Ignition lock diameter - Speedo Pod
181Klischies
181Klischies is offline
PostPosted: Wed Dec 16, 2020 3:26 pm    Post subject: Ignition lock diameter - Speedo Pod Reply with quote
Hi guys, I need your help. Can someone give me the correct diameter of the ignition lock or the hole for it in the speedo pod? Some previous owner drilled the pod to install an aftermarket unit.
Also, has anyone restored it? I don't even know where to start.
Btw, I didn't find any thread with this info.
Thanks!
58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
81' Karmann Ghia Safari Mobil
Martin Southwell
Martin Southwell is offline
PostPosted: Thu Dec 17, 2020 5:04 pm    Post subject: Re: Ingnition lock diameter - Speedo Pod Reply with quote
That's a whacky upside down dash set up you have there. Never seen that before.
From a NOS ignition barrel and keys I have, purchased from a VW dealer many years ago, the barrel measures 15.85mm diameter, and the opening in the pod 16.25mm.
Hope this helps.
johnshenry Premium Member
johnshenry is offline
PostPosted: Fri Dec 18, 2020 6:24 pm    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
As someone who restores those speedo pods, I am of the opinion you are way better off finding a new pod than trying to repair that one. There is no easy way to repair that augered out ignition switch hole and truth is, unmolested pods are not that hard to find. But find one that has the original ignition switch cap on the back. 80-90% of them are missing this part. They are not available anywhere as a reproduction part that can be used. (Yes, that Sam Steel guy in Spain makes them, but they are resin cast, not bekelite and they will not stand up to the needed soldering of the terminal bus bar). The parts internal to the switch are all readily available.
John Henry
'57 Deluxe
'56 Single Cab
181Klischies
PostPosted: Sun Dec 20, 2020 11:13 am    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
Thanks Johnshenry and Martin! That's the info I was looking for.
A new question arises. My car is a 52' deluxe. Can I use any pod (barndoor, standart splitbug or does it need to be a deluxe aswell)? I was thinking on getting any of those and paint it ivory.
I heard that the speedo hole is a different size. The one offered to me is 10 cm. Unfortunately my car is 80 kilometers away and my city is in quarantine. Can't measure mine at the moment.
This photos were sent to me by the seller. What do you think?
Thanks!!
58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
PostPosted: Sun Dec 20, 2020 12:09 pm    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
100mm is a deluxe pod. Will work well for your car, looks like a nice, complete pod.
Standard pods are 95mm speedometer opening.
John Henry
'57 Deluxe
'56 Single Cab
181Klischies
PostPosted: Sun Dec 20, 2020 12:49 pm    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
Thanks John! So, that pod should have been ivory in the past?
58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
PostPosted: Sun Dec 20, 2020 6:05 pm    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
Yes, that is correct.
John Henry
'57 Deluxe
'56 Single Cab
djfordmanjack
djfordmanjack is offline
PostPosted: Mon Dec 21, 2020 5:44 am    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
Look closer and you will see remnants of the original ivory paint inside the ign lock hole and around the perimeter of the speedo hole.
It would also provide a good means to color match some new paint!
That is a nice pod for sure !
Hotrods, Fords, Veedubs and Triumph Twins ! ______Barndoor + Kohlruss Coachbuilt DLX afficionado
'51 Brezel project, Azurblau L36
'52 BD Coachbuild project
'54 Oval Sunroof project with my son, L275 Lichtbeige
'55 Wolfsburg panel project, Taubenblau L31 all original paint
'56 Oval, Polarsilber L324 og paint og chrome og everything
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Tue Dec 22, 2020 4:56 pm    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
sure like standard dark brown more than ivory and put standard pods in, when possible, in my deluxe dashes - z
this was our 6/52 deluxe
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
'91 NSX- wishful thinking
All super-heroes, wear a MASK
181Klischies
PostPosted: Mon Jan 25, 2021 10:37 am    Post subject: Re: Ignition lock diameter - Speedo Pod Reply with quote
Hi guys! Thanks for the help! The pods are on their way!
58' PGSG
61' Single Cab
62' T34
68' T34
70' Double Cab
71' 181
