mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sat Jan 16, 2021 5:56 pm Post subject: Re: What did you do for your Bus today? |
Father_n_son_T1 wrote: |
mandraks wrote: |
i would bet money though, that your 67 is a 21 window bus? |
I’ll take that bet |
well, i am intrigued, let's see some pics then _________________ regards
Uli
Father_n_son_T1 Samba Member
Posted: Sun Jan 17, 2021 9:54 am Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
mandraks wrote: |
well, i am intrigued, let's see some pics then |
While I figure out how and where to upload my pic.s, could you elaborate on your scepticism?
Edit: _________________ Bjorn
1967 T1 Samba 23W |
55bundt Samba Member
Posted: Sun Jan 17, 2021 5:37 pm Post subject: Re: What did you do for your Bus today? |
WOW!!! Well I be damned!! A genuine 1967 23 window...This gentleman knows what he has!! |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Sun Jan 17, 2021 7:30 pm Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
mandraks wrote: |
Edit: |
sure, a brazilian bus would have corner windows. I don't mind that at all, i like the pressed bumpers as well. _________________ regards
Uli
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Mon Jan 18, 2021 9:07 am Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
mandraks wrote: |
VW didn't produce 23 windows in 67. Factory production of 23 window buses ended in 63 and the 21 window bus replaced it for the 64 model year. Your bus appears to be a 23 window or 23 window clone based on a Brazilian made bus. It is a chore that involves a lot of cutting and welding to make a German built 67 bus into a 23 window due to the wider rear hatch etc. References to a 67 23 window are still a relatively new thing to some folks myself included. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Mon Jan 18, 2021 5:40 pm Post subject: Re: What did you do for your Bus today? |
Okie Adam wrote: |
mandraks wrote: |
mandraks wrote: |
VW didn't produce 23 windows in 67. Factory production of 23 window buses ended in 63 and the 21 window bus replaced it for the 64 model year. Your bus appears to be a 23 window or 23 window clone based on a Brazilian made bus. It is a chore that involves a lot of cutting and welding to make a German built 67 bus into a 23 window due to the wider rear hatch etc. References to a 67 23 window are still a relatively new thing to some folks myself included. |
_________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Posted: Mon Jan 18, 2021 6:13 pm Post subject: Re: What did you do for your Bus today? |
Busted-bolt wrote: |
Okie Adam wrote: |
mandraks wrote: |
mandraks wrote: |
i found another on in the brazilian bus section, 73, same color, just before the 23 window conversion and without the pressed bumpers.
Uli
Posted: Tue Jan 19, 2021 4:27 pm Post subject: Re: What did you do for your Bus today? |
Thank you all kindly for your interest! So far we’ve concluded it is indeed Brazilian, AND I can count to 23
A bit surprized over some of the reactions at first. But I get it now you’re trying to tell me, that some conversion may have taken place. Never gave it a thought, (and won’t give it any further, since I’m very happy with my bus as it is). Plus it’s veering off this thread’s course.
What’s with all the tip-toeing, gentlemen? I won’t be offended by facts, I deal with facts. And I’ll learn more about my bus, and that’s a good thing! So, for future comments on any of my topics, you can be straight up honest with me. And I mean it in the friendliest way.
Now back to topic...sorta
I’m down for count after hernia surgery today, so garage build will be postponed for a couple of weeks. In some ways something I had done for my bus today, so I can do some heavy lifting soon without bowels going pop.
I hope I don’t have to post pictures of my yellow tinted, white bandaged abdomen to convince any sceptics of my procedure today , (it’s not a pretty sight ). And as I may not know too much about Brazilian VW history yet, I do know anatomy.
But as soon as I start diggin’ I’ll keep you posted. Build year and country of origin will be documented thoroughly!
For more pic.s and a few vid.s you can go to fatherandson_t1 on instagram _________________ Bjorn
1967 T1 Samba 23W |
Posted: Tue Jan 19, 2021 4:53 pm Post subject: Re: What did you do for your Bus today? |
What's most important is you like the bus and drive it! However, I'll say that pressed bumpers don't look right at all with fried egg turn signals.
How deep are you going on the digging? Did you do the magnet test all around the drip rails, under the doors, on the doglegs, or where the rear hatch and engine carrier meet (where there are likely rust issues)? Check for a few key items:
- Is there an m-code plate behind the passenger seat on the bulkhead?
- If so, does it match the stamped vin in the engine bay or the title?
