Spare tire mounting bracket
Page: Previous  1, 2
PostPosted: Tue Dec 04, 2012 9:40 pm    Post subject: Reply with quote
Keep an eye on the classifieds.
There was a complete set posted just a couple days ago and I've had an ad for just the brackets running for a while:
http://www.thesamba.com/vw/classifieds/detail.php?id=1282936
kombisutra
kombisutra is offline
PostPosted: Tue Dec 04, 2012 10:03 pm    Post subject: Reply with quote
Wow, I never knew they made those for 15s also! Trippy!
tumisoft
tumisoft is offline
PostPosted: Wed Jul 08, 2015 10:05 am    Post subject: Reply with quote
Hi,
Does anyone has the exact measurements of the bracket in the first picture in the first post of this topic?
It is missing in my bus and I would like to make one myself.
Thanks
Stefan
Clara Premium Member
Clara is offline
PostPosted: Wed Jul 08, 2015 2:43 pm    Post subject: Reply with quote
tumisoft wrote:
Hi,
Thanks
Stefan
I see three in the classifieds right now:
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
tumisoft
tumisoft is offline
PostPosted: Wed Jul 08, 2015 10:40 pm    Post subject: Reply with quote
Hi Clara,
Thanks, I saw them too but I live in Belgium and I can't seem to find one here.
Stefan
Brian_1952
Brian_1952 is offline
PostPosted: Thu Jul 09, 2015 1:17 am    Post subject: Re: Spare tire mounting bracket Reply with quote
AlteWagen wrote:
I finally have a spare tire that will fit in the well behind the front seat. Now I can use the original wing nut and bracket that were in the bus when I got it. Unfortunately I dont know how the bracket is supposed to hold down the tire.
Anyone got any pics or advice?
Thanks
Moderator notes, here is a summary:
A stud was added sometime in the 1962 model year to hold the spare tire in
Thanks for this knowledge I have one of each I was wondering why there was a difference
place behind the front seat.
A wing nut and bracket were used on the stud to fasten the wheel in place.
To the best of my knowledge, the shorter bracket was used for 15" wheels and the taller bracket for 14" wheels.
Thanks for this knowledge I have one of each one is wondering why there was a difference
Photos:
Thanks for this knowledge I have one of each and was wondering why there was a difference
(20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal
mandraks
mandraks is offline
PostPosted: Thu Jul 09, 2015 7:56 am    Post subject: Re: Spare tire mounting bracket Reply with quote
Thanks
the 15 inch wheel and tire is narrower, that is why the 15 inch bracket is narrower. Once the 14inch wheel came, the bracket needed to be wider. I also saw that the mounting hole is oval, possibly to accommodate both size wheels? the diameter is not the same between 6.40 15 and 7.00 14
regards
Uli
tumisoft
tumisoft is offline
PostPosted: Thu Jul 09, 2015 11:17 am    Post subject: Reply with quote
And the measurements of the narrow one (for 15" wheel) , anyone ?
easy e
easy e is offline
PostPosted: Wed Jun 22, 2016 3:36 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
Old... but, oh well...
Short one (15") has a 0.5" gap, will get other measurements in a few hours.
Tall one (14") has a 0.75" gap, don't have this one to measure.
aka: Evan
easy e
easy e is offline
PostPosted: Wed Jun 22, 2016 9:03 pm    Post subject: Re: Spare tire mounting bracket clamp Reply with quote
Here's for 15" wheel bracket...
Holes are on the same axis... just not sketched that way.
The R = 18 dimension changes from corner to corner (not consistent)... & is larger than the other corners.
aka: Evan
PostPosted: Wed Jun 22, 2016 10:19 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
Cool. What is T?
easy e
easy e is offline
PostPosted: Wed Jun 22, 2016 10:38 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
T = material thickness
3.6mm = 0.1417"
Closest standard sheet metal thickness is 10 ga @ 0.1345" (9 gauge @ 0.1495")
Steel bar stock standard thicknesses... 1/8" = 0.125" & 3/16" = 0.1875"
aka: Evan
easy e
easy e is offline
PostPosted: Thu Jun 23, 2016 8:31 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
regurgitating a little for clarity...
From post #1
A stud was added sometime in the 1962 model year to hold the spare tire in place behind the front seat.
The 15" bracket gap is 0.5"
The 14" bracket gap is 0.75"
And from the 14", 15", 16" wheel FAQ thread...
On December 19, 1963, chassis # 1222026 (August 5, 1963, chassis # 1145427 for 1 ton models), VW went to a 14" wheel, size 14x5.00
So, the narrow gap bracket was fairly short lived... about two years.
Is that right?... or did pre-'62 bench seat buses use the bracket... but just didn't have the supplied stud (loose bolt)?
Or, did the pre-'62 use something different to secure the spare?... or was it just loose in the spare tire area?
aka: Evan
PostPosted: Thu Jun 23, 2016 8:38 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
My '61 spare is loose in the spare tire well with no stud there or any sort of bracket.
lightice
lightice is offline
PostPosted: Mon Jul 03, 2017 5:50 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
Does anyone have dimensions for the 14" wheels?
Metal thickness and the height (both side) and width.
depth would be 3/4" gap + metal thickness x2.
Difficult to find one and would try to fabricate one from sheet metal.
aircool911
aircool911 is offline
PostPosted: Wed Nov 11, 2020 9:11 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
Not to beat a dead horse but that foto posted from the owners manual is pretty dark. I have a 67 Doublecab .Does anyone have a pic of how the spare fits with the bracket? It’s not clear how the bracket goes. Does the wheel sit on top of the bracket? Does the long side of the bracket face out? Short side in? What does the short side do, hold the wheel? Pictures would be helpful, thanks much.
PostPosted: Wed Nov 11, 2020 10:27 pm    Post subject: Re: Spare tire mounting bracket Reply with quote
From earlier in this thread
Dave24 wrote:
Long side nearest wingnut, place the spare in the well, and the "bracket" just goes over the edge of the rim and tighten w/nut to hold. It doesn't go through a lug hole.
Pic I found
Page: Previous  1, 2
Page 2 of 2
