OldBlueSyncro Samba Member
Joined: April 24, 2018 Posts: 196 Location: British Columbia
Posted: Tue Apr 09, 2019 8:37 am Post subject: GoWesty's Transaxle Plug with Temp Sensor |
Has anyone used GoWesty's transaxle plug with a temp sensor?
https://www.gowesty.com/product/manual/24646/fill-plug-for-transaxle
I was thinking of putting one in it'd be nice to keep the magnet too. Would I still get a similar reading if I used the temp senor in the fill plug? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 14062 Location: Palm Beach County, Florida
Posted: Tue Apr 09, 2019 9:32 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
They are selling it as a “fill plug” Do you have the 4th gear oil plate installed? If so, there may not be enough room for the temp sender. Probably not an issue though. I have to imagine there’s a pretty good hurricane going on in there and the sender is bound to pick up temp. Might not be as accurate submerged, but you are looking for consistency. Plus at some point, the sender may be reading case temp once the heat has saturated. _________________ 1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q |
Posted: Tue Apr 09, 2019 9:46 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
MarkWard wrote: |
They are selling it as a “fill plug” Do you have the 4th gear oil plate installed? If so, there may not be enough room for the temp sender. Probably not an issue though. I have to imagine there’s a pretty good hurricane going on in there and the sender is bound to pick up temp. Might not be as accurate submerged, but you are looking for consistency. Plus at some point, the sender may be reading case temp once the heat has saturated. |
I didn't even pick up on the fact that it's being sold as a fill plug haha. No oil plate installed that I know of. I can stick my finger in the fill hole a good ways so I imagine I don't have an oil plate in there. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 6383 Location: Western WA
Posted: Tue Apr 09, 2019 10:22 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
If your finger doesn't hit a "wall" you don't have oil plates. Oil plates are a good thing, a well known "passive" gearbox lubrication enhancement.
The left pic you can see a drain plug magnet inserted into the filler plug hole. The temperature sensor would be here, but due to the bushing stackup, it would protrude into the gearbox much LESS than the magnet does.
Incidentally, oiling plates completely block the oil thrown by 4th gear from hitting the sensor. The sensor won't have hot oil "thrown at it". This is not a problem, just a 'note'. The sensor would be reporting an average of the inside air/oil vapor temperature, and the transmission case temperature. Most of the time there will be little difference between oil temp, inside air temp, and case temp. Basically the GW filler plug bushing is a super-easy way to add a temperature sender to your transaxle.
Vanagon owners who may be interested in transaxle temp are those with:
1) Big engine
2) drive fast (like 70+)
3) drive heavy
4) old trans
5) 5.43 or 6.17 gears
6) big tires
7) lubricant contaminated by steel dust, bits, bad stuff
8 ) oxidized lubricant (turned black)
9) a smokin' checkbook
If you don't have any of these, the normal transaxle temp of 140-150°F may not interest you much, and it shouldn't. It's actually GOOD news. Take care of that cool running trans and keep it lubed or #9 comes sooner! If your trans is getting hot you should at least change your oil,,,, and slow down too. _________________
EJ25, Peloquin diff, locker, transaxle oil cooler/filtration system
....KTMs, GasGas, and a Stumpjumper
Gear oil is like underwear.
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 2863 Location: VA/TN
Sodo Samba Member
Posted: Tue Apr 09, 2019 11:07 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
GoWesty is more for the filler plug, but of course it works on the drain plug too. But as a drain plug bushing it would delete the super-important magnet.)
I'd go Boxeer for sure. Them you are measuring oil temp AND you have a neodymium magnet.
Boxeer seems to be relying on their reputation and engineering expertise, and don't appear to understand that relatively few people are aware of those traits they offer the Vanagon customer.....
Boxeer needs some sales help.
This is a classical problem with engineers tasked with all the complications of creation, production, business, and "sales".
Which can be a mixed blessing - because as a small business they may be unable to supply the volumes that better salesmanship would provide....
There's never enough time in a day, or enough quality help.
Well anyway here's a few important details lacking from their sales pitch.
They could easily tell everyone these details directly on their website for "free" (and 24/7/365 )
rather than wait for some transaxle obsessed forum nut to put on a Boxeer hat.
Missing from Boxeer sales pitch:
-point out the neodymium ring magnet.
-tell you the thread specification (of the sensor hole).
-show you a pic of exactly what you will receive which is ONLY a bushing (with the magnet)
Leave 1 or 2 questions unanswered and the customer buys "nothing".
Answer all questions?
^^This results in <add to cart> (24/7/365)
They could to show a pic of the Bosch® guage kit that they recommend.
They showing that the gauge kit includes the sensor that fits their product.
Better yet, they should simply stock and sell the guage, even if they had to buy it from Amazon for $22. Make up a 100% kit that leaves zero guesswork and 100% confidence for the customer.
Unless I've made a mistake...... (But I'm not a Boxeer rep, I'm just a forum guy)
Here's what you get from Amazon for $22. The adapters are 1/4", 3/8" and 1/2" (not used). Nobody cares if it's $22 or $40. If Boxeer offerred that gauge kit for $40 people will happily <add to cart> even those who know it's $22 on Amazon. The "certainty" that it will bolt onto your van is worth $18 more.
Anyway I bet they're too busy to deal with small things like this. But its only a few minutes work, and it sells 24/7/365 "for free". _________________
Posted: Tue Apr 09, 2019 11:14 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
The gowesty is used in conjection with this temp sensor.
https://www.gowesty.com/product/electrical/22241/oil-temp-sender?v=
The Boxeer one looks like it might be difficult to use a socket to remove the plug with the temp sensor still installed. It's also a little pricey for just the plug. It says the senor isn't included. |
Sodo Samba Member
Posted: Tue Apr 09, 2019 11:22 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
On second thought I can't really say for sure which is better.
