pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Fri Jan 29, 2021 5:06 pm Post subject: Rear Heater Wiring - Remove or Use for Something Else |
I removed my rear under seat heater. The wiring is still in place. Is there any value in keeping this in place? Should I cut it out?
Thanks, _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
kourt Samba Member
Joined: August 13, 2013 Posts: 1946 Location: Austin, TX
Posted: Fri Jan 29, 2021 5:16 pm Post subject: Re: Rear Heater Wiring - Remove or Use for Something Else |
It's very useful for running circuits from the engine bay to the dashboard. If you want to add things like oil pressure and oil temp gauges, the heater wiring harness is perfect for that. I would not remove it.
kourt |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Fri Jan 29, 2021 5:22 pm Post subject: Re: Rear Heater Wiring - Remove or Use for Something Else |
As above - plus if it's not in the way why remove it? Just tuck it to the side, one day it might prove very useful. _________________ Jim Crowther
Vespa GTS 300 |
pbrown Samba Member
Posted: Fri Jan 29, 2021 5:37 pm Post subject: Re: Rear Heater Wiring - Remove or Use for Something Else |
I'm installing a 5'x5' plywood subfloor. I'll use a holesaw and drill a hole for it to pass through and just tie it off for future use.
Thanks. _________________ Patrick Brown
r39o Samba Polizei
Posted: Fri Jan 29, 2021 5:48 pm Post subject: Re: Rear Heater Wiring - Remove or Use for Something Else |
My idea was to use the switch to turn on lights in the back. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Sat Jan 30, 2021 12:03 pm Post subject: Re: Rear Heater Wiring - Remove or Use for Something Else |
In my truck I use it for controller my power inverter and combining my batteries.
In my van I use it to read the blinky lights for the Subaru, instead of going under the rear seat and plugging the green connectors together I can do it right form the drivers seat.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
