181Klischies Samba Member
Posted: Wed Dec 16, 2020 3:26 pm Post subject: Ignition lock diameter - Speedo Pod |
Hi guys, I need your help. Can someone give me the correct diameter of the ignition lock or the hole for it in the speedo pod? Some previous owner drilled the pod to install an aftermarket unit.
Also, has anyone restored it? I don't even know where to start.
Btw, I didn't find any thread with this info.
Thanks! _________________ 58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
81' Karmann Ghia Safari Mobil |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 984 Location: Bath, England
Posted: Thu Dec 17, 2020 5:04 pm Post subject: Re: Ingnition lock diameter - Speedo Pod |
That's a whacky upside down dash set up you have there. Never seen that before.
From a NOS ignition barrel and keys I have, purchased from a VW dealer many years ago, the barrel measures 15.85mm diameter, and the opening in the pod 16.25mm.
Hope this helps.
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Fri Dec 18, 2020 6:24 pm Post subject: Re: Ignition lock diameter - Speedo Pod |
As someone who restores those speedo pods, I am of the opinion you are way better off finding a new pod than trying to repair that one. There is no easy way to repair that augered out ignition switch hole and truth is, unmolested pods are not that hard to find. But find one that has the original ignition switch cap on the back. 80-90% of them are missing this part. They are not available anywhere as a reproduction part that can be used. (Yes, that Sam Steel guy in Spain makes them, but they are resin cast, not bekelite and they will not stand up to the needed soldering of the terminal bus bar). The parts internal to the switch are all readily available. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sun Dec 20, 2020 11:13 am Post subject: Re: Ignition lock diameter - Speedo Pod |
Thanks Johnshenry and Martin! That's the info I was looking for.
A new question arises. My car is a 52' deluxe. Can I use any pod (barndoor, standart splitbug or does it need to be a deluxe aswell)? I was thinking on getting any of those and paint it ivory.
I heard that the speedo hole is a different size. The one offered to me is 10 cm. Unfortunately my car is 80 kilometers away and my city is in quarantine. Can't measure mine at the moment.
This photos were sent to me by the seller. What do you think?
Thanks!! _________________ 58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
Posted: Sun Dec 20, 2020 12:09 pm Post subject: Re: Ignition lock diameter - Speedo Pod |
100mm is a deluxe pod. Will work well for your car, looks like a nice, complete pod.
Standard pods are 95mm speedometer opening. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sun Dec 20, 2020 12:49 pm Post subject: Re: Ignition lock diameter - Speedo Pod |
johnshenry wrote: |
Standard pods are 95mm speedometer opening. |
Thanks John! So, that pod should have been ivory in the past? _________________ 58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
Posted: Sun Dec 20, 2020 6:05 pm Post subject: Re: Ignition lock diameter - Speedo Pod |
181Klischies wrote: |
johnshenry wrote: |
Thanks John! So, that pod should have been ivory in the past? |
Yes, that is correct. _________________ John Henry
'57 Deluxe
'56 Single Cab |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2171 Location: Graz, Austria, Europe
Posted: Mon Dec 21, 2020 5:44 am Post subject: Re: Ignition lock diameter - Speedo Pod |
Look closer and you will see remnants of the original ivory paint inside the ign lock hole and around the perimeter of the speedo hole.
It would also provide a good means to color match some new paint!
That is a nice pod for sure !
johnshenry wrote: |
_________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Dec 22, 2020 4:56 pm Post subject: Re: Ignition lock diameter - Speedo Pod |
… sure like standard dark brown more than ivory and put standard pods in, when possible, in my deluxe dashes - z
this was our 6/52 deluxe
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Mon Jan 25, 2021 10:37 am Post subject: Re: Ignition lock diameter - Speedo Pod |
Hi guys! Thanks for the help! The pods are on their way! _________________ 58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
