Heat Risers...
legotech7
legotech7 is offline
PostPosted: Sat Nov 21, 2020 11:59 am    Post subject: Heat Risers... Reply with quote
Decided to get a new progressive carb kit, to replace the one I have. Its shot. My question is my buggy's set up doesn't have the heat risers, though it was running fine, till the fuel pump crapped out on me. I will be replacing that as well with an electric pump. Will I need the heat risers with the new kit I ordered? I've seen a few buggy's wit out them. Any input on this would be greatly appreciated... thanks..
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Nov 21, 2020 3:17 pm    Post subject: Re: Heat Risers... Reply with quote
if you drive in cool/cold weather you'll need them.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
jspbtown
jspbtown is offline
PostPosted: Sun Nov 22, 2020 7:17 am    Post subject: Re: Heat Risers... Reply with quote
Can I ask why you decided to go with a progressive set up with electric fuel pump?
Your fuel pump should be wired into some sort of safety switch (oil sender?) to make it safe.
legotech7
PostPosted: Sun Nov 22, 2020 7:27 am    Post subject: Re: Heat Risers... Reply with quote
jspbtown
I went with the progressive kit, my engine ran so well with it , even with out the heat risers. But I decided to go with them anyway as suggested. The electric fuel I think fare better with these set ups, As well ass ease of replacement if ti ever goes south. Had them before in other bugs and never had issues with them. My last one ran for 10 years. No issues. The new mechanical pump are just garbage. They may last a year at best and to replace them with a weber progressive kit is a PITA......Electric pump/... easy peasy....And yes I will have an over ride switch for it... Thanks for the input...
Q-Dog
Q-Dog is offline
PostPosted: Sun Nov 22, 2020 9:05 am    Post subject: Re: Heat Risers... Reply with quote
I like to keep it simple. My original VW fuel pump is over 50 years old. Every few years it gets a cleaning and a rebuild.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Mr. 010
Glenn is offline
PostPosted: Sun Nov 22, 2020 9:08 am    Post subject: Re: Heat Risers... Reply with quote
Why?
My fuel pump is over 20 years old and works just fine.
Glenn
legotech7
PostPosted: Sun Nov 22, 2020 10:07 am    Post subject: Re: Heat Risers... Reply with quote
Q-Dog Thats a good pump, you can rebuild, but hard to find. These new pumps coming from Brazil are garbage. Had to change quite a few in too short of periods of time. Going electric...
Q-Dog
Q-Dog is offline
PostPosted: Sun Nov 22, 2020 10:33 am    Post subject: Re: Heat Risers... Reply with quote
Last time I rebuilt the pump I am using in my buggy was 8 years ago. About 30,000 miles so far.
Brian
'69 Dune Buggy
'70 Beetle
legotech7
PostPosted: Sun Nov 22, 2020 12:57 pm    Post subject: Re: Heat Risers... Reply with quote
Well had some time this afternoon. Took out the engine, Easy on a buggy, took me a bit since I have a bad case of CRS. I tagged everything for ease of replacement. Now to go over it and see what else I need. This engine had no signs of oil leakage anywhere. Dry as a bone, but would you all recommend I change the seals in the oil cooler? I might apt to change the clutch and pressure plate as well. Am I missing anything? I will replace the exhaust gaskets, they look pretty rusty from setting around so long. Should I use a relay for the electric fuel pump? I'll post as I go along, any other recommendations would be appreciated... Thanks..
jspbtown
jspbtown is offline
PostPosted: Sun Nov 22, 2020 5:43 pm    Post subject: Re: Heat Risers... Reply with quote
Front seal. Yes on the oil cooler seals. Be sure to get the right pressure electric pump (or regulator) and yes on the relay.
legotech7
PostPosted: Mon Nov 23, 2020 9:05 am    Post subject: Re: Heat Risers... Reply with quote
Thanks. Noted on all....
andygere
andygere is offline
PostPosted: Mon Nov 23, 2020 2:41 pm    Post subject: Re: Heat Risers... Reply with quote
The stock rebuildable Pierburg fuel pumps are sold by a few vendors as rebuilt units, and the rebuild kits are available from Wolfsburg West if you can get your hands on a used one. I was able to find a NOS unit when I had my 2165 built last year. I wanted a stock mechanical pump for simplicity and reliability, and the Pierburg fit the bill in terms of working well with my dual Webber linkage and relocated coil. For those interested, here are a few of the vendors that list them.
https://www.classiccult.com/vw-pierburg-fuel-pump-1958-67.html
http://www.vintagewerks.com/Fuel%20Pumps/fp_4sale.html#1300pierburgfuelpump
EVfun
EVfun is offline
PostPosted: Mon Nov 23, 2020 9:52 pm    Post subject: Re: Heat Risers... Reply with quote
You have no leaks... why would you replace any seals?
Wildthings wrote:
