VanagonRocco Samba Member
Joined: October 14, 2020 Posts: 18 Location: Los Angeles, CA
Posted: Tue Oct 27, 2020 1:28 pm Post subject: Question About Driver's Seat Battery Compartment |
I'm looking at auxiliary battery solutions, and one idea I had is to put a battery and an inverter inside the driver's side battery compartment, and also cut two holes, so I can have an AC plug outlet poke out in a convenient location (see photo).
Here's my question:
Is it possible to cut a hole in the part labeled (1) in the photo, and slip in an inverter into that space, so the AC plug outlet sticks out of hole (2)? What's behind there? Is it empty or full of things that really shouldn't be messed with? THANKS!
It's a 1985 1.9 GL if that helps..
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17115 Location: Retired South Florida
Posted: Tue Oct 27, 2020 1:44 pm Post subject: Re: Question About Driver's Seat Battery Compartment |
Where you want to insert the inverter appears to be the inner fender well. There is also an expansion tank in that fender area. Best to get a flashlight and have a look. Sorry if I misunderstood. _________________ ☮️ |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Wed Oct 28, 2020 4:40 am Post subject: Re: Question About Driver's Seat Battery Compartment |
You can cut through the back of that battery box (into the cabin) but not the side as one of the fuel tank expansion tank is on the other side of that wall. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
