Roof Insulation
Page: Previous  1, 2
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu Nov 26, 2020 10:47 am    Post subject: Re: Roof Insulation Reply with quote
blue72beetle wrote:
First five words were "Not gonna be a camper" and people lose their minds about vanlife Laughing
Some folks like talking more than conversing. This is just the electronic version. Laughing
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
alaskadan
alaskadan is offline
PostPosted: Thu Nov 26, 2020 6:07 pm    Post subject: Re: Roof Insulation Reply with quote
Rmax is fine dude. We are all bored and nitpicking the nuances of different insulation to use. Chances are our vans will be taken care of better for the next 40 years than the previous 40 as they get rarer and more cherished. I'd say the worst part about using the rmax is its rigidity making impossible to install tight to the metal with no trapped ish moist air pockets behind it.
calvinater
calvinater is offline
PostPosted: Fri Nov 27, 2020 8:00 am    Post subject: Re: Roof Insulation Reply with quote
nemobuscaptain wrote:
calvinater wrote:
If you eliminate any air space , there will be no where for condensation to form.
lol wut? If you have cold metal and humid warmer are inside, it will still form.
It still has condensation under there, you just don't SEE it. If you feel the insulation it will often be soggy.
theoretically it is possible to get a complete vapor barrier. realistically it's almost impossible to achieve. even manufacturers fail to achieve it.
In the building trades it is known as eliminating the cold condensing area.
"Albatross"!
malcolm2
malcolm2 is offline
PostPosted: Fri Nov 27, 2020 8:02 am    Post subject: Re: Roof Insulation Reply with quote
I decided to do a small test. I weighed a hunk of R-Max. Soaked it in a bowl of water for 19 hours. Weighed it again. Same weight.
So I would say R-max does not absorb water.
BEFORE
DURING
AFTER
My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
ccpalmer
ccpalmer is offline
PostPosted: Fri Nov 27, 2020 6:11 pm    Post subject: Re: Roof Insulation Reply with quote
all buses should be campers.
Smile
Very True!!
airschooled wrote:
Some folks like talking more than conversing. Laughing
Also very true
'71 Westy
SGKent Premium Member
SGKent is offline
PostPosted: Fri Nov 27, 2020 7:06 pm    Post subject: Re: Roof Insulation Reply with quote
I wouldn't be that concerned about it soaking up water. I would be concerned about water wicking behind it and sitting there. Until you spend a night in a cold bus and wake up wit water all over everything on the shell you won't understand. See this rust? It is all from the inside out due to condensation inside layers in the top not drying out. It is a lot of work to get rid of it.
This is all from the inside out.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
nemobuscaptain
nemobuscaptain is offline
PostPosted: Fri Nov 27, 2020 11:06 pm    Post subject: Re: Roof Insulation Reply with quote
calvinater wrote:
in the building trades it is known as eliminating the cold condensing area.
In the building trades you dont insulate a small portion of a couple if walls and ignore the areas that are really losing heat or allowing summer heat in . An IR camera easily shows it isnt the metal panels leaking our heat.
It is total waste of time.
There is a reason car manufacturers dont build cars like buildings.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
Last edited by nemobuscaptain on Fri Jan 22, 2021 10:37 pm; edited 2 times in total
kens4um
kens4um is offline
PostPosted: Mon Dec 21, 2020 12:46 am    Post subject: Re: Roof Insulation Reply with quote
I am trying to insulate the front of my bus and used fiberglass before with no problem. Last year I put on double bubble reflective insulation contact cement to metal roof which gave me a 7 degree cooler ceiling. I am going to look for condensation though I would think contact cement would keep the condensation from reaching the roof..will respond if I see trouble...
Abscate
Abscate is offline
PostPosted: Mon Dec 21, 2020 5:40 am    Post subject: Re: Roof Insulation Reply with quote
Great rant, worthy of bookmarking...with one correction
good bag can keep you comfortable well below zero real American degrees
Dutch, Polish-German origin. That’s aboutAmerican as you can get.
.ssS!
old DKP driver
old DKP driver is offline
PostPosted: Mon Dec 21, 2020 9:31 am    Post subject: Re: Roof Insulation Reply with quote
It’s 35 degrees here this morning with insulation. Does this really matter since
It’s winter time? Probably the same in the bus/camper in my garage Rolling Eyes
V.W.owner since 1967
malcolm2
malcolm2 is offline
PostPosted: Mon Dec 21, 2020 2:57 pm    Post subject: Re: Roof Insulation Reply with quote
The original thought I had in the OP was more about the heat. The sun beaming down on the huge metal roof and side panels heating up the interior.
But like an insulated Thermos.... It keeps hot things hot and it keeps cold things cold.... "How do it know?"
Page: Previous  1, 2
Page 2 of 2
