Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Thu Dec 17, 2020 12:22 pm Post subject: Re: 57 Single Cab repair from Austria |
Nice. Will you come and do mine when you're finished?
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri Dec 25, 2020 6:42 pm Post subject: Re: 57 Single Cab repair from Austria |
I see your ball. Kewl how you saved the headlight bucket grease pens. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Mon Jan 04, 2021 11:03 am Post subject: Re: 57 Single Cab repair from Austria |
The aftermarket door wedges are crap. But you can flip them left to right and get more miles out of them |
Jack-Fatboy Samba Member
Joined: September 28, 2007 Posts: 353 Location: POLAND
Posted: Thu Jan 07, 2021 9:32 am Post subject: Re: 57 Single Cab repair from Austria |
Absolutly TOP level good luck with finishing truck. |
BarryL Samba Member
Posted: Thu Jan 07, 2021 6:46 pm Post subject: Re: 57 Single Cab repair from Austria |
Huetti_1989 wrote: |
The fuel tank hits the side when in right alignment and fully opened, normal? |
Yes and can be bent by over zealous pump-jockey. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Thu Jan 07, 2021 10:02 pm Post subject: Re: 57 Single Cab repair from Austria |
BarryL wrote: |
Also our new fangled primer and paint systems make for a much thicker paint layer.
The thicker paint will fill that tight gas door gap. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2179 Location: Graz, Austria, Europe
Posted: Fri Jan 08, 2021 9:28 am Post subject: Re: 57 Single Cab repair from Austria |
Christian, maybe you can stick some self adhesive, high density foam band on the inside of the gas door, in the gap right next to the hinge. maybe 3-6mm thick. that way the foam will rest against the hinge before the door actually touches the opening ( not opening all the way).
This is what I use, available from Hostra company/ Industrial Rubber and hardware. it is called Zellkautschuk ( natural rubber) and it is water repelling, not soaking and quenching like usual cheap foam.
_________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Mon Jan 11, 2021 11:16 pm Post subject: Re: 57 Single Cab repair from Austria |
j.pickens wrote: |
BarryL wrote: |
The thicker paint will fill that tight gas door gap. |
djfordmanjack wrote: |
Now i adjust it a little bit out and realized that it don´t hit the side, it is tight but it worked, i want to keep it like factory, so it it would hit someday, no matter. thanks.
I built a extra wiring harness for the extra flashers front and rear and emergency switch as i need for legal street registration, i hope it works. I want to keep the old little Semaphore switch to control them.
Also cleaned the wiper engine and the Hardware.
-Christian
_________________ My 1957 semaphore Single Cab:
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1954 Deutsche Bundespost Barndoor:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34 Flipseat Westfalia:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751 |
Tvättbjörn Samba Member
Posted: Tue Jan 12, 2021 12:24 am Post subject: Re: 57 Single Cab repair from Austria |
Lot of cutting.....
But i found a new cutting Tool (only a hobby tool) what can cut really exact and without bend the panels.
-Christian
How is your Blechnippler holding up after all that use? Do you have a model number ?
thanks |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Jan 12, 2021 7:32 am Post subject: Re: 57 Single Cab repair from Austria |
Tvättbjörn wrote: |
thanks |
you mean NIBBLER? Nipple needs a completely different set of tools _________________ regards
Uli
Posted: Tue Jan 12, 2021 11:58 am Post subject: Re: 57 Single Cab repair from Austria |
Did you get approvwl from Dr Best to use your toothbrush that way? |
V-Dub Guy Samba Member
Posted: Thu Jan 14, 2021 5:56 am Post subject: Re: 57 Single Cab repair from Austria |
This is all the fun stuff now...like putting jewelry! Looking very nice.
I see light at the end of the tunnel...keep it up |
