Seal Ring: Heat Exchanger to Muffler
ia02
ia02 is offline
PostPosted: Tue Jul 02, 2013 6:44 pm    Post subject: Seal Ring: Heat Exchanger to Muffler Reply with quote
Does anyone know where I can get the seal ring that seals the threaded connection between the stock heat exchangers and muffler? The seal sits inside the female threads of the heat exchanger and the muffler flange buts up against the seal.
Thanks in advance...
MOCHABILL
MOCHABILL is offline
PostPosted: Tue Jul 02, 2013 8:11 pm    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
Russ Wolfe[RIP] recommended using the copper thermalcouple tubing,used in hot water heaters.
Regards.
'71 Squareback FI
'07 Passat wagon 2.0
'03 Ranger 4door 4.0
ia02
ia02 is offline
PostPosted: Tue Jul 02, 2013 8:21 pm    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
[quote="MOCHABILL"]
Did he prescribe cutting a length forming into a ring and just laying it inside the opening? Or should the ends be joined in some way? Any info is greatly appreciated
Bobnotch
Bobnotch is offline
PostPosted: Tue Jul 02, 2013 8:43 pm    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
[quote="ia02"]
If I remember right, he suggested angle cutting the ends, so that they overlapped in a smooth fashion (formed a complete circle).
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ia02
ia02 is offline
PostPosted: Tue Jul 02, 2013 8:54 pm    Post subject: Reply with quote
does it like the seals are included in this kit?
http://www.vwispwest.com/341298003.html?page=1
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 03, 2013 6:01 am    Post subject: Reply with quote
It certainly looks like it. I'd give them a call to find out before ordering though.
Tram wrote:
Tram wrote:
volksaddict
volksaddict is offline
PostPosted: Sat Feb 06, 2021 6:30 am    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
I'm looking for these now too. Wish I'd saved that bad thermocouple I changed out last fall. I tried some single port intake copper rings but they didn't seem to take up enough space and I'm thinking the thermocouple tubing isn't much bigger. I remember an aluminum ring falling out of one of these years ago, way bigger than the rings mentioned above.
Anyone have a pic or description of the original sealing ring?
ataraxia
ataraxia is offline
PostPosted: Sat Feb 06, 2021 8:42 am    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
https://vwispwest.com/gasket-exhaust-to-exchanger-n138361/?p=YzE9MTMx
https://www.mcmaster.com/97725A590/
https://www.belmetric.com/hollow-crush-gaskets-c-1...-9208.html
EasternNotch
EasternNotch is offline
PostPosted: Sat Feb 06, 2021 4:24 pm    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
I took some measurements of some I have
-Lucas
1964 Notchback
1969 T34 Ghia
1989 Doka AFN TDI
1969 Fastback
1968 T14 Ghia
*Cruised all day long 70 mph before I parked it!
gt1953
gt1953 is offline
PostPosted: Sun Feb 07, 2021 7:05 am    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
You do need that ring installed, when mine went back together I also used some exhaust liquid sealant to make certain it sealed.
72 type 1
73 type 1
72 Squareback
({59 Euro bug, 62, 63, 67, 68, 69 type ones 68 & 69 type two, 68 Ghia all sold})
volksaddict
PostPosted: Sun Feb 07, 2021 8:52 am    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
Thank you Eastern Notch for the best reply to a technical question I have ever received!!
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Feb 07, 2021 1:07 pm    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
I always clean those super-fine threads and use anti-seize on them, to make it more likely (though not certain) they will come part later if needed.
volksaddict
PostPosted: Wed Feb 17, 2021 5:57 am    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
So I ended up using a 40hp cylinder sealing ring from the pile of leftover gasgets, cut at a 45 and fit to the heat riser. The ring is a good beefy size, bigger than the intake sealing rings I tried and the soft copper fits together nicely when cut with wire cutters. Threads clean and wiped with antisieze, big nuts tightened with channellock pliers, nos mufler. Good to go Very Happy
KTPhil is offline
PostPosted: Wed Feb 17, 2021 9:54 am    Post subject: Re: Seal Ring: Heat Exchanger to Muffler Reply with quote
Retighten those big nuts after about 500 miles or so. They can loosen with heat/cool cycles, and the escaping gasses corrode those fine threads. No need to put a death grip on it, just snug it well after it sets in over those miles. Check it again at the next valve adjustment.
