fast86gn Samba Member
Posted: Thu Jan 14, 2021 3:33 pm Post subject: Generator stand gasket |
I forgot to order a gasket for the generator stand. Can I use a thin layer of rtv sealant or should I wait and order the gasket? Thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Thu Jan 14, 2021 3:35 pm Post subject: Re: Generator stand gasket |
Don't use silicone, if it get in the oil it can block a oil passage and cause engine failure. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Jan 14, 2021 3:36 pm Post subject: Re: Generator stand gasket |
Thank you |
jsturtlebuggy Samba Member
Posted: Thu Jan 14, 2021 3:59 pm Post subject: Re: Generator stand gasket |
Are you using the metal baffle between stand and case?
If so, you don’t use any gaskets, just some sealant, not silicone. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Glenn Mr. 010
Posted: Thu Jan 14, 2021 4:37 pm Post subject: Re: Generator stand gasket |
jsturtlebuggy wrote: |
If so, you don’t use any gaskets, just some sealant, not silicone. |
Sorry but you still use a paper gasket above and below the metal baffle.
Member #1009
#BlueSquare |
Posted: Thu Jan 14, 2021 7:09 pm Post subject: Re: Generator stand gasket |
Don’t be sorry , you are just looking at old picture. The metal baffle changed from a flat to a raised ridge around the outside and that is used as the seal.
It the same idea with stock dual port intake gaskets.
VW did this change as the paper gaskets break over time from normal engine vibrations.
I have been building VW engine since around 1973 and remember seeing the factory bulletin when this change happened. _________________ Joseph
Elrod Motorsports
Glenn Mr. 010
Posted: Thu Jan 14, 2021 7:35 pm Post subject: Re: Generator stand gasket |
Then why are the gaskets till included? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Jan 14, 2021 8:50 pm Post subject: Re: Generator stand gasket |
Gasket kits have included many items not always used on later engines. For many years there was seals included for the long rocker studs used only early 40hp and 1500cc heads long after they stop being used.
I would bet if your friend Russ (RIP) was still alive and told you the same thing you would believe him.
Do you still use the paper gaskets for the cylinders base? There in the kits too. _________________ Joseph
Elrod Motorsports
Glenn Mr. 010
Posted: Fri Jan 15, 2021 6:59 am Post subject: Re: Generator stand gasket |
I build an engine or two a year and never had a leak from there so i'll continue to do what works... for me. _________________ Glenn
Member #1009
#BlueSquare |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri Jan 15, 2021 7:59 am Post subject: Re: Generator stand gasket |
Yes you can use RTV. Different people have different opinions. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Fri Jan 15, 2021 10:02 am Post subject: Re: Generator stand gasket |
You do what you want Glenn, from my experience of building many engines that at the time period being used as daily drivers you did every thing you could to stop oil leaks. After you seen so many generator stands leaking from broken gaskets, when the new improved baffle plate came out you stopped worrying about having and oil leak start there.
And if look you may find others out there that agree with me and remember why the new improved baffle came with the sealing ridge around the edge just like stock dual port intake gaskets. _________________ Joseph
Elrod Motorsports
Glenn Mr. 010
Posted: Fri Jan 15, 2021 10:04 am Post subject: Re: Generator stand gasket |
My engines don't leak.. .and I sleep well at night.
Whatever works for you. _________________ Glenn
Member #1009
#BlueSquare |
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Fri Jan 15, 2021 3:26 pm Post subject: Re: Generator stand gasket |
Actually for the first time in several engine builds I did use the paper gaskets that go between the cylinders and the case. I needed .003" to make a .040" deck height so on they went! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Glenn Mr. 010
Posted: Fri Jan 15, 2021 3:41 pm Post subject: Re: Generator stand gasket |
Many feel that paper intake gaskets are better at sealing than the OE metal one on stock engines. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jan 15, 2021 4:57 pm Post subject: Re: Generator stand gasket |
I can say the same thing about the metal gaskets that many like to use them.
It is really hard to outsmart VW engineers and what they came up with to use. _________________ Joseph
Elrod Motorsports
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Fri Jan 15, 2021 8:11 pm Post subject: Re: Generator stand gasket |
Install'd a new alternator stand just today. Used the metal gasket with ridge, sandwitch'd between paper gaskets. Not worried about oil leaks, but how will I ever know firing order!!
EVfun Samba Member
Posted: Fri Jan 15, 2021 11:24 pm Post subject: Re: Generator stand gasket |
MrGoodtunes wrote: |
You could stamp 4 3 2 1 on it. _________________
Wildthings wrote: |
Posted: Sun Jan 17, 2021 2:20 am Post subject: Re: Generator stand gasket |
Mr Goodtunes, with using a H5 engine you have more chances of oil leaking from cracks in case other then worry of your generator/alternator stand.
Air cooled.net, JBugs,and Kustom1 Warehouse in there online catalogs all say you do not need gaskets with oil baffle/defector that has the raised edge, just good sealant _________________ Joseph
Elrod Motorsports
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Mon Jan 18, 2021 9:53 pm Post subject: Re: Generator stand gasket |
The Mexican Alt stand has an o-ring seal on the bottom....it's a nice upgrade and quite reasonable since most originals have fillers that are rusted out. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Jan 21, 2021 9:54 pm Post subject: Re: Generator stand gasket |
EVfun wrote: |
You could stamp 4 3 2 1 on it. |
Ask Zundfolge. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
