ripperfarms Samba Member
Joined: July 14, 2019 Posts: 40 Location: Central Illinois
Posted: Sun Oct 18, 2020 7:16 pm Post subject: 63 turn signal switch turning on steering column |
I have a 63 sedan and the turn signal switch is turning on the steering column.
I tried to find some youtube videos on how to fix that but to no avail.
It is in the shop right now for some new spring plates but when I get it back I want to fix the turn signals.
They will work but the whole turn signal column (housing) and the lever slip around the steering column, maybe a 1/8 turn, before turning the signal on.
Is there some clamp inside of there or what should keep it from sliding around the steering column.
Thanks for any help ahead of time....Dave in Illinois....the land of no old VWs. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sun Oct 18, 2020 7:37 pm Post subject: Re: 63 turn signal switch turning on steering column |
There should be a slotted screw that tightens and holds the assembly in place. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Sun Oct 18, 2020 8:17 pm Post subject: Re: 63 turn signal switch turning on steering column |
Once you confirm the screw:
1) Check for center on the steering box:
2) Then check for centering of the steering wheel on the column. If you skip this you can break things.
3) Set the gap between theswitch and steering wheel:
mukluk Samba Member
Posted: Sun Oct 18, 2020 8:23 pm Post subject: Re: 63 turn signal switch turning on steering column |
The screw is located as shown below, it threads into a clamping plate which is forced against the column tube to hold the switch assembly in place.
_________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Oct 19, 2020 6:27 am Post subject: Re: 63 turn signal switch turning on steering column |
I think this answer will work for me ...... as soon as I get the bug back I will fix it.
I felt around there before but did not feel it so this time I will look closer.
Thanks to everyone for their help
mukluk wrote: |
