scott74baja Samba Member
Joined: February 20, 2021 Posts: 3 Location: Boulder CO
Posted: Sat Feb 20, 2021 7:30 pm Post subject: 74 baja - rear suspension locked up |
long time reader first time poster.
i've got a 74 baja with an IRS rear end.
the drivers side rear swing plate barely moves, so the ride is rough whenever i hit any potholes. my first thought was that everything was just rusted and seized, so i put it up on jackstand and then put my jack under the drum and it does move, all of maybe a 1/4 inch. then it lifts the whole side off the jack stand.
soaked it all day with pbblaster but since it does move even that tiny amount, i'm guessing it's not a rust issue.
passenger side is fine and moves about 5 inches or so.
any ideas what might be going on? |
Dale M. Samba Member
Posted: Sat Feb 20, 2021 8:07 pm Post subject: Re: 74 baja - rear suspension locked up |
Disconnect shock absorber and test again....
Posted: Sat Feb 20, 2021 8:56 pm Post subject: Re: 74 baja - rear suspension locked up |
Yep. Shoulda added that. Did. No difference |
cbeck Samba Member
Posted: Sun Feb 21, 2021 4:44 am Post subject: Re: 74 baja - rear suspension locked up |
My guess is too much preload on the torsion bars. Search reindexing rear torsion bars. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Sun Feb 21, 2021 7:45 am Post subject: Re: 74 baja - rear suspension locked up |
Disconnect spring plate and test again....
Posted: Sun Feb 21, 2021 3:14 pm Post subject: Re: 74 baja - rear suspension locked up |
Yep dale, that frees up the trailing arm and axle, so sounds like cbek is onto something
Guessing the PO or whoever built this rig wanted max height, ride quality be darned. Also explains the off-road lights that weren’t even wired up |
