kdnguyen61 Samba Member
Joined: June 14, 2019 Posts: 109 Location: Houston, Texas
Posted: Mon Dec 21, 2020 5:14 pm Post subject: Trunk hinge problem with EMPI Dual HPMX |
Hi Members,
I am trying to put my trunk lid back on the car but the trunk hinges are hitting the top of my air filters. I have a 3 1/2 inches filters. Currently the hinge springs are sitting at the second hole from the bottom. Someone told me that I can move the spring where when you close, the spring will stop at certain point.
So, here are some options I am thinking of:
1) Move the spring like up to the top hole. This may give the clearance. But when I move one side, it looks like the hinge is up higher than before. Will this raise the trunk lid up when it fully close? Is this a the right way to get clearance?
2) Or buy the rectangle air filters with 2 1/2 filters and don't install the chrome velocity stacks?
3) Or buy another round filters like from JBugs which has 5.5" diameter and 2" high but I measured my current filters and they have 5" ID and 6" OD. Will this work?
I am sure some members out there with Ghia and have installed dual air filters before. Thank you in advance. |
c21darrel Samba Member
Duncan67KG Samba Member
Joined: August 09, 2015 Posts: 33 Location: Southern California
Posted: Mon Dec 21, 2020 7:39 pm Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
I went for the struts as well...
I ordered the parts from Mcmaster-Carr
_________________ Duncan
1967 Ghia Coupe |
bt Samba Member
Joined: January 29, 2004 Posts: 441 Location: chicago
Posted: Tue Dec 22, 2020 5:25 am Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
https://www.thesamba.com/vw/forum/viewtopic.php?t=250851&start=80
Check out page 5.
I cut my springs (It's been about 9 years without them being a problem) after having the struts.
C21darrel links to a very simple option _________________ Most people think that they are thinking....... but all they are really doing is rearranging their prejudices |
PeteSC Samba Member
Posted: Tue Dec 22, 2020 7:18 am Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
Try moving them up a hole and see what you get. I have a friend with 2 Ghias that he ran without springs for 20 years, only recently find that installing the stock springs in a higher hole gave him the clearance needed. It might not work for your application, but costs nothing but time to try.
I did the same as bt on mine - removed 7/8" from the springs (and have them in a higher hole). Also had to removed 5/8' from the air cleaner. Not the simplest approach, but I was going for a vintage speed look and didn't want to use struts.
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
kingkarmann Samba Member
Posted: Tue Dec 22, 2020 8:52 am Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
I too installed struts but kind of wished I did this...
https://www.thesamba.com/vw/classifieds/detail.php?id=1808184 _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
VeloMikey Samba Member
Posted: Tue Dec 22, 2020 10:37 am Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
I just let it rest on the the velocity stack. So far, no harm, no foul. I was going to suggest Gary Bergs solution that Kingkarmann posted.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3815 Location: Georgia
Posted: Tue Dec 22, 2020 10:44 am Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
Not the greatest pictures and the carbs are 45 Dells on a 2276 so I don’t know if what I did will work for your HMPX carbs.
The original air cleaners that came with the carbs interfered with the passenger side hinge only. For a while I just took that one spring off and used a painting pole to prop the lid open when I needed to. On my refresh I wanted a more elegant solution so I ordered short stacks and air cleaner elements.
I may have given up a couple of horsepower but the lid opens and closes as it should with no interference.
I thought about struts but I didn’t want to punch holes in my body.
I never even knew about those weird little aftermarket clips spring things. I’m not even sure how those would work do they just kind of turned backwards and that holds the lid open and then we’ve got to do some finagling to get it closed?
_________________ Volkswagen!
(Compression 8.7:1) |
myghiarocks Samba Member
Joined: June 02, 2009 Posts: 143 Location: DFW area Texas
Posted: Tue Dec 22, 2020 11:23 am Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
jeffrey8164 wrote: |
I also did the same as jeffery8164. probably 25 years ago. never had a probplem since. |
Posted: Wed Dec 23, 2020 5:28 pm Post subject: Re: Trunk hinge problem with EMPI Dual HPMX |
All Members,
Thank you all for the information. I moved the spring to the top hole of the hinges and I barely have enough clearance without hitting the top of air filter especially the passenger side. Just for anyone future reading, I have a 3 1/2 inches tall air filters with 5"ID and 6"OD for 44 HPMX. |
