Emergency break question
bobbysheets
bobbysheets is offline
PostPosted: Sat Jan 16, 2021 3:09 pm    Post subject: Emergency break question Reply with quote
Does anyone know what size pin or have a part number for the pin that goes into the emergency brake to hold the handle shaft and the upright arm together? I have a Bentley and it named the part but not a part number. I looked up the part without any luck. TIA
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jan 16, 2021 4:35 pm    Post subject: Re: Emergency break question Reply with quote
almost every product sold that was designed to be serviced has parts manuals and fiches that show parts. Learn how to use them if you will be owning a 50 year old VW bus. There are different parts for different years so not every year uses the same part, although I suspect that part is common between years. Here are some links to such sites online. The part you probably want is on fiche page 58 and is likely part #20 which is N 013 239 1. You also need part number 21 to hold it. Next, if a part number is not in the fiche it is because VW discontinued it a long time ago. They remove numbers when the part is discontinued, so sometimes you have to look at older models to see if they show the part when earlier copies of the parts manuals were printed. Last, learn who the folks are who sell good quality used parts. Many times you can give them a description of the part and they can get it for you. I like using classified here on the Samba, Ken Madsen at TheBusco, Chris at BustedBus, Avery's Air Cooled, and Interstate VW parts in Lake Elsinore CA.
Here are links to fiches. Learn to use them.
Click on part to see parts number on this site. Mostly late bays:
http://www.michaelknappmann.de/bulli/michaelk/vw_bus_d/fiche/t200100.html
http://www.jerseylooker.com/FicheDump/LateBaywindow/LateBay-Main.html
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-Main.html
American Standard Snorkeling Terrier
Preserve YOUR Freedom of Speech ~ as best you can, avoid Amazon, Facebook, Twitter, and Google. Support businesses near you, and buy local whenever you can.
airschooled Premium Member
Air-Schooled
airschooled is offline
PostPosted: Sat Jan 16, 2021 5:12 pm    Post subject: Re: Emergency break question Reply with quote
I Google'd "VW bus handbrake pin" and the number one result was:
https://www.mtmfg.com/part/view/emergency-brake-le...0AQAvD_BwE
Learn to fix your vintage Volkswagen.
www.airschooled.com
Knowledge. Confidence. Reliability.
SGKent is offline
PostPosted: Sat Jan 16, 2021 9:46 pm    Post subject: Re: Emergency break question Reply with quote
Robbie - that may be the one that the bracket lever swivels on instead of the pull rod to bracket lever. Part number #10. I think he wants item #20.
http://www.michaelknappmann.de/bulli/michaelk/vw_bus_d/fiche/t205800.html
Air-Schooled
PostPosted: Sun Jan 17, 2021 12:06 am    Post subject: Re: Emergency break question Reply with quote
Oops- yes! Second result Wink
https://www.ebay.com/itm/Empi-98-6118-Anchor-Pin-P...867f240966
www.airschooled.com
timvw7476
timvw7476 is offline
PostPosted: Sun Jan 17, 2021 1:15 am    Post subject: Re: Emergency break question Reply with quote
[quote="airschooled"]Oops- yes! Second result Wink
^ that may be the anchor pin for the pivot arm at the shoe, held by the horseshoe clamp. The one up above has a groove on each side for a retainer & is larger
IIRCC.?
kreemoweet
kreemoweet is offline
PostPosted: Sun Jan 17, 2021 2:00 am    Post subject: Re: Emergency break question Reply with quote
Why is it that so many bus owners asking about parts here fail to even mention what model year they have?
Are they under the impression that all busses and parts were the same?
It seems the part in question is #N 13 239 1 for 68-71 bus, held in place with cotter pin and washer, and
#N 23 500 1 for '72 (and later?) bus, held in place with 6 mm "safety clip" #N 23 624 1.
'67 bug: seized by the authorities
bobbysheets
PostPosted: Sun Jan 17, 2021 4:09 am    Post subject: Re: Emergency break question Reply with quote
Iím sorry I failed to add that my bus is a 74í and that I wasnít aware of this fiche parts list. The part I was googling is called a ratchet rod pin not the lower pin held in by two e-clips. Thanks for the feedback and help. Iíll be sure to do more searching before I ask for help next time.
Rolling Eyes
SGKent is offline
PostPosted: Sun Jan 17, 2021 8:24 am    Post subject: Re: Emergency break question Reply with quote
Rolling Eyes
It isn't that we are mean and demand you do more searching. It is trying to give owners the tools to be successful with their bus. 40 years ago they could walk into a dealer and order the part. Today, a lot of times it is often whether you can be successful finding a specific part - or a picture of how it is supposed to be put together. Same for a repair. Most of us find that we often spend more time trying to find a GOOD part than doing the actual repair - especially when we are just starting out.
kreemoweet
PostPosted: Sun Jan 17, 2021 10:41 am    Post subject: Re: Emergency break question Reply with quote
The early and late parts are very similar. Probably a hardware store 5/16 clevis pin, perhaps
modified a bit, would work in all.
Wildthings
Wildthings is offline
PostPosted: Sun Jan 17, 2021 10:08 pm    Post subject: Re: Emergency break question Reply with quote
Lots of foreign made tractors are sold in this country and I would bet more than one of them uses a pin that would work here. A local place that sells and/or repairs farm equipment might be able to help you out.
