Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Sat Jan 09, 2021 12:17 pm Post subject: Question about using a roller bending machine |
Hello dear forum members and a "Happy New Year!".
I have decided to post this non-VW question here, because I could not find any answer on the internet and I do not know anybody with any experience working such machines and hopefully some of you do.
I have decided to build myself some sort of semi-portable car-shelter out of metal arches and a fabric covering. As such, I have attempted to bend the arches out of 3/4 inches round tube using a hand operated roller bender. It was my first time ever. I have purchased the bender a year ago, but never used it
As such, my first attempt ended in disappointment. As the arch was created the pipe started to twist no matter how much I have tried to guide it by hand. In the end I have ended with something that resembled a section of a coiled spring.
Does anybody know how can I prevent this from happening? As in to make a proper "straight" arch?
Thank you.
Photo of my "twisted" arch:
Photos of the roller bender i have used:
_________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5501 Location: 1st Coast
Posted: Sat Jan 09, 2021 7:03 pm Post subject: Re: Question about using a roller bending machine |
c21darrel, I've seen yours and I haven't made mine yet, I may in the spring. I don't know how the hundreds of pounds of wet ice and snow kept mine form caving in.
c21darrel wrote: |
Perhaps not the reply you seek...
I dont think you will find any fabric that will last more than a couple years at best. I used one of the Costco car garages, when the fabric was toast, I used corrugated metal roof. 7 years trouble free. These frames are all over, i picked up 2 for free, they just wanted it gone.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Sat Jan 09, 2021 8:47 pm Post subject: Re: Question about using a roller bending machine |
Well, having some experience with roller benders, the primary cause of your failure is not having the correct dies for the machine. You must have the proper shape and size for the size tubing you want to use. Those dies that you have in there now are generic and are only meant to curve very short lengths of conduit type metal, not heavier gauge steels. If there is any slop side to side, you're going to get a spring shape.
The only way to work with what you have now is to do it with three people - two to hold the infeed and outfeed perfectly straight as a third person spins the wheel and applies the pressure. Even then, you will likely have issues. |
Posted: Sat Jan 09, 2021 11:35 pm Post subject: Re: Question about using a roller bending machine |
Letterman7 -> Thank you for your input. Unfortunately these are the dies I have to work with. I will try getting one or two friends to help me out with keeping the pipe straight.
Any advice regarding how I can ameliorate the problem by doing (or not doing) certain things when bending? Such as start position, going both directions or just only one direction and manually re-setting the pipe (and using some indexing marks) for the other pass?
Now, about the fabric cover itself, i know it is not the most ideal thing, but there are situations when you cannot use anything more than that or else it might start to look like a garage or some sort of shed, and it might be inappropriate in the eyes of some people _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
Posted: Sun Jan 10, 2021 7:43 am Post subject: Re: Question about using a roller bending machine |
So funny, you kill me c21darre teaspoons of snow, the best! I'm visualizing it now.
I would move back to my native SoCal in a heartbeat but unfortunately that will lead to divorce.
