handle stored in the engine compartment coming loose and causing major damage to the engine.
My first Thing had the special pulley bolt for the hand crank and the crank itself. The handle stayed stored in the front boot together with the tire changing stuff. |
Posted: Sat Oct 10, 2020 5:29 pm Post subject: Re: Engine crank handle storage |
The clamps that came with the handle did not hold it tight enough and it did not have the fancy clamp on the right.
I stuck behind the jack in the front.
I installed the special pulley bolt for the handle. _________________ 74 Thing 1600DP