I would send off for a "Birth certificate" to see what it really started out as, not that it much matters. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Jan 20, 2021 10:40 am Post subject: Re: What did you do for your Bus today? |
What’s with all the tip-toeing, gentlemen? I won’t be offended by facts, I deal with facts. And I’ll learn more about my bus, and that’s a good thing! So, for future comments on any of my topics, you can be straight up honest with me. And I mean it in the friendliest way. |
Brazilian Busses get a bad rap from the shitty people who are flipping junk with a ton of lipstick. There were never sunroof deluxs from Brazil, the roof has been cut to add the sunroof and skylights and usually not correctly.
As you dig into the bus you may find many cans of worms you need to deal with. A local shop did $20K in work to bring a $40K Brazilian Bus to safe driver status. |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Wed Jan 20, 2021 10:48 am Post subject: Re: What did you do for your Bus today? |
ToolBox wrote: |
That and there’s a reason why sunroof Buses had belly pans. Let’s see how well the doors open and close in a few years on those Buses. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
Posted: Thu Jan 21, 2021 10:27 am Post subject: Re: What did you do for your Bus today? |
peecee69 wrote: |
VWAdam wrote: |
That and there’s a reason why sunroof Buses had belly pans. Let’s see how well the doors open and close in a few years on those Buses. |
Great point! Maybe one of the easiest (and first) checks is to look under the bus and see if there are belly pans. If not, you've got quite a bit of work to fix that. |
That and how twisted is the chassis to start with from all the beating it has taken over it's lifetime. |
DadaCheese Samba Member
Joined: April 15, 2008 Posts: 835 Location: Richmond, CA
Posted: Sun Jan 31, 2021 2:54 pm Post subject: Re: What did you do for your Bus today? |
Today
Nothing major;
put in a reproduction grab bar (from Wolfsburg West).
Also fixed that my rear dome light wasn't working (contacts and grounding screws needed to be cleaned).
_________________ ----------------------------------------------------------
Dada as in dadaism.
Cheese as in the stuff I love to eat. |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Mon Feb 01, 2021 4:44 pm Post subject: Re: What did you do for your Bus today? |
Well, I thought I was doing good. I've been working on a 66 Velvet Green bus that per the M-codes was built with a dual circuit brake system. So when ordering all my new brake components, I ordered the beloved 67 Only dual master cylinder.
When it came time to pull the old unit, I noticed it was a single circuit unit. When I installed the dual master cylinder, all of the brake lines were accounted for, kicker is now with everything buttoned up, I can't get the driver front wheel cylinder to bleed. All other 3 wheels are behaving normally.
Is there a T within the front brake hard lines that is missing to make this dual circuit brake master work correctly, and allow the DR side wheel cylinder to received fluid?
Thanks gentlemen, these silly Splits are just different enough from a Bay to get this Bay fella in trouble.
Sam _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Tue Mar 02, 2021 6:30 pm Post subject: Re: What did you do for your Bus today? |
Don't know why I didn't do this years ago!
Typically you have to take off the special lug-nut that keeps the spare on the bracket ('67 Westfalia Walk-through has the spare in the back left), then heave it out of the well so that you can turn it around and find the Valve Stem to check the pressure or add air.
Dada as in dadaism.
Posted: Thu Apr 01, 2021 6:34 pm Post subject: Re: What did you do for your Bus today? |
Installed a 3/4ths length roof rack (or 2/3rds?) made by Front Runner.
Although it would be great to have a classic looking original or reproduction rack, we have a very low ceiling garage.
I worked with the Front Runner folks to "create" this one.
The specifications have it low enough for my purposes, and if I want, I can utilize some of the many accouterments they make (already bought a couple, and I have specific plans to fulfill within April for over-packing camping fun).
I have a thread somewhere in which I was asking about/discussing "modern" racks and load bars. When I have time I'll tack details about this rack there (part numbers, measurements, etc.), in case anyone's interested. Love it so far, but it's been on a total of 3 hours.
Total weight: 76.65 pounds _________________ ----------------------------------------------------------
Dada as in dadaism.
Posted: Fri Apr 02, 2021 8:36 am Post subject: Re: What did you do for your Bus today? |
Mandraks, that's incredible... for simplicity, however, I am going with this:
Front Runner makes a Quick-Release mount that I'll be able to take it off the rack anytime I want without wrenching anything. _________________ ----------------------------------------------------------
Dada as in dadaism.