c21darrel wrote: |
lol, in SoCal the snowfall is measured in teaspoons. |
Maui Roadsters
Lind wrote: |
Posted: Sun Jan 10, 2021 7:37 pm Post subject: Re: Question about using a roller bending machine |
Komissar wrote: |
Now, about the fabric cover itself, i know it is not the most ideal thing, but there are situations when you cannot use anything more than that or else it might start to look like a garage or some sort of shed, and it might be inappropriate in the eyes of some people |
Tough call. It all depends if you're trying to do a full arch or just corners. If you minimize the length, you'll minimize the errors. Personally, I wouldn't try to do a full arch - I'd roll "corners" as best as I could, then weld those onto straight pieces. Otherwise, start in the middle, add a little pressure, then go both directions about a foot at a time, going outwards each time before you add more pressure. If you can build some sort of boxed "slot" to help contain the pipe as far out on either side as you can (make it as tight as possible to the pipe, even to the point that it's touching the pipe), you might be able to keep it straight(er) with one person. Alternately... look for someone in your area that has an exhaust pipe bender that you can pay for them to turn the tubes for you. |
modok Samba Member
Joined: October 30, 2009 Posts: 26743 Location: Colorado Springs
Posted: Sun Jan 10, 2021 8:00 pm Post subject: Re: Question about using a roller bending machine |
Perhaps you could purchase conduit or muffler tubing the right size for the dies it has. |
vwsplitman Samba Member
Joined: June 18, 2003 Posts: 322 Location: Plymouth, CT
Posted: Tue Jan 12, 2021 3:27 pm Post subject: Re: Question about using a roller bending machine |
Speaking of tarps or covers, I purchased a long time ago(25 years) some vinyl signs used on billboards. These were huge when opened up. Able to cut them with scissors and out of one piece got 6 that would each cover a VW bug easily. Used them thru the years for car covers, firewood covers, engine and tranny covers. None have any damage as far as shreading, holes, ripping etc. I notice there is a company that has periodic ads on Facebook with a similiar product. A little more costly than the cheap tarps, but will last forever. They even have grommets around the perimeter for tie downs. Just a thought. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jan 12, 2021 4:37 pm Post subject: Re: Question about using a roller bending machine |
When the twisting happens does it always go the same way? (to the right for example?), it could be as simple as shimming one of the rollers to one side with washers a little. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4897 Location: Southern AB
Posted: Tue Jan 12, 2021 4:52 pm Post subject: Re: Question about using a roller bending machine |
We have 2 home made frames for our car storage, and we've been storing cars in them for 15 or so years. Heavy duty vinyl tarps last between 3-5 years. I switched them both to PVC last year , we'll see if they get a longer life.
The biggest killer is the sun, it degrades the tarp until you can see the coating start to flake off, then you have a limited time to change it before the wind rips it to shreds. Supposed to get 80-120km winds tomorrow, never a problem, but the tarps are pulled tight and screwed down under some aluminum 3/4" angle strips _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2065 Location: Bulli Klinik, Colorado Springs
Posted: Tue Jan 12, 2021 4:58 pm Post subject: Re: Question about using a roller bending machine |
You can build a metal or wooden guide to keep the pipe going in and coming out of the roller. Think of it as sandwiching the arcing pipe. Or just do it very carefully with a friend on the other end. I’m familiar with the problem. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Wed Jan 13, 2021 4:15 pm Post subject: Re: Question about using a roller bending machine |
c21darrel wrote: |
Rain weight accumulating in the tarp will collapse the tubing! BTDT _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Fri Jan 22, 2021 3:25 am Post subject: Re: Question about using a roller bending machine |
Managed to finish my temporary car cover.
In the end I have used Letterman7's suggestion of using only rounded smaller sections as corners for the frame.
I have also made a video of it and how it fits over my VW Type 3.
I have designed and tested it with a full canvas cover, in case I need to store the car during a rainy period, but usually I will used the shelter with a smaller tarp covering the roof only.
https://www.youtube.com/watch?v=fNCm_KZdotw _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
calvinater Samba Member
Posted: Fri Jan 22, 2021 4:36 am Post subject: Re: Question about using a roller bending machine |
Nice video , hope you do not get a lot of snow, that roof tarp will sag , being flat like that. _________________ "Albatross"! |
Posted: Fri Jan 22, 2021 6:02 am Post subject: Re: Question about using a roller bending machine |
Nice job! |
Posted: Sun Jan 24, 2021 7:34 am Post subject: Re: Question about using a roller bending machine |
calvinater wrote: |
Nice video , hope you do not get a lot of snow, that roof tarp will sag , being flat like that. |
Hy, thanks for liking the video and the car shelter.
Although I do hope that the snow will not be so severe, I did account for rainfall and light snow by not putting any horizontal rails between the upper corners of the main sections comprising the frame. Thus, the canvas is only supported by the horizontal "backbone" in the middle, but the laterals drop down in between the frame sections, and thus any water will go down to the sides (and hopefully some snow as well). _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
