Dormobile Roofrack Clamps
blackdog1999 Premium Member
blackdog1999 is offline
PostPosted: Tue Jan 28, 2014 3:34 pm    Post subject: Dormobile Roofrack Clamps Reply with quote
I have been asked by several people to post pics & specs on some Dormobile front roofrack clamps so they can make them. Here they are;
Home of the one true split Bus Motorhome
ezcamper
ezcamper is offline
PostPosted: Tue Jan 28, 2014 5:32 pm    Post subject: Reply with quote
I came a set of dormobile clamps that are the same on top but the bottom where the clamp attaches to the rain gutter is more triangle shaped and does not have a back to crimp onto the gutter.
I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks
PostPosted: Tue Jan 28, 2014 6:16 pm    Post subject: Reply with quote
If there is nothing to clamp it to the back side of the gutter how does it secure? Road vibration could, theoretically, work its way loose.
fig
fig is offline
PostPosted: Tue Jan 28, 2014 9:12 pm    Post subject: Reply with quote
Thanks for that blackdog; you've saved me having to take pics as I've also had the same requests.
The clamps on my 63 Martin Walter Dormobile rack don't have the gutter clamps and I have had one vibrate loose before. Luckily I heard it fall and stopped and found it on the road. Since then I've used cable ties to secure them to the rack legs. My clamps have a hole drilled through the lower part, which is perfect for the safety ties. The part that hooks under the gutter on mine is also triangular.
fig
Kaapse Kombi Kult
"Don't make a fuss, just get on the bus ..."
ezcamper
ezcamper is offline
PostPosted: Sat Oct 25, 2014 10:19 pm    Post subject: Reply with quote
Just made this clamp out of stainless.
emersonbiggins
emersonbiggins is offline
PostPosted: Fri Jan 29, 2021 8:46 am    Post subject: Re: Dormobile Roofrack Clamps Reply with quote
How much is a pair of those repro clamps?
ezcamper
ezcamper is offline
PostPosted: Fri Jan 29, 2021 1:10 pm    Post subject: Re: Dormobile Roofrack Clamps Reply with quote
$75 each. They are no longer stainless though.
MrBusCo
MrBusCo is offline
PostPosted: Sun May 09, 2021 9:49 pm    Post subject: Re: Dormobile Roofrack Clamps Reply with quote
How do you tighten these? just wondering.
Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com
peecee69 Premium Member
peecee69 is offline
PostPosted: Mon May 10, 2021 5:54 am    Post subject: Re: Dormobile Roofrack Clamps Reply with quote
In this picture:
The left side hooks to the roof rack and is stationary with a threaded rod inside it. The right side hooks to the rain gutter and has female threads and a ball & socket mechanism. The right side is rotated right to tighten and left to loosen. I had one of these racks a while back and those clamps work quite well. I wish they would have a provision for a cotter pin to lock them in place, but I checked them every time I fueled up to make sure they were still tight. I think I found them slightly loose a few times.
1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight=
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
MrBusCo
MrBusCo is offline
PostPosted: Mon May 10, 2021 6:58 am    Post subject: Re: Dormobile Roofrack Clamps Reply with quote
And you just turn it in by hand and its tight enough?
peecee69 is offline
PostPosted: Mon May 10, 2021 7:01 am    Post subject: Re: Dormobile Roofrack Clamps Reply with quote
Yep. If a wrench or some other tool is used to get more leverage, either the rack or the rail gutter will bend. Don't ask me how I know...
