DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Wed Feb 10, 2021 6:06 pm Post subject: And so it begins... (2234 build) |
I have an engine that was in my Baja when I bought it. I was told it's a 2180. Had dual kads and was a torquey little engine.
But if you've followed my YT videos, it was a leaky mess. The final straw was the broken lifter bore. So I've been running an 1835 with a progressive (and shitacular Empi intake and exhaust) ever since.
I miss the torque of the bigger engine.
I bought a used Mexican AS41 case for $200 shipped. Never machined, apparently only one 1600 build out of it. The engine had:
W110
84mm Crank (might be cast... I found a casting line)
Stock but clearanced rods
Dual Kads (since sold off...)
Cracked heads (Big valves, built on a stock casting)
I dropped it off at Berg this afternoon for cutting and clearancing (how the hell do you spell that?). I honestly had zero idea Berg was like 4 minutes from my house! Now that Rimco is in Santa Fe Springs (and I'm not super happy with them anyway), my options are narrowing. I stopped at AJ's shop and he recommended Berg.
Anyway, I have the CIP1 IDF 44 clones, heads from Mofoco coming, the cam and lifters are PERFECT (must have been changed recently). I'm happy with the 110 for this. The crank is a big question mark right now. If it's truly cast, I hesitate to use it, but the damn thing ran for who knows how long in the original engine. The P&C were completely worn out! I may build it anyway after having it gone over.
Haven't decided...
Anyway, the torque beastie is on the way! I can't wait, even though it'll be a slow build. I don't do anything fast... _________________ No boom today. Boom tomorrow. There's always a boom tomorrow.
Posted: Thu Feb 11, 2021 2:41 pm Post subject: Re: And so it begins... (2234 build) |
Just got a call from Gene Berg asking me to bring a cylinder in to make sure they get the bore just right.
I love them so much. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Sun Feb 21, 2021 5:13 pm Post subject: Re: And so it begins... (2234 build) |
Cam change... I was just handed a beautiful Web 122/125.
Ugh, I think I'm gonna need dual springs. Anybody running that cam with single HD springs? _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sun Feb 21, 2021 5:15 pm Post subject: Re: And so it begins... (2234 build) |
DurocShark wrote: |
Just got a call from Gene Berg... |
Gene passed years ago.
DurocShark wrote: |
W110
Cracked heads (Big valves, built on a stock casting) |
Sounds like a Bergmann POS. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Feb 21, 2021 5:27 pm Post subject: Re: And so it begins... (2234 build) |
OK, Gene Berg Enterprises. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Glenn Mr. 010
Posted: Sun Feb 21, 2021 5:28 pm Post subject: Re: And so it begins... (2234 build) |
So you're gonna stick with a W110 in a 2234?
Why not get a cam that will produce some power? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Feb 21, 2021 5:32 pm Post subject: Re: And so it begins... (2234 build) |
No idea who Bergmann is but I'm not totally disgusted with that engine. I think the BS I found was from later "repairs" and the cam replacement since that cam and lifters look brand new.
Aside from the craptactular case, there was heavy wear in the cylinders and the center crank bearing was showing copper. The other bearings were fine (another vote for that crank being cast vs forged). Oh, the dual kads on there were pretty tired too.
I think the carbs were choking that engine more than anything else. I suspect I can get a bunch more power out of a better breathing engine of the same specs. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Sun Feb 21, 2021 5:34 pm Post subject: Re: And so it begins... (2234 build) |
Glenn wrote: |
Why not get a cam that will produce some power? |
Hence me asking about the Web 122/125... _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Glenn Mr. 010
Posted: Sun Feb 21, 2021 5:37 pm Post subject: Re: And so it begins... (2234 build) |
DurocShark wrote: |
Glenn wrote: |
Hence me asking about the Web 122/125... |
Good... make sure you get the combo right or it can be a dog. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun Feb 21, 2021 5:38 pm Post subject: Re: And so it begins... (2234 build) |
The W110 was a TON of fun in this car and that was with shitty heads and itty bitty dual Kads. So it's a known quantity.
But better heads and bigger carbs tell me it won't be enough anymore. So when this was handed to me, the fast ramp of this cam makes me think I need to change up the heads some. That's why I ask questions. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15307 Location: Deep in the 405
Posted: Sun Feb 21, 2021 6:47 pm Post subject: Re: And so it begins... (2234 build) |
A Baja with large heavy off road rear tires doesn't need high RPM horsepower. The W-110 might be a great cam where you get the most torque in the 1500-4500 RPM range.
What heads? What size exhaust? What size rear tires? what gear ratios? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Sun Feb 21, 2021 7:31 pm Post subject: Re: And so it begins... (2234 build) |
More importantly... Can that 122/125 run ok with single HD springs?
Heads aren't here yet, so just the one question so far. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3290 Location: Rapid City, SD
Posted: Sun Feb 21, 2021 8:37 pm Post subject: Re: And so it begins... (2234 build) |
DurocShark wrote: |
Heads aren't here yet, so just the one question so far. |
Not a chance. Duals for sure. The 122 has pretty quick ramps.
Brian _________________ www.type-emotorsports.com |
74 Thing Samba Member
Posted: Sun Feb 21, 2021 9:10 pm Post subject: Re: And so it begins... (2234 build) |
Brian_e wrote: |
DurocShark wrote: |
Brian |
Thanks, that's what I was thinking. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Mon Mar 01, 2021 6:39 pm Post subject: Re: And so it begins... (2234 build) |
Took the crank to DPR for a polish/grind. It's cracked. Sigh.
Ordered a new one from them. They're going to work over the flywheel too and balance them. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Sat Apr 10, 2021 3:23 pm Post subject: Re: And so it begins... (2234 build) |
Note to self: Don't try to clearance your cam with an angle grinder.
Hahaha
I figured it was worth a shot. The cam was free...
So now what cam should I be looking at? I'm leaning toward a C35. ACN has them for $80 and already clearanced. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Sat Apr 10, 2021 4:51 pm Post subject: Re: And so it begins... (2234 build) |
Since I'm stalled on the bottom end, I went over the P&C's. I'm impressed with AA. Balanced within .5 grams by swapping the wrist pins between two pistons.
Posted: Sat Apr 17, 2021 1:55 pm Post subject: Re: And so it begins... (2234 build) |
Cleaning up the various parts revealed this. How does the timing gear get so mauled but still run?
(The clean one is the problem...) _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sat Apr 17, 2021 2:02 pm Post subject: Re: And so it begins... (2234 build) |
Most cam gear failures are due to the small gear getting distorted or the big gear coming loose on the cam. Or the mag gear just crumbles apart but not often.
I've seen them put together too tight or too loose or all dented up and still work....good enough. |
