input shaft center divot-- use case?
charleslabri
charleslabri is offline
PostPosted: Sat Nov 14, 2020 11:24 am    Post subject: input shaft center divot-- use case? Reply with quote
Anyone have a good idea why the center divot is there in the input/main/etc shaft coming out of the trans?
The outer chamfor makes sense- so it guides it into the pilot bearing.
But why this center carve out?
An example of my labor in action:
https://www.instagram.com/wileythewesty/
My Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=730525&highlight=
MarkWard
MarkWard is offline
PostPosted: Sat Nov 14, 2020 11:28 am    Post subject: Re: input shaft center divot-- use case? Reply with quote
So it could be chucked up in a lathe. Normal and not required if you are considering cutting it back.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Nov 14, 2020 12:32 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
It might also be a recess for a reserve of grease to keep the pilot bearing lubed over time.
Casey--
'01 Weekender --> full camper
y u rune klassik?
charleslabri
PostPosted: Sat Nov 14, 2020 12:44 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
Thanks for the insight. Y’all are great
My Build Thread:
MarkWard
MarkWard is offline
PostPosted: Sat Nov 14, 2020 12:55 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
I hope this advice was tongue and cheek. Don't pack a bunch of grease in there. Grease shouldn't be flowing. If it did, centrifugal force would throw it on the clutch disc.
Howesight
Howesight is offline
PostPosted: Sat Nov 14, 2020 1:12 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
Zeitgeist, shame on you for that fake news! That space is NOT intended to hold grease.
Originally, the centre was carved out to give Vanagon owners a place to hide their weed. VW realized that with the Splitty and Bay vans, there was no secure place to hide your weed, so they ensured the Vanagon generation would not suffer this ignominy. Now that increasingly liberal laws on weed are popping up in many states, that space has been re-designated as a place to hide your ecstasy, although you will only find this information in the darkest corners of the interwebs.
https://www.youtube.com/watch?v=eFktbuhAyLM
'86 Syncro Westy SVX
Zeitgeist 13
PostPosted: Sat Nov 14, 2020 1:18 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
I was trained to pack the pilot bearing with Bosch distributor grease, and to fill the divot with the same. I'm not talking about filling that entire crank cavity, 'cause that would be a recipe for hot spots on the wear surfaces.
Casey--
y u rune klassik?
Vanagon Nut
Vanagon Nut is offline
PostPosted: Sat Nov 14, 2020 1:24 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
My vote is also for lathe work. Morse taper part at tail piece?
edit: both my ABA swaps with cut input shaft, no divot at end, work fine.
I added a little extra grease (IIRC a "sticky" synthetic grease) at the new pilot bearing on my first ABA swap and possibly too much Moly at input shaft splines. I'm not certain but I think it was Moly from input shaft splines that ended up on my FW. Regardless, in hindsight, (edit: in my less than educated opinion) I should not have added grease to the new "sealed" type pilot bearing.
Neil.
15º ABA FW, early days. Looks like excess Moly from input shaft splines. Clutch still worked fine though and little wear was seen at disc after some years use.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
charleslabri
PostPosted: Sat Nov 14, 2020 3:58 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
I ended up doing a very gentle cutting wheel method and adding a slight campher.
The original campher was 5mm deep, i went about 3.5mm. After these pics i polished it with 400-600 grit sandpaper
Sounds like this divot in question is non-essential
My Build Thread:
MarkWard
MarkWard is offline
PostPosted: Sat Nov 14, 2020 4:04 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
Do yourself a favor and bolt the transmission to the engine with no clutch. Select a gear and turn the engine through. Make sure the cv flange does not turn. You can also leave your string to see how deep the shaft engages the pilot bearing.
revolution337
revolution337 is offline
PostPosted: Sat Nov 14, 2020 6:17 pm    Post subject: Re: input shaft center divot-- use case? Reply with quote
I did exactly this. Although I used an o-ring instead of string to help determine the depth of the insertion into the pilot bearing. A was able to get a pretty clear shot of the whole package through the starter hole. I had a friend spin the engine over by hand while watching the trans input shaft. I could easily verify that the crankshaft was turning and the input shaft was not, indicating no binding.
