Lowering
gitchesum
gitchesum is offline
PostPosted: Wed Feb 17, 2021 3:13 pm    Post subject: Lowering Reply with quote
I've read all the posts about this . So there's that.
I need to drop the front down about 6 inches. I don't think I'll be able to get that with the beam and spindles. Thinking I might be able to squeak out 4 in. with that combo.
How far can I increase the length of that slot in the beam, and what'll I get ?
I just need a good 6 in. Wink
Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go...
ALB
ALB is offline
PostPosted: Sat Feb 20, 2021 2:26 pm    Post subject: Re: Lowering Reply with quote
Have you included 1 1/2-2" for shorter front tires as well? 185/60-15's are only 23 3/4" tall and there's a bunch even shorter. I can't imagine a 25-25 1/2" tire clearing everything with a 356 dropped that much... Al
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
gitchesum
PostPosted: Sat Feb 20, 2021 6:44 pm    Post subject: Re: Lowering Reply with quote
Currently have 185/55's mounted on these wheels. When the car is on the ground I have 27 1/4 " to the ground, from the top of the fenderwell. with an appx 6 inch space between the top of the tire to the bottom of the fender. Like to see that at zero.
57 SC
61 356B
GMC SLT 4x4 Dmax
William Crowell
William Crowell is offline
PostPosted: Tue Feb 23, 2021 5:52 am    Post subject: Re: Lowering Reply with quote
I'm sure it will be JUST FINE!
gitchesum
PostPosted: Tue Feb 23, 2021 10:15 am    Post subject: Re: Lowering Reply with quote
Gorgeous...for a replica.
57 SC
61 356B
GMC SLT 4x4 Dmax
gitchesum
PostPosted: Tue Feb 23, 2021 10:18 am    Post subject: Re: Lowering Reply with quote
Took out the adjusters to grind up the slot. This is the look I'm after, and will require spindles.
57 SC
61 356B
GMC SLT 4x4 Dmax
gitchesum
PostPosted: Fri Apr 02, 2021 8:44 pm    Post subject: Re: Lowering Reply with quote
So i took the beam adjusting block out, and ground the top down 1/4 inch and notched the beam slot 1/2 inch. Dropped the car 3 inches and still has plenty of travel in the front. Now onto the dropped spindles to give me almost 3 inches more. Plus running a 185/60 tire.
57 SC
61 356B
GMC SLT 4x4 Dmax