The GW filler plug adapter is $16
and the Boxeer drain magnet adapter is $65.
They are kind of "different".
I bet the temperatures registered:
....of transaxle air temp (GW)
.vs.
...oil sump temp (Boxeer)
would be appx the same. _________________
Gear oil is like underwear. |
Posted: Tue Apr 09, 2019 12:22 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
A buddy has the boxeer one in the filler location. I think something in his ej25 conversion kit is blocking the way.
He also jacked his van up on passenger side to overfill the trans to get a more accurate reading. _________________ Brandon
"Jo Ann" - 1983.5 Ivory Westfalia 1.9L 2wd |
Sodo Samba Member
Posted: Tue Apr 09, 2019 1:18 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
shagginwagon83 wrote: |
He also jacked his van up on passenger side to overfill the trans to get a more accurate reading. |
If he has the Smallcar bellhousing, Smallcar uses a different drain plug with a teeny magnet. Unlike the VW plug which has a big magnet.
The Boxeer adapter/plug won't fit in the Smallcar drain hole but it does fit in the filler hole.
Running the oil level above the filler hole would provide good oil temp readings. But there are some concerns with this...
FYI ..... I did quite a bit of research WRT gearbox oil levels. I found that a gearbox designer wants the maximum oil level (for maximum lubrication). They choose the level by filling the gearbox until the excess "oil churning" causes an increase in oil temperature, which indicates that the box has "too much oil". Then they reduce the level a little from that. So I think it's probably better to use a normal oil level. But if he has a guage he'll know if it's "hot".
And maybe he would reduce the level to normal and report back to you/us if the trans temperature dropped ??? That would be interesting (to some of us). There's a thread for it here: Manual Transaxle: OVERFILL for lower temperature & longer life? _________________
markswagen Samba Member
Joined: January 28, 2018 Posts: 590 Location: san diego
Posted: Tue Apr 09, 2019 9:12 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
the boxeer sender bung won't fit if you have a kennedy engineering with their headers, there's no space for the sender, the bung would fit, i have a customer who bought the bung, it's stuck to his ebrake as far as i know. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Sodo Samba Member
Posted: Tue Apr 09, 2019 9:24 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
Yah that’s another thing.
Boxeer needs to post pics of it installed on vans.
Pics answer a lot of questions. _________________
Cdub! Samba Member
Posted: Tue Apr 09, 2019 9:59 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
It’s actually stuck to the seatbelt anchor Mark  |
CaliforniaVan Samba Member
Posted: Mon Jan 18, 2021 12:32 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
Hi!
First...i know, this postig is a bit old...but...
i would like to know, where i can find this bushing, which has a magnet in it.
Boxeer hasn´t it in stock. I would like to use it in the transmission drain plug. Normal bushing without magnet are not the problem...
Maybe anyone can help to find? |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 4377 Location: Honolulu,Hawaii and France
Posted: Mon Jan 18, 2021 12:45 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
CaliforniaVan wrote: |
Hi!
Halo!
if you don`t care about the magnet, I sell bushings in the classifieds
The center hole is M14x1.5. The Bosch senders are M12x1.5, if that`s you want to use, you`ll have to install a reducer bushing into the M14 hole or for whatever sender you`re using smaller than M14.
https://www.thesamba.com/vw/classifieds/detail.php?id=1978285 _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Tue Jan 19, 2021 4:23 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
ALIKA T3 wrote: |
Hi!
Halo!
https://www.thesamba.com/vw/classifieds/detail.php?id=1978285 |
Aloha!
Thank you for the offer but i only need a bushing with magnet...
Also i need M16 and not M14 - it´s not a Vanagon transmission - it´s an 012 Audi trans... |
oceanair Samba Member
Joined: June 09, 2013 Posts: 634 Location: Victoria, BC
Posted: Tue Jan 19, 2021 9:24 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
How about a sender for my Auto?? _________________ 84 Vanagon Tin Top, 1970 Ghia - 2014 Jetta Wagon TDI -- all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback - wish I could have them all back! |
Posted: Tue Jan 19, 2021 10:40 am Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
oceanair wrote: |
How about a sender for my Auto?? |
You can purchase a weld in bung for the oil pan next time you have it off. You can also weld in a drain plug that comes in handy. Check Summit or Jegs for the weld in bung. _________________ 1982 Vanagon Camper with ALH TDI.
charleslabri Samba Member
Joined: December 08, 2019 Posts: 335 Location: South Lake Tahoe
Posted: Tue Jan 19, 2021 2:00 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
This came up at an opportune time for me. Ive been wanting to add a temp sensor to my 091/aircooled as its going to be running the boxeer TDI relatively soon.
What have folks considered the best method for getting accurate temps? These plug-style sensors? _________________ -------------------------------------------------
An example of my slave labor in action:
https://www.instagram.com/wileythewesty/ |
Posted: Tue Jan 19, 2021 4:48 pm Post subject: Re: GoWesty's Transaxle Plug with Temp Sensor |
Quote: |
You can purchase a weld in bung for the oil pan next time you have it off. You can also weld in a drain plug that comes in handy. Check Summit or Jegs for the weld in bung. |
Thanks - _________________ 84 Vanagon Tin Top, 1970 Ghia - 2014 Jetta Wagon TDI -- all sweet rides! Love em!
