buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sat Jan 09, 2021 9:35 pm Post subject: Running braided steel fuel lines in the tunnel |
Is there room in the tunnel to run a pair of -6 AN stainless braided fuel line through it? I've never been inside a tunnel to see how much room there is. I recently took mine off that i had run along the bottom of the car to freshen up the pan and I'd like to put them where they would be better protected than the bottom of my slammed car. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
buguy Samba Member
Posted: Sat Jan 09, 2021 10:07 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
I wouldn't mind cutting a window in the tunnel in a couple spots if needed (then reweld) to attach a clamp.
That's where i had these ran under the car. I have $650,000 in fittings in braided line, not going to change it to hard line now. I actually started with hard line but didn't like the way it was bending for how i wanted it, so then i got the braided. |
buguy Samba Member
Posted: Sat Jan 09, 2021 11:24 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
No the stock one was too small so I'm running 2 new ones. I run E85 and boost. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Sun Jan 10, 2021 6:22 am Post subject: Re: Running braided steel fuel lines in the tunnel |
Is the body off the pan? If so, you could remove the bottom plate and have full access.
Mine are run within the channel where the pan bolts are.
Another option would be to run them inside and you could tuck them along the pan where it connects to the heater channel. There’s a small pocket there |
buguy Samba Member
Posted: Sun Jan 10, 2021 6:54 am Post subject: Re: Running braided steel fuel lines in the tunnel |
No it's not off the pan. When i built this car i didn't take it off the pan and i didn't touch the under side. So the other day i put it on the lift, did some blasting and painting, and now ready to put the fuel lines back on, intercooler water lines, radiator and fan... Etc. I broke an axle, so i figured while the engine and trans are out, i would do some of this stuff. I'd like to also replace all the brake line while everything is exposed.
Where i ran the fuel line i had to run it up under the tank and where it turns to go up, the car is pretty low there. Looks to be an easy spot to hit the ground or if i run over something it could make a mess. So if i could run it in the tunnel that would be best. I don't really want to run the line inside the car if i don't have to. With EFI and all the extra wiring it takes up more of those side areas near the heater channel.
I also don't want to be rattling in the tunnel or getting in the way of the shift rod. So, if needed i will make a couple cuts in the tunnel so i can get some clamps in there. I just didn't want to rip my carpet up (it's glued down and surely will have to be replaced) and cut the tunnel if there wasn't room in there for the lines. |
txoval Samba Member
buguy Samba Member
Posted: Sun Jan 10, 2021 8:26 am Post subject: Re: Running braided steel fuel lines in the tunnel |
Thanks man that helps a lot! Looks like there is a brace up front I'm going to have to notch out to run them from front to back. I can't tell for sure from the pics, but it doesn't appear to have enough space under that brace to run them. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Sun Jan 10, 2021 8:50 am Post subject: Re: Running braided steel fuel lines in the tunnel |
I put a 5/16ths line through the tunnel with some wire harness spiral wrap on it. It fit under the brace. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
buguy Samba Member
Posted: Sun Jan 10, 2021 8:54 am Post subject: Re: Running braided steel fuel lines in the tunnel |
Perfect. Thanks clone. This stuff is pretty big with the ends on it already. I'm hoping i don't have to pull them back off to get it through! I didn't enjoy putting them on the first time. |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Sun Jan 10, 2021 1:53 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
I’ve got two -8 braided lines in the tunnel. _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
buguy Samba Member
Posted: Sun Jan 10, 2021 3:06 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
Any advice/things to look out for? |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6033 Location: CONGERS, N.Y.
Posted: Sun Jan 10, 2021 3:30 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
I have had brake and fuel lines brake in my tunnel. Not fun smelling gas and not knowing were it was coming from until after a week of driving it finally dripped out the bottom of the tunnel.
Also had my brake line corrode along side the tunnel because what it was stock the line was on the floor and rotted out. My leg got wet from the spay.
Both are raised above the floor, so they can't get wet.
I like seeing them!!! They have been in that location for 30 years.
Yes I have a fire extinguisher, just in case.
_________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
buguy Samba Member
Posted: Sun Jan 10, 2021 4:30 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
Understandable. But i have carpet and ptfe lined hose. Not saying it can't fail, but less likely. |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Sun Jan 10, 2021 5:11 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
I used 3/8 stainless hard line mounted to the passenger side inside the tunnel, I used hydraulic blocks welded in place to secure the lines. I had bottom plate off the tunnel to do it though. |
buguy Samba Member
Posted: Sun Jan 10, 2021 5:19 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
This is the area of concern. I was going to just make a skid plate for it, but i feel like moving it is a safer and cleaner install. Pic 2 is where i had it ran. It was tucked up in there pretty well along the car. Over the torsion and the area in pic 1 not so much.
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Sun Jan 10, 2021 5:38 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
There’s not a braided or soft fuel line made besides nylon that modern fuel will not eat through in a few years.
Routing soft PTFE through the tunnel would be the height of shortsightedness. _________________ 1970 Turbo Baja Bug Turbaja 2165 t3/t4 Speeduino sequential EFI LS3 coil on plug ignition
1965 Chevy c30, Microsquirt turbo aluminum 5.3/nv4500 |
Posted: Sun Jan 10, 2021 5:58 pm Post subject: Re: Running braided steel fuel lines in the tunnel |
Under the bug, no way, two many things can happen. Skid plates are not liquids proof. Also we always hit things we do not expect, Rocks, gravel, tree branches, stuff falling off the truck in front of you.
Anything can cause it and you are stranded pouring out gallons of gasoline, on a road way or parking lot of driveway.
How will you stop gas from coming out the broken line. When redoing my rubber hose to the carbs, I left a hose clamp off. I drove one city block and smelled gas. Shut the car and saw gas pouring out under the car. I lost 3 gallons before I could get to a Vice Grip to cut off the supply. Do you have a plan if that happens to your stainless lines ? Not a happy scenario. Not to mention you are now stranded. _________________ email: [email protected]
