challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Mon May 11, 2020 3:28 pm Post subject: Re: Very rotten Split panel. |
Savage work! What are you doing with the original gearbox set up? |
BusJunky Samba Member
Joined: February 27, 2009 Posts: 568 Location: Norwalk, ohio
Posty Samba Member
Posted: Fri May 15, 2020 5:59 am Post subject: Re: Very rotten Split panel. |
last few bits of required metal arrived. Looking forward to getting these in. _________________ Tony C
http://www.facebook.com/tonys.vw.toys/
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
Posted: Fri May 15, 2020 7:34 am Post subject: Re: Very rotten Split panel. |
Nice. Silver weld panels? |
Posty Samba Member
Posted: Sat May 16, 2020 3:11 pm Post subject: Re: Very rotten Split panel. |
Yep weld through primer.
Corners started. D post as expected need lots of work.
A lot of bits still missing back here.
Cleaned some of the primer off the side to check the sign writing out. So sorry I didn't preserve more of the original paint.
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
Posted: Sun May 17, 2020 12:39 pm Post subject: Re: Very rotten Split panel. |
Nothing broken inside that gearbox, the bearings in the reduction boxes were shot though and look like they were the originals. Perhaps the reason it was parked was noisey boxes. |
Posty Samba Member
Posted: Sat Jan 16, 2021 1:10 pm Post subject: Re: Very rotten Split panel. |
Pottering away on the old girl and collecting all the missing parts. Maybe this year will be her year.
I had hopped to save the d posts but decided to replace them in the end. as they were toast and thankfully the panels are now available.
Replaced the ends of both chassis legs so id have something nice and solid to weld the d-posts too.
Lots of fun trying to line all the rear up. I now have both the d-posts welded to the top and lining everything up at the bottom before I commit to welding . Happy to have a bit to progress. I have a straight axle conversion complete and in. just to make sure it was all good. Starting making up the wiring loom.
Beam ready to build brakes back up.
I can actually see and end in sight.
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
Posty Samba Member
Posted: Sat Jan 23, 2021 12:37 pm Post subject: Re: Very rotten Split panel. |
Got the corners in. gaps are far from perfect but delighted to have them in. I finally have the external box complete. Now i am missing a lot of internal metal but a good days work.
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Sat Jan 23, 2021 3:40 pm Post subject: Re: Very rotten Split panel. |
Keep up the great work Posty! Nice wood stove to keep your warm and pushing through your hard work even in winter. Looks to be 32 degrees in Ireland today, about the same here in New Jersey, USA _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Sat Jan 23, 2021 3:59 pm Post subject: Re: Very rotten Split panel. |
Awesome determination! You're getting there!
If this pandemic ever lightens up I gotta get back to Ireland and among other things (our family has a vacation home in Midleton, Co, Cork that none of has has been in for years!) it would be fun to see your progress in person! Keep up to great work!
Long live the P and T Panel!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sat Jan 23, 2021 6:13 pm Post subject: Re: Very rotten Split panel. |
good to see you are back at it _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Posty Samba Member
Posted: Mon Jan 25, 2021 12:01 am Post subject: Re: Very rotten Split panel. |
Rear tube closing panels made and installed. Also finished the final little bit of the long side.
Have a rear end.
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
Posty Samba Member
Posted: Thu Jan 28, 2021 12:35 pm Post subject: Re: Very rotten Split panel. |
We have an engine bay .. I have included some of the earlier work on the same area. Its been a journey.
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Jan 28, 2021 12:47 pm Post subject: Re: Very rotten Split panel. |
Posty wrote: |
did you lose the VIN number? it should be right where your hand is. _________________ regards
Uli
Posted: Thu Jan 28, 2021 2:28 pm Post subject: Re: Very rotten Split panel. |
Top job Tony getting close to running out of stuff to weld |
Posty Samba Member
Posted: Thu Jan 28, 2021 3:02 pm Post subject: Re: Very rotten Split panel. |
mandraks wrote: |
Posty wrote: |
did you lose the VIN number? it should be right where your hand is. |
Irish made bus didn't have it stamped or this one did not anyway only the plate in the bay. I have it but its tough to read the plate is crusty. _________________ Tony C
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
Posted: Thu Jan 28, 2021 4:39 pm Post subject: Re: Very rotten Split panel. |
Posty wrote: |
mandraks wrote: |
Posty wrote: |
Irish made bus didn't have it stamped or this one did not anyway only the plate in the bay. I have it but its tough to read the plate is crusty. |
interesting, did not know that _________________ regards
Uli
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24130 Location: Southeast USA
Posted: Thu Jan 28, 2021 7:45 pm Post subject: Re: Very rotten Split panel. |
It's a CKD bus, so it's going to have some weird stuff. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
lil_azza Samba Member
Joined: December 18, 2012 Posts: 249 Location: somerset
Posted: Mon Feb 01, 2021 12:52 pm Post subject: Re: Very rotten Split panel. |
great work keep it up _________________ 70 early bay
71 deluxe beetle
58 rhd beetle
69 karmann cabriolet
61 panel bus |
Posty Samba Member
Posted: Sat Feb 06, 2021 12:03 pm Post subject: Re: Very rotten Split panel. |
Preparing the donor panel for above the engine bay. Adding a bay window engine hatch before going in. lots of bits missing around the edges. The bus it came out of had the spare wheel well. I hope to use the bit I cut out for the hatch to make the ends meet. Also made the overflow pipe. Beer Time.
78 Westy
64 Split panel
64 Karmann Ghia
72 trekker
70 bug |
