mark tucker Samba Member
Posted: Tue Jan 26, 2021 4:01 pm Post subject: Re: What did you build today? |
thats a bit far for me to go just to slap some moron....and nowdays it's extremely acceptable to be a effing moron...and apparently encouraged. |
Abscate Samba Member
Posted: Tue Jan 26, 2021 6:29 pm Post subject: Re: What did you build today? |
I use the Remote Slap App....a hand jumps out of your device and does the deed _________________ .ssS! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Jan 26, 2021 6:51 pm Post subject: Re: What did you build today? |
I didn't "build" but i did run over 300' of Cat 6 wire from one end of my synagogue to the other for both voice and data to the new cantor's office and for the PC that runs our webcast.
Damn, I hate drop ceiling tiles. They always have crap on top of them so you get filthy and the fiberglass just makes my arms itch. _________________ Glenn
Member #1009
#BlueSquare |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Onceler Samba Member
Posted: Tue Jan 26, 2021 10:40 pm Post subject: Re: What did you build today? |
Installed an aluminum radiator in a Lincoln mark V. Had to cut/weld the mounts of course, to make it fit. Typical aftermarket stuff, nothing fits. But I remember when aluminum radiators were big money, now $150 off eBay and only 30 minutes of modifications _________________ 1972 Karmann Ghia |
Posted: Wed Jan 27, 2021 2:50 am Post subject: Re: What did you build today? |
Glenn wrote: |
Damn, I hate drop ceiling tiles. They always have crap on top of them so you get filthy and the fiberglass just makes my arms itch. |
If you dust your arms with cornstarch before it helps stop the itchies. _________________ .ssS! |
anthracitedub Samba Member
Posted: Thu Jan 28, 2021 9:21 pm Post subject: Re: What did you build today? |
I made a battery tray for my Ghia. I also made the inner cross member support that runs underneath it, installed an aftermarket inner bumper fastening panel.
Really gave structural integrity back to that corner of the car. I only made what I needed to, wasn’t interested in making the whole tray. Also shied away from adding the inner detail to the battery area, I didn’t want to ruin my panel by pressing my luck. It’s not 100% perfect, but great driver quality for a resto custom Ghia.
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Fri Jan 29, 2021 7:44 am Post subject: Re: What did you build today? |
Very nice work and a beautiful Ghia!
But please dignify it with a coat of real paint, it looks like the body is straight enough to... _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Fri Jan 29, 2021 8:40 am Post subject: Re: What did you build today? |
It was bare metal stripped inside and out... all nooks and crannies, body off. Then I 2k primed it and shot inside/ underneath with single stage enamel, then undercoated it with bed liner spray. I do want to continue the actual paint job eventually... just not on the priority list. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Mon Feb 01, 2021 1:54 pm Post subject: Re: What did you build today? |
Since I had so much success with wheel widening, I decided to have fun with another pair of VW wheels & make a waste oil heater out of a pair of Passat spare wheels. First up is to plug up all them holes.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Feb 09, 2021 2:27 pm Post subject: Re: What did you build today? |
Before I put the finishing touches on it, I drug it outside & fired it up to see what needed tweaking & where.
I still need to make some legs for it, increase the flue size, install the drip feed, attach the door, make a latch for it, & pass some pipe through it for additional heat exchange. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Tue Feb 09, 2021 3:18 pm Post subject: Re: What did you build today? |
go man go, looking good. love innovation. _________________ "Albatross"! |
Zundfolge1432 Samba Member
Posted: Mon Mar 15, 2021 10:22 am Post subject: Re: What did you build today? |
What did I build today? I’m certainly not the originator of this crude accessory item although I did take the more subtle approach. I had almost all the material on hand so cost was minimal, even the two key pieces came from a junk pile. The main wire is stainless plastic coated. Secondary wire is stainless X2 and a safety chain back up. We used all stainless fasteners double nutted( no pun intended) and Loctite. It could be viewed as an exercise in bad judgement and this falling off at speed could be dangerous. Don’t try this at home, I’ll probably be taking this off soon. I had planned to put these on the wife’s Toyota Prius but upon inspection it would have been difficult because the whole lower side is plastic covered with nowhere to install any weight bearing device. Sad as they would have looked much better I thought.
*edit* one day later I took a look at this and removed it
Open this link and you see the commercial side of this accessory but please don’t get all offended. You were warned. https://www.google.com/search?source=univ&tbm=...&dpr=2
Last edited by Zundfolge1432 on Tue Mar 16, 2021 7:34 pm; edited 1 time in total |
supercub Samba Member
Posted: Mon Mar 15, 2021 3:42 pm Post subject: Re: What did you build today? |
It was windy and I didn't have anything important to do, so I built a kite for the first time in probably 25 years. It's made from sticks, paper, tape, and string. My dad showed me how to build them when I was a kid. It actually flew pretty darn well. After about 45 minutes the paper got too beat up and it wouldn't fly right anymore. It was a lot of fun in a ridiculous sort of way.
Posted: Sat Mar 20, 2021 4:27 pm Post subject: Re: What did you build today? |
I built this out of spare parts. I sourced an original early 60s 26 inch frame and chain guard. Found a used springer front end. Found a used 2 speed kickback rear hub and wheel, correct front wheel,correct bow pedals. Handle bars and grips are from a mid 60s Schwinn exercise bike.
The original wheels are proprietary size 26 by inch and three quarter and only the chinese make a tire to fit now. The seat isn’t right but it’s new. The fenders came from something else. Mix it all together and you’ve got a cruiser
1969 was last year for the Bendix 2 speed and they came in two other gear ratios, yellow band and Blue band. Then the variation of 24 or 36 spoke count. Finally a rare third variation with larger diameter holes to accommodate thicker spokes found on heavy duty or tandem bikes.
As you can imagine parts are getting harder to find. |
Posted: Wed Mar 08, 2023 6:53 am Post subject: Re: What did you build today? |
wooden latch for my bathroom door. I do plan to sink the screws in and plug the holes with wood. This is made of Cherry and Oak wood. |
kingkarmann Samba Member
Posted: Wed Mar 08, 2023 10:03 am Post subject: Re: What did you build today? |
Bride Of Articulation.
An Articulated figure (scarecrow) for the garden.
My bride is an avid gardener and has quite the vision.
She found some plans and asked me to make it for her.
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Mar 14, 2023 6:09 am Post subject: Re: What did you build today? |
Slapped together a 'Cat Tower'
_________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Thu Mar 16, 2023 9:25 am Post subject: Re: What did you build today? |
xoo00oox wrote: |
nice work, I like to use nice ceder, smells good,works easy and I buy it in 6"x6' pertty cheep when the stors have it ,ceder fence pickets, same size as the same ceder they sell for trim work & what ever but about 1/3 price. probabaly be good for the shit house door, bugs dont like it.. I trimed out my last 2 story building with it about 3 years ago. |
Posted: Sat Mar 18, 2023 10:26 am Post subject: Re: What did you build today? |
I got stupid and tried to bend a cable end for my roadster top...I then had to make a billet aluminum end for that cable end that I broke. wtf would they make a formed cable end out of pot metal for? wtf?? and they put the rong shape cable end on it too. it should of been a "S" shaped end not a 90 degree end that bends and lets if pop off,it has plastic clip but those break because it is nolonger 90 degrees witch causes it to pull out and break the plactic clip& eff up other parts. so now it has billet end and firmly attached. but still not a "S" shaped end like it should of had witch is no slip, no clip, easy on&off, easy to make and used on many automotive things/cables/linkages. you cant fix stupid...or a engineer,. |
