DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Thu Dec 24, 2020 7:49 am Post subject: What’s your Go to Body Filler(bondo) |
What’s the best out there in terms of adhesion, sandability, strength, etc.
jspbtown Samba Member
Posted: Thu Dec 24, 2020 7:53 am Post subject: Re: What’s your Go to Body Filler(bondo) |
I like the line of Rage products personally. Rage Gold specifically but I am sure there might be better versions. |
67ctbug Samba Member
Posted: Thu Dec 24, 2020 10:55 am Post subject: Re: What’s your Go to Body Filler(bondo) |
I use Rage gold at work, never had a problem. Started using Upol Fantastic at home, also no problems. Rage is wicked money compared to Upol. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Thu Dec 24, 2020 11:42 am Post subject: Re: What’s your Go to Body Filler(bondo) |
67ctbug wrote: |
I use Rage gold at work, never had a problem. Started using Upol Fantastic at home, also no problems. Rage is wicked money compared to Upol. |
I see that my local O’Reillys has Upol Fantastic for about $13 for a quart can. Some reviews I’ve read say this stuff spreads like butter and cuts easy with 120grit vs other products on the market. |
Posted: Thu Dec 24, 2020 2:28 pm Post subject: Re: What’s your Go to Body Filler(bondo) |
DerrickfromNC1 wrote: |
67ctbug wrote: |
After an hr of grinding and a few minutes with the flapper wheel me thinks she is ready for a thin coat of filler.
Bodywork and smoothing panels is not my forte, but I’m hoping a thin coat of filler and careful hand sanding will have this bumper primer ready after the 1st attempt. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4416 Location: Stuck in Ohio
Posted: Sat Jan 09, 2021 9:10 am Post subject: Re: What’s your Go to Body Filler(bondo) |
Looking for a good epoxy highfill primer from a spray can that doesn’t cost over $25/can. A place to buy it over the counter would be nice also....waiting for Amazon even though they are fast is slowing my project down!
Thanks |
Braukuche Samba Member
Posted: Sat Jan 09, 2021 9:42 am Post subject: Re: What’s your Go to Body Filler(bondo) |
Thanks |
Epoxy high build sucks. It gums up paper. Better to use polyester primer as your sandable and then shoot epoxy sealer over it before topcoat.
The days of $25/can primer ended a long time ago... _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
