Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!!
Page: Previous  1, 2, 3 ... 23, 24, 25
Cliff@BrownBags
Cliff@BrownBags is offline
PostPosted: Fri Jul 08, 2016 8:59 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
damn that is so tempting. I love the idea of stock reliability but added fun. Is 1800 the price for me to take my stock 1500sp, and slap the kit on and drive?
its not about what you say you will do oneday, its what you do today that actualy means something.
Joel Mohr
Joel Mohr is offline
PostPosted: Thu Jul 14, 2016 10:48 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Pretty much! The kit doesn't come with a locked out 009, but other than that, It doesn't require any other parts. The turbos went up though, and the kit is now 1900....throttle cable for a bug, header, rebuilt Kadron pre-jetted, intake, boots, clamps...as you see in the pics...
SEE YOU AT THE RACES!!!!
Joel Mohr
PostPosted: Tue Jul 19, 2016 9:24 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Just finished dyno tuning a 1915 with our kit, 200 HP 220 TQ...small cam and some head work...
Striker27
Striker27 is offline
PostPosted: Thu Sep 29, 2016 9:15 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Where can you get one of these kits? How much are they?
Jjackson27
Jjackson27 is offline
PostPosted: Fri Nov 04, 2016 7:26 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Okay so this is my first post here, i have a vanagon and a bug. The buggy is in need of more power and turbo is the route im taking. I saw the list of items needed for the turbo set up and was wondering if anyone could give me a full rundown on where to get the items, how to install, etc.
Thanks alot
Joel Mohr
PostPosted: Fri Nov 11, 2016 8:52 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
I'm sold out on the kits, but with enough interest, I'll make more...BTW, just built a 1672 (65 x 90.5) for my Puma, 211 TQ, 185 HP...11 PSI, pump gas...
56vvdubb
56vvdubb is offline
PostPosted: Thu Aug 09, 2018 12:43 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Aloha guys, here is an update to this thread. Here is a Joel Mohr turbo set up on a Stock 1600SP engine built by Billy Manely (here on the Samba). Street driven on 9lbs. of boost. Not sure about the HP, did not dyno the car. I have driven the car roughly 1000 miles and no issues with oiling that I know of, I have the top of the decklid popped for additional cooling while driving. I will be putting on a CHT gauge and Oil temp dipstick to monitor. I really just drive regularly and cruise hardly on boost. It is only when you need or want boost that is comes on. At 4000 rpm in 3rd gear pushing 9lbs. of boost is great fun. MPG's right now hover around 17mpg with the current jetting. I am sure that is because of my heavy foot and an increase in HP. I ordered the kit straight from Mohr performance and added the 09 distributor locked out. The kit has everything to "Bolt on". I will be ordering another kit for my bus when it is ready.
madmike
madmike is offline
PostPosted: Thu Aug 09, 2018 3:47 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Cool Cool
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
bj
bj is offline
PostPosted: Thu Aug 09, 2018 8:40 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
can't wait to drive it!! Very Happy
Dr OnHolliday
Dr OnHolliday is offline
PostPosted: Thu Aug 09, 2018 11:23 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Kool stuff. I wouldn't run a turbo without a welded and balanced fan, tho.
1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
TheViking
TheViking is offline
PostPosted: Thu Aug 09, 2018 4:28 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Why is that? Stock pulley setup slips at 4500 rpm?
Dauz
Dauz is offline
PostPosted: Thu Aug 09, 2018 4:33 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Welded and balanced fans are a necessity based off revolutions per minute. Not forced induction (or lack therof).
clonebug
clonebug is offline
PostPosted: Sun Aug 12, 2018 8:06 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
With a turbo you don't need to rev a stock engine past 5000-5500 rpm....if the turbo is sized correctly.
Your mileage is probably due to a rich jetting rather than a heavy foot.
With a draw through you use fuel to keep your intake temps in check to combat detonation.
Get a decent AFR meter and you can tune that engine better.
I recommend the PLX gauge.....no calibrating and very reasonably priced. The gauge will display volts so if you have a voltmeter you can just install it in place of that gauge.
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
Joel Mohr
PostPosted: Tue Sep 18, 2018 8:24 am    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
Looks good! Thanks!
dillon schuh
dillon schuh is offline
PostPosted: Wed Dec 02, 2020 5:58 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
is this Kit still available ?
oprn
oprn is offline
PostPosted: Thu Dec 03, 2020 3:08 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
I love the simplicity of your kits Joel Mohr! And the fact that it all fits under the stock engine cover. By limiting these systems to 10 or 11 psi they are so much more user friendly and yes there is a market out there for less than monster performance. A budget turbo kit is the perfect answer.
I have just finished building a nice 1641 SP with the intent to keep it N/A but you are making it very difficult to keep my resolve!! The only thing I would change is to dump the locked 009 and go with a junkyard crank trigger conversion.
dillon schuh
PostPosted: Thu Dec 03, 2020 5:51 pm    Post subject: Re: Homemade Turbo 1600 Single Port recipe, DYNO'ED, NOW T3/T4!! Reply with quote
I have a 1641 DP with a 34 pic
its super reliable but its a dog on the hills
Budget turbo kit needed
Page 25 of 25
