Sheet metal hole punch recommendation
ncpi
ncpi is offline
PostPosted: Sat Dec 05, 2020 9:27 am    Post subject: Sheet metal hole punch recommendation Reply with quote
Getting ready to do floor pans. I either want to pick up a cheap pneumatic punch or possibly a hand punch if I need to. My compressor is FL is a small 0.6 CFM.
Pneumatic punches seem to take about 4CFM. Hey, I only have about 30-40 holes per floor. Any idea what kind of cycle time I would have to deal with if I used my 0.6 CFM compressor. I'm not looking to buy a bigger compressor, but if I can punch a hole every 2 minutes it would only take an hour per floor pan Smile
Alternatively, I could buy a hand operated hole punch.
Bulli Klinik
Bulli Klinik is offline
PostPosted: Sat Dec 05, 2020 9:39 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
I've been using a Roper-Whitney hand punch for years. There is a generic version available for about half the price on Amazon.
As a side-note, I've extended the handles on mine so that I can place it in a vice and have a bit more leverage while punching holes.
https://www.amazon.com/Capri-Tools-CP21050-21050-P...KNKR23V1X6
I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs
ncpi
ncpi is offline
PostPosted: Sat Dec 05, 2020 9:45 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
That one on Amazon is exactly the one I was looking at. Good to hear the positive feedback. how much hand force does it take to punch thru floor pans (probably 20 Ga.)?
Hand punch and cheap pneumatic are about the same price.
67ctbug
67ctbug is offline
PostPosted: Sat Dec 05, 2020 11:47 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
I use a Whitney hand punch at work, doesn't hardly take any force at least for the one I use. I'd say about the same as cutting a piece of 20 or 18 gauge with aviation snips. It may be annoying to do floor pans with, but less annoying than waiting for a compressor to catch up.
'67 Beetle L41
'71 Westfalia (sold) Sad
'74 Westfalia
‘69 Plymouth
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
infiniteLoop
infiniteLoop is offline
PostPosted: Sat Dec 05, 2020 5:47 pm    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
A dual point drill bit (Pilot Point) or a step bit works really good on sheet metal.
ncpi
ncpi is offline
PostPosted: Sun Dec 06, 2020 5:54 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
Thanks guys, looks like the hand punch will work. I probably won't drill even though its the cheapest route as I would rather not clean up all the holes.
I still wonder if the pneumatic punch would work well enough on my tiny compressor. Anyone tried it?
infiniteLoop
PostPosted: Sun Dec 06, 2020 6:11 pm    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
The air hammers I have do not exhaust my compressor much. I would think a 3.5 and up Hp would work. I believe a air punch;that is hand held anyways , would mostly be dependent on psi and not air flow because you do not do them very fast.
Bulli Klinik
PostPosted: Tue Dec 08, 2020 9:41 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
If your options are a cheapo air punch, I wouldn't bother. The quality units work well but the manual punch will always work. It also gives you the option of different sized holes. I use a couple pieces of pipe to extend the handle for additional leverage on my hand punch. My HF flanger/punch lives in the least opened drawer of my tool box for a reason. Next stop will be the garbage can.
Infinite, if you're still drilling panels for rosette welds, treat yourself to a punch. You'll see that it will be well worth the money, save you time and give you a better final product with no burrs to file.
Mike K
Bulli Klinik
Colorado Springs
infiniteLoop
PostPosted: Tue Dec 08, 2020 3:00 pm    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
I thought I would post the other two methods because I found that they worked well. They get a perfectly round hole unlike a regular drill bit. I have a pre "Chinese flood the market' Chinese Whitney punch that works perfect.
ncpi
ncpi is offline
PostPosted: Tue Dec 08, 2020 3:14 pm    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
Thanks guys...appreciate your input and the ability to learn from your experiences. I think I'll go with the hand punch.
misterh
misterh is offline
PostPosted: Thu Dec 10, 2020 6:40 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
The Harbor Freight flange/punch works for me. It only consumes air for a fraction of a second for each hole.
ncpi
ncpi is offline
PostPosted: Thu Dec 10, 2020 7:12 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
Thanks! That's exactly what I wanted to know...but....I just pulled the trigger on ordering the hand punch, literally 5 minutes before your post Sad Crying or Very sad
Bulli Klinik
PostPosted: Thu Dec 10, 2020 10:04 am    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
Here's the handle extension I use on my punch. You can make quick work of punching holes with the punch in a vice. I welded a flange on the lower handle in order to mount it.
In addition to punching holes for rosette welds, I use mine with an 1/8" punch to make these little tabs used to trial fit and align panels prior to welding. Benefit is that you can align the panels with no gap as opposed to the wingnut style panel clamps. Always shoot for no gaps.
Mike K
Bulli Klinik
Colorado Springs
ncpi
ncpi is offline
PostPosted: Thu Dec 10, 2020 5:52 pm    Post subject: Re: Sheet metal hole punch recommendation Reply with quote
Nice welds! I hope I don't need handle extensions that long Surprised I bet the cheap chinese hand punch's die cast handles would snap Laughing
