ncpi Samba Member
Posted: Sat Dec 05, 2020 9:27 am Post subject: Sheet metal hole punch recommendation |
Getting ready to do floor pans. I either want to pick up a cheap pneumatic punch or possibly a hand punch if I need to. My compressor is FL is a small 0.6 CFM.
Pneumatic punches seem to take about 4CFM. Hey, I only have about 30-40 holes per floor. Any idea what kind of cycle time I would have to deal with if I used my 0.6 CFM compressor. I'm not looking to buy a bigger compressor, but if I can punch a hole every 2 minutes it would only take an hour per floor pan
Alternatively, I could buy a hand operated hole punch. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2065 Location: Bulli Klinik, Colorado Springs
Posted: Sat Dec 05, 2020 9:39 am Post subject: Re: Sheet metal hole punch recommendation |
I've been using a Roper-Whitney hand punch for years. There is a generic version available for about half the price on Amazon.
As a side-note, I've extended the handles on mine so that I can place it in a vice and have a bit more leverage while punching holes.
https://www.amazon.com/Capri-Tools-CP21050-21050-P...KNKR23V1X6 _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
ncpi Samba Member
Posted: Sat Dec 05, 2020 9:45 am Post subject: Re: Sheet metal hole punch recommendation |
Bulli Klinik wrote: |
https://www.amazon.com/Capri-Tools-CP21050-21050-P...KNKR23V1X6 |
That one on Amazon is exactly the one I was looking at. Good to hear the positive feedback. how much hand force does it take to punch thru floor pans (probably 20 Ga.)?
Hand punch and cheap pneumatic are about the same price. |
67ctbug Samba Member
Posted: Sat Dec 05, 2020 11:47 am Post subject: Re: Sheet metal hole punch recommendation |
I use a Whitney hand punch at work, doesn't hardly take any force at least for the one I use. I'd say about the same as cutting a piece of 20 or 18 gauge with aviation snips. It may be annoying to do floor pans with, but less annoying than waiting for a compressor to catch up. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Sat Dec 05, 2020 5:47 pm Post subject: Re: Sheet metal hole punch recommendation |
A dual point drill bit (Pilot Point) or a step bit works really good on sheet metal. |
ncpi Samba Member
Posted: Sun Dec 06, 2020 5:54 am Post subject: Re: Sheet metal hole punch recommendation |
Thanks guys, looks like the hand punch will work. I probably won't drill even though its the cheapest route as I would rather not clean up all the holes.
I still wonder if the pneumatic punch would work well enough on my tiny compressor. Anyone tried it? |
Posted: Sun Dec 06, 2020 6:11 pm Post subject: Re: Sheet metal hole punch recommendation |
The air hammers I have do not exhaust my compressor much. I would think a 3.5 and up Hp would work. I believe a air punch;that is hand held anyways , would mostly be dependent on psi and not air flow because you do not do them very fast. |
Posted: Tue Dec 08, 2020 9:41 am Post subject: Re: Sheet metal hole punch recommendation |
ncpi wrote: |
If your options are a cheapo air punch, I wouldn't bother. The quality units work well but the manual punch will always work. It also gives you the option of different sized holes. I use a couple pieces of pipe to extend the handle for additional leverage on my hand punch. My HF flanger/punch lives in the least opened drawer of my tool box for a reason. Next stop will be the garbage can.
Infinite, if you're still drilling panels for rosette welds, treat yourself to a punch. You'll see that it will be well worth the money, save you time and give you a better final product with no burrs to file. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Tue Dec 08, 2020 3:00 pm Post subject: Re: Sheet metal hole punch recommendation |
I thought I would post the other two methods because I found that they worked well. They get a perfectly round hole unlike a regular drill bit. I have a pre "Chinese flood the market' Chinese Whitney punch that works perfect. |
ncpi Samba Member
Posted: Tue Dec 08, 2020 3:14 pm Post subject: Re: Sheet metal hole punch recommendation |
Thanks guys...appreciate your input and the ability to learn from your experiences. I think I'll go with the hand punch. |
misterh Samba Member
Joined: May 03, 2018 Posts: 23 Location: Central Texas
Posted: Thu Dec 10, 2020 6:40 am Post subject: Re: Sheet metal hole punch recommendation |
ncpi wrote: |
The Harbor Freight flange/punch works for me. It only consumes air for a fraction of a second for each hole. |
ncpi Samba Member
Posted: Thu Dec 10, 2020 7:12 am Post subject: Re: Sheet metal hole punch recommendation |
misterh wrote: |
ncpi wrote: |
Thanks! That's exactly what I wanted to know...but....I just pulled the trigger on ordering the hand punch, literally 5 minutes before your post |
Posted: Thu Dec 10, 2020 10:04 am Post subject: Re: Sheet metal hole punch recommendation |
Here's the handle extension I use on my punch. You can make quick work of punching holes with the punch in a vice. I welded a flange on the lower handle in order to mount it.
In addition to punching holes for rosette welds, I use mine with an 1/8" punch to make these little tabs used to trial fit and align panels prior to welding. Benefit is that you can align the panels with no gap as opposed to the wingnut style panel clamps. Always shoot for no gaps.
Mike K
Bulli Klinik
Colorado Springs |
ncpi Samba Member
Posted: Thu Dec 10, 2020 5:52 pm Post subject: Re: Sheet metal hole punch recommendation |
In addition to punching holes for rosette welds, I use mine with an 1/8" punch to make these little tabs used to trial fit and align panels prior to welding. Benefit is that you can align the panels with no gap as opposed to the wingnut style panel clamps. Always shoot for no gaps. |
Nice welds! I hope I don't need handle extensions that long I bet the cheap chinese hand punch's die cast handles would snap |
ncpi Samba Member
Posted: Fri Mar 19, 2021 6:58 am Post subject: Re: Sheet metal hole punch recommendation |
Just a follow-up. I bought the capri hand punch from Amazon. It's actually pretty nice. Then when I was getting ready to punch holes I decided to get the cheap, on sale, air punch at HF.
The air punch works great on the pans I have, even with the cheap under $40 air compressor from HF. They are 20 GA. I can do a whole pan with the Air compressor only repumping once.
I ended up using the hand punch to make holes in the rubber heater channel to pan gasket. That works great too. |
Posted: Fri Mar 19, 2021 11:54 am Post subject: Re: Sheet metal hole punch recommendation |
I have the HF punch/flange tool and it works great. It perfect for punching holes for plug welding.
I also have a "long reach" hand punch that I bought somewhere 30 years ago. It's good for larger holes like for the pan's body bolts. |
