Zeitgeist 13 Samba Member
Posted: Sat Nov 21, 2020 11:35 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Trust me, just cut the entire firewall out. It does nothing that helps you.
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17112 Location: Retired South Florida
Posted: Sun Nov 22, 2020 8:54 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
You may have another fittment issue. Did Boxeer fabricate the engine mount for the shorter 091 transaxle? Also, the aircooled transaxle had slightly longer CV shafts. I mention this because of my experience.
Not knowing how and where his engine support mounts, it might require you to use his engine attachment location and modify the trans mount and linkage.
I had the opposite problem. My original conversion used the 091’mounting and when I upgraded to the 091/1 trans I had to work around my original engine location. Shortening my trans bracket allowed for the later trans to fit without changing engine location.
So measure twice before you start cutting. It’s solvable. _________________ ☮️ |
charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Sun Nov 22, 2020 10:15 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
The mounts do not account for the aircooled differences. I’m chatting with Greg about this for future folks. He said the engine sits about 1/2” from the fw. So likely I’ll be about 1.5” in the fw.
See on the rear, the gap is exactly 2”
In the meantime, I cut out some spacers. Measured up and templated from the brackets. Used a nice thick 3/8” steel rectangle tube. If it’s good, I’ll powder coat them. This is why I’m near 90% gonna cut that firewall. My rough measurements say with the 2” difference I’ll be smacking through the FW
_________________ -------------------------------------------------
An example of my labor in action:
https://www.instagram.com/wileythewesty/
My Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=730525&highlight= |
syncrogreg Samba Member
Joined: November 08, 2009 Posts: 742 Location: USA (Nashville TN)
Posted: Sun Nov 22, 2020 11:21 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
The input shaft has to be cut as per the KEP directions. 15 and 50 degrees angles are identical because the adapter plate thickness stay the same for both 15 and 50 degree configuration. The amount of shaft to be cut is 7/16"
I did measure and I think 9mm is plenty to be cut and clear the crank.
Greg _________________ conversions: www.boxeer.com Common rail TDI and NOW PDK transmissions!!
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel |
Posted: Fri Nov 27, 2020 7:57 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
As I was test fitting my new clutch slave, I noticed the rubber hose from the frame to the slave was totally rotted. It was holding fluid, but I suspect that wouldn’t be for long.
I ordered a new braided line from burley that simplified the whole design anyway.
When I got it, it was really different. The nut on the end went from 17mm to 13mm and didn’t have the fit I was looking for- it was loose and killed like it wanted to fall out.
So I contacted burley. It’s nice to have some good customer service. He texted me back and we chatted it out. Short of it is that my old design is.... NLA from what I can tell. So I made a new bracket.
Cut it out of some spare galvinized sheet metal, welded it back on- and now I have a proper modern sized mount. _________________ -------------------------------------------------
My Build Thread:
Posted: Tue Dec 01, 2020 5:36 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Today i did some drillin' and weldin' to migrate the engine mounts back toward the rear about 1.5".
I added a reinforcing plate to the frame, as I felt that it needed just a little-teeny-weenie bit more than what it had with the original mustache bar
hindsight, while i had the welder powered up, i should have filled the old holes, but whatever. im not always a perfectionist.
I did a test fit with the boxeer engine, and this is where it landed the mounts.
Here are is a pic. It was fun.
My Build Thread:
4Gears4Tires Samba Member
Posted: Wed Dec 02, 2020 7:41 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
That's a neat engine lift. _________________ '87 Syncro
Posted: Tue Dec 08, 2020 9:28 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Today I did a little repair on the CVs that were in disrepair...
some pow-pow coating on the rear axle rods to make em purdy:
I left the paint off the boot match area as i figured i didnt want to mess with the tolerances. Powpow is no good with that _________________ -------------------------------------------------
My Build Thread:
Posted: Wed Dec 09, 2020 11:37 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Test fit #1
I put the thing in.
Aircooled 091 transaxle (as everyone knows) pushes the engine forward about 1.5"
Some ghetto mounts (on the left) as temporary spacers. Ill likely be cutting the boxeer SS mounts and extending them to fit the aircooled placement.
heres a few pics next day after i worked outside until 10pm with a headlamp in the freezing tahoe winter to mount this thing solo:
My Build Thread:
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Wed Dec 09, 2020 11:48 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Hell yeah! nice progress!
Why does the 091 Aircooled transaxle push things forward? |
Posted: Thu Dec 10, 2020 6:55 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
erste wrote: |
I believe it’s 2” longer. Smarter people may correct me if I’m wrong. Possible that it mounts 2” further forward than the wbx trans.
I don’t have a wbx to compare _________________ -------------------------------------------------
My Build Thread:
?Waldo? Samba Member
Posted: Thu Dec 10, 2020 7:57 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
The 091 and 091/1 transaxles are similar length. The 094 5-speed and 094 4wd syncro transaxles are longer. With the switch to the 091/1 and 094 in '83.5/83 the seam between engine and trans moved rearward presumably in order to give more room for the nose of the 094 5-speed trans (and probably for the eventual 094 4wd syncro trans). That change can also be seen in the engine mounting position and carrier bar difference between the '82 diesels (091 trans) and the '83 diesels (094 5-speed). |
Posted: Thu Dec 10, 2020 8:20 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
You can also just modify the trans mount to shift the drivetrain rearward. My van uses a DK trans, and I've added spacers to both lower and move everything back. Definitely easier than modifying Greg's mounts.
y u rune klassik? |
Posted: Thu Dec 10, 2020 9:57 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Quote: |
You can also just modify the trans mount to shift the drivetrain rearward. |
but then youd gotta run WBX shifter, yes?
Honestly, its not hard to mod gregs mounts. Im gonna slice and splice them with stainless. _________________ -------------------------------------------------
My Build Thread:
Posted: Thu Dec 10, 2020 10:00 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
You might need to lengthen one linkage rod. I don't think you'd need to do any other changes to the shifter/linkage. |
Posted: Thu Dec 10, 2020 11:45 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
I'm running a modified 091 rear shift rod mated to a stock 091/1 front section. Shifts are buttery smooth. _________________ Casey--
y u rune klassik? |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10368 Location: Sunshine Coast B.C.
