Replacing ignition control module
Nickel_Nackel
Nickel_Nackel is offline
PostPosted: Sun Oct 25, 2020 1:53 pm    Post subject: Replacing ignition control module Reply with quote
Do I just slap this puppy on my van like this and call it good?
I guess I need to cut in more screw holes cus this doesn’t line up with the old ones
1985 1.9L Potato
MarkWard
MarkWard is offline
PostPosted: Sun Oct 25, 2020 2:25 pm    Post subject: Re: Replacing ignition control module Reply with quote
I would try it before you mount it. The original is a 2 part with an aluminum heat sink that is attached to the van and the module bolts to the heat sink.
If it works see if you can use one of the original holes.
1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q
Nickel_Nackel
Also is running my van at 25 degrees 2” from the U mark okay for it?
1985 1.9L Potato
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Oct 25, 2020 3:23 pm    Post subject: Re: Replacing ignition control module Reply with quote
Can you reuse your original heatsink in addition to the components you show in the photo? Yeah, that would give you two heat sinks but might allow the original holes to be used.
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Oct 25, 2020 3:26 pm    Post subject: Re: Replacing ignition control module Reply with quote
I think 2" is more than 25° -- perhaps about 35°.
But yeah, should be okay - I actually run a little more advance than that.
DanHoug
DanHoug is offline
PostPosted: Sun Oct 25, 2020 3:50 pm    Post subject: Re: Replacing ignition control module Reply with quote
so in the vintage BMW airhead world, they use the same ignition module. there have been numerous instances where these have had intermittent failures due to a lack of heat sink grease between the module and heat sink. it'll probably work just fine, but if you want a belt and suspenders approach, separate the two and apply some heat sink compound. it has made a difference in the BMW motorcycle world.
-dan
87 Westy, 2.1 w/ 4 spd ratty but reliable.
89 Westy, gorgeous, stock 2.1 w/ 4 spd.
