bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Wed Nov 25, 2020 8:57 am Post subject: Bocar 34PICT3 question |
I am rebuilding a Bocar 34PICT3 for a friend to use on his 71Bus. This is the second Bocar 34PICT3 I've rebuilt.
As I compared the stock jet sizes for a 71bus to what's on the carb, I noticed that the Pilot Air bleed drilling is about 125 while the stock size for all VWs using 34PICT3s from 71-74 is 147.5.
If none of the VWs use 125, why does Bocar build one with that drilling? Perhaps for use in a 1300 in Eur/RoW?
What's the downside of leaving it at 125 vs. enlarging it? And, if I enlarge it to 150 (I only have a 1.5mm drill), will that be a problem? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Wed Nov 25, 2020 12:08 pm Post subject: Re: Bocar 34PICT3 question |
bnam wrote: |
noticed that the Pilot Air bleed drilling is about 125 while the stock size for all VWs using 34PICT3s from 71-74 is 147.5. |
Not true. For instance, the 1975 specs for a type 2 with 1600 engine with 34 PICT-3 carb have a 120 pilot air jet.
Not a US-distributed model, of course. Carb specs varied widely depending on intended market for the vehicle. _________________ '67 bug: seized by the authorities
bnam Samba Member
Posted: Wed Nov 25, 2020 4:08 pm Post subject: Re: Bocar 34PICT3 question |
Yes, I was (incorrectly) thinking of US cars when I wrote that. Do you have the full specs for that 1975 T2 carb? Would you mind posting it? I would like to refer to it before I modify this Bocar. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
vwoldbug Samba Member
Posted: Wed Nov 25, 2020 4:17 pm Post subject: Re: Bocar 34PICT3 question |
What size main jet does it have . I think buses were different than beetles. |
Posted: Wed Nov 25, 2020 11:07 pm Post subject: Re: Bocar 34PICT3 question |
bnam wrote: |
Do you have the full specs for that 1975 T2 carb? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26313 Location: Douglas, WY
Posted: Thu Nov 26, 2020 1:14 am Post subject: Re: Bocar 34PICT3 question |
I'll call that image and raise you a few.
Whenever I've come across stuff like this over the last couple of decades, I've logged it on my charts. You can that chart here, sorted by the Modification State Number:
http://members.trainorders.com/android/temp/CarbBaseFlangeNumbersA.doc _________________ Andy T.
bnam Samba Member
Posted: Thu Nov 26, 2020 9:20 am Post subject: Re: Bocar 34PICT3 question |
@kreemoweet -- Thanks! _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
