av8shunmeckaneck Samba Member
Posted: Tue Jan 12, 2021 3:36 am Post subject: Soft top frame pivot bushings |
I've had this idea for a long time to have a bushing that keeps the hoop and the rest of the frame together during top removal. Not sure if any body makes something like this already. Didn't see one on TTS.
Enjoy.
Last edited by av8shunmeckaneck on Tue Jan 12, 2021 10:09 pm; edited 1 time in total |
Joe 20 Samba Member
Posted: Tue Jan 12, 2021 8:14 pm Post subject: Re: Soft top frame pivot bushings |
I don't know if I understand what you are talking about but mine doesn't come apart. The parts are supposed to stay together aren't they? It is a real nice piece you made I guess to replace the "factory" piece? _________________ "Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy |
74 Thing Samba Member
Posted: Tue Jan 12, 2021 10:17 pm Post subject: Re: Soft top frame pivot bushings |
My pins just behind the rear doors are spot welded to the tab. Are they supposed to be welded to the frame? I could see if they were welded to the main portion of the top frame, pointing inward, the tension of the hoop could hold it on the pins.
el_safari Samba Member
Joined: January 01, 2005 Posts: 375 Location: Nouvelle Aquitaine,France
Posted: Wed Jan 13, 2021 5:48 am Post subject: Re: Soft top frame pivot bushings |
av8shunmeckaneck wrote: |
Enjoy.
Hi Great idea!
Did you make your own?
Quite often the parts of the top frame are bent and it will be then easy to work on them _________________ La terre n'est qu'un seul pays |
Dougster43 Samba Member
Posted: Wed Jan 13, 2021 1:07 pm Post subject: Re: Soft top frame pivot bushings |
My pivot pins were spot welded in as well. I had to use a cutoff wheel to remove them. I then drilled a few small holes in back of the replacement pins (in the flat back part) for welding them back on. |
kenj06 Samba Member
Posted: Wed Jan 13, 2021 6:00 pm Post subject: Re: Soft top frame pivot bushings |
interesting idea. Never really paid attention but I have bolts on mine, no pin.
I haven't removed the top that often but may start when I have the hardtop ready to go. |
Posted: Wed Jan 13, 2021 11:05 pm Post subject: Re: Soft top frame pivot bushings |
Hi Great idea!
Quite often the parts of the top frame are bent and it will be then easy to work on them [/quote]
Yes, I made these myself.
-kenj06,
I too don't take the top off very often, but when I do, its a massive pain with the hoop flopping about. Its usually to transport plywood or long/large items.
P.S.< Last night I put the top back on myself and it wasn't too bad. |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Fri Jan 15, 2021 12:24 pm Post subject: Re: Soft top frame pivot bushings |
How much extra exertion do you have to apply to "stretch" the frame over the pins? The frame is already prone to bends and weaknesses (cracking). I like the design. Also, do you have to drill out the frame to accept the new bushing (adding further weakness)? When I remove my top (cue the innuendos), I put a "zip tie" to keep the frame parts from going all dangerously floppy. A little R&D and some QC field testing...I'm following... _________________ "I haven't seen one of those since I was shootin' at 'em!" |
THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Mon Jan 18, 2021 11:07 pm Post subject: Re: Soft top frame pivot bushings |
Nice! I like it |
Posted: Fri Jan 29, 2021 10:09 pm Post subject: Re: Soft top frame pivot bushings |
Rev. Scott wrote: |
How much extra exertion do you have to apply to "stretch" the frame over the pins? The frame is already prone to bends and weaknesses (cracking). I like the design. Also, do you have to drill out the frame to accept the new bushing (adding further weakness)? When I remove my top (cue the innuendos), I put a "zip tie" to keep the frame parts from going all dangerously floppy. A little R&D and some QC field testing...I'm following... |
Nothing extraneous to expand the frame over the pins. My frame sits on the pins without squeezing them or trying to spread open.
Still not clear if the pins are supposed to be welded in or not but in any case it works better to have them welded in. |
BNMike Samba Member
Joined: November 12, 2009 Posts: 333 Location: Hot Springs, SD
Posted: Sun Jan 31, 2021 7:44 am Post subject: Re: Soft top frame pivot bushings |
My top attachment pins are welded on, and as I recall they were permanent on the '73 that I had new.
BNMike |
