mickey12 Samba Member
Joined: August 22, 2015 Posts: 80 Location: Kansas City
Posted: Sun Jan 10, 2021 2:51 pm Post subject: Kennedy Stage 1 Pressure Plate |
I have a Type 1 2021cc DP engine with a Kennedy Stage 1 Pressure Plate. I want to attach it to an early style transaxle w/older throw-out-bearing. I've read a lot of conflicting information.
Can I just get an early style T/O bearing pressure ring for the Kennedy PP and slide it on?
Do I need to remove the old cross shaft and replace it with a heavy duty one, with a new style throw-out bearing?
See pressure plate and throw-out-bearing
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
Posted: Sun Jan 10, 2021 3:10 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
You just need the ring that goes on the PP fingers. I'm not sure if you can buy them separately or not but you could email Kennedy and check with them.
Maybe someone on here has one they can part with. _________________
| richardcraineum wrote: |
| I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
| cbeck wrote: |
| His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Sun Jan 10, 2021 3:25 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
I think this will work from Dune Buggy Supply?
Throwout Bearing Guide Sleeve
For 1971-1979 Type 1 &
Type 2 - 113-141-181B
$3.99 |
modok Samba Member
Joined: October 30, 2009 Posts: 27750 Location: Colorado Springs
Posted: Sun Jan 10, 2021 3:28 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
| Forgot to say that the transaxle is on a 1968 Type 1, if that matters. |
Posted: Sun Jan 10, 2021 4:56 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
What Modok posted a link to is what you will need for your transmission.
If that is an original German throwout bearing.....it might be a little dry inside.
Gently remove the cover in back and you can repack that bearing for another long life. _________________
| cbeck wrote: |
Audi TT intercooler
EcuMaster PMU16
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80325 Location: Sneaking up behind you
Posted: Sun Jan 10, 2021 5:10 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
| modok wrote: |
| it is "possible" to install a late throwout bearing into the trans, but it's a PITA would not recommend. |
If the casting has the 3 bosses for the mounting studs, it's just a matter of marking the location and drill/tap the holes. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
modok Samba Member
Posted: Sun Jan 10, 2021 5:13 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
Agreed.
Tho if his trans is actually 1968 model, that's before it had the bosses. |
Glenn  Mr. 010
Posted: Sun Jan 10, 2021 5:19 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
| modok wrote: |
Agreed.
Checked his gallery, there's a picture of a swingaxle, so correct as usual King Friday. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun Jan 10, 2021 6:07 pm Post subject: Re: Kennedy Stage 1 Pressure Plate |
| thank you, thank you, thank you!!!!!!!!! |
