1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Dec 04, 2020 10:39 pm Post subject: Re: Luxury Tools |
I like it but NO WAY am I paying $28 shipping...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Fri Dec 04, 2020 11:26 pm Post subject: Re: Luxury Tools |
the big milwaukee, will buzz of castle nuts, just like they are lug nuts, not been beaten yet, some of the castle nuts they've broke, hadn't ever been off, very impressive IMHO, i had a milwaukee rep at home depot buzz off the castle nuts on my van, i'd over torqued them deliberately, trying to ensure faliure, as i'd told her, i'd buy there and then, if it took off the nuts.
i think i'd gone well over 1200ftlbs, they were bad bearings and have been replaced since, but the impact took them off, i was blown away.
the 18v dewalt i had been using, wouldn't touch lug nuts.
djkeev wrote: |
Wow!
Spendy tool Mark!
I have a DeWalt 18v 1/4" hex impact.
It delivers more than I'll ever want.
My 120 v DeWalt impact matches or exceeds my 1/2" air powered NAPA impact for the larger tasks.
Dave |
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Sat Dec 05, 2020 6:29 am Post subject: Re: Luxury Tools |
If you like to think of "luxury" as perceived benefit instead of actual cost, then this $7 Harbor Freight transfer pump will have you eating bonbons and sipping bubbly when the job of changing your trans lube is done.
One caveat: if you don't shorten the intake tube be sure to route it into the supply vessel in a piece of PVC to keep the red plastic tube from curling inside the container and sucking air.
Two caveat: gear lube is pretty viscous so be patient and don't force it.
_________________ '87 Westy in Wolfram Grey Metallic |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Sat Dec 05, 2020 11:52 am Post subject: Re: Luxury Tools |
i don't know what kind of magazines you had access to, yikes.
dobryan wrote: |
Looks like something you’d see in the back of certain magazines in my younger days. |
619 201 0310 |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Sat Dec 05, 2020 12:06 pm Post subject: Re: Luxury Tools |
campism wrote: |
For a little more coin, I much prefer this tool. I use it daily around the shop.
https://www.amazon.com/Mityvac-MVA6851-Automotive-...merReviews
They even offer a larger, 1.5 liter version, which I also own and use occasionally.
https://www.amazon.com/Mityvac-MVA6852-Fluid-Extra...P5EWYVGZV1 _________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Sat Dec 05, 2020 3:42 pm Post subject: Re: Luxury Tools |
here's a useful tool i cobbled up... an impact screwdriver/torx/etc. using the Holy Grail of impact hammers, the Snap On PH3050, i welded a blank Parker .401 impact shank to an old 3/8" extension with a hole thru it. attach any tool to the drive part. this allows one to hammer away on a #$%@ screw while applying only slight torque with the crossbar. after beating the beejeezus out of them, the screws seem to always yield.
_________________ -dan
www.thefixitworkshop.com |
Posted: Sun Dec 06, 2020 6:37 am Post subject: Re: Luxury Tools |
revolution337 wrote: |
campism wrote: |
https://www.amazon.com/Mityvac-MVA6852-Fluid-Extra...P5EWYVGZV1 |
I get it, but the HF tool is a transfer pump. Pulls fluid out of the supply vessel on the upstroke and sends it to the receiving vessel on the downstroke without having to move the hoses around. Extremely helpful for my working conditions at that moment. _________________ '87 Westy in Wolfram Grey Metallic |
jimf909 Samba Member
Posted: Sun Dec 06, 2020 9:12 am Post subject: Re: Luxury Tools |
After years of hacking away with cheap syringes, etc. I bought the first MityVac mentioned above and appreciate the it was worth spending $25 on.
It looks like amazon sells the HF pump under different brands for a few bucks more...
https://www.amazon.com/Koehler-Enterprises-RA990-M...HVR97JT94D _________________ - Jim
Abscate wrote: |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sun Dec 06, 2020 2:07 pm Post subject: Re: Luxury Tools |
I just spent some bucks on a torque multiplier to get the rear axle nut off and back on again a bit easier.
Proto Torque Multiplier J6202A
https://www.amazon.com/gp/aw/d/B002FCLA9Q?ref=ppx_pt2_mob_b_prod_image
There is less expensive ones listed on Amazon, but I wanted an American vender as opposed to the imports. _________________ This free advice is worth exactly what you paid for it.
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sun Dec 06, 2020 7:43 pm Post subject: Re: Luxury Tools |
Bloody hell! A four foot 3/4" breaker bar and 46mm socket came to ~$75 for me on Ebay a couple of years ago. The breaker bar has proved its worth on several other projects as well. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Sun Dec 06, 2020 8:50 pm Post subject: Re: Luxury Tools |
fxr wrote: |
Bloody hell! A four foot 3/4" breaker bar and 46mm socket came to ~$75 for me on Ebay a couple of years ago. The breaker bar has proved its worth on several other projects as well. |
Yep, I got that too. Plus 2 pieces of 4' pipe for extended leverage that fit inside each other for easier storage to fit over the end of the breaker bar and the torque wrench I use to put the nut back on.
I know for a fact from experience that a Torque Multiplier is faster and easier then using that setup. I can also use a smaller torque wrench. When you're by yourself with only two hands it is easier.
One little trick if you have questionable quality 46mm socket it is a good idea to put a hose clamp around the end that fits over the nut to keep it from cracking. Works on all cheap socket sets you buy at the flea markets! _________________ This free advice is worth exactly what you paid for it.
Posted: Sun Dec 06, 2020 9:44 pm Post subject: Re: Luxury Tools |
l considered similar, but ended up with a milwaukee 1/2'' impact.
similar cost, less effort on my part
i fancy the 3/4'' milwaukee impact, also.
619 201 0310 |
Abscate Samba Member
Posted: Mon Dec 07, 2020 5:00 am Post subject: Re: Luxury Tools |
Steve M. wrote: |
fxr wrote: |
One little trick if you have questionable quality 46mm socket it is a good idea to put a hose clamp around the end that fits over the nut to keep it from cracking. Works on all cheap socket sets you buy at the flea markets! |
Why waste a hose clamp when you can steal a zip tie from a wheel chair bound person? They can’t chase you , either. _________________ .ssS! |
clift_d Samba Member
Joined: December 02, 2012 Posts: 265 Location: Hackney innit, UK
Posted: Mon Dec 07, 2020 7:19 am Post subject: Re: Luxury Tools |
Well done - it makes that 46mm nut really easy doesn't it.
The main disadvantage I spotted with the cheap torque multipliers, aside from build quality, is that they don't tell you what torque ratio you're getting, although you could probably work it out by comparing input to output rotations. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue Feb 23, 2021 3:40 pm Post subject: Re: Luxury Tools |
there was a sale on a 'garage pack' of Hylomar... couldn't resist!
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
