74GreenBug Samba Member
Joined: December 31, 2018 Posts: 6 Location: Tennessee
Posted: Mon Oct 19, 2020 11:23 am Post subject: Longblock |
Alas the old 74 engine finally gave up the ghost. Im looking to replace the longblock assembly, any recommendations on where to buy? |
Zundfolge1432 Samba Member
Posted: Mon Oct 19, 2020 12:35 pm Post subject: Re: Longblock |
Why not rebuild it yourself? |
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Mon Oct 19, 2020 12:56 pm Post subject: Re: Longblock |
What part of the longblock broke? Is the whole lower end just clapped out? If it has good compression & end play it might not need to be completely replaced. Just remove & refresh! |
Posted: Mon Oct 19, 2020 1:05 pm Post subject: Re: Longblock |
I read your first two threads did you follow up on either? Back to long block you can go cheap and buy something off craigslist or go with a known builder. But actually there’s plenty of people building engines at home that are just as nice but cost less because they don’t have the overhead of running a business. I’d contact one of the VW clubs in Tennessee and ask around probably many choices close to home.
https://memphis.craigslist.org/pts/d/memphis-vw-beetle-bug-bus/7183803124.html |
Posted: Mon Oct 19, 2020 10:10 pm Post subject: Re: Longblock |
The heads are shot, the case is cracked, and one of the pistons is broken. Basically the engine just decided to crap out hard and fast. Much like many of the Subarus I see lol. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
JDMbeetle Samba Member
Cusser Samba Member
Posted: Tue Oct 20, 2020 7:06 pm Post subject: Re: Longblock |
For reference, when I rebuilt my own 1600cc DP engine in 2016-2017, I spent $1500.
Local machining of case and heads was $640 which included them supplying the bearings. I bought new Moresa pistons and cylinders, and a Maxi2 oil pump/filter. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Oct 20, 2020 7:14 pm Post subject: Re: Longblock |
Cusser wrote: |
Local machining of case and heads was $640 which included them supplying the bearings. I bought new Moresa pistons and cylinders, and a Maxi2 oil pump/filter. |
This I’ll always endorse and it turned out well he drives It still. I’ve built a couple myself it ain’t hard. The second cheapest way out network with local VW people, join a club. People that live in apartments have done this on kitchen table.
Even this old car was made good again 😀 |
