Ghia wire harness rubber question 1963
Big Mike Cbad
Big Mike Cbad is offline
PostPosted: Mon Feb 22, 2021 5:24 pm    Post subject: Ghia wire harness rubber question 1963 Reply with quote
Question about this small rubber boot in the passenger lower front fender area behind the splash guard where the wire harness comes out of the tube in the heater channel and runs up the fender behind the splash guard and into the front trunk area. Didn't see this rubber noted in the Ghia diagrams and have not seen it in any parts list for my car. Any idea where to find it and if there is a part number for it that I can't find? It's for a 63 Ghia vert and I'm running a new wire harness for it. Found all the other grommets, but can't seem to find this small rubber boot. Appreciate any help you can provide.
1963 ghia convertible project
sputnick60
sputnick60 is offline
PostPosted: Mon Feb 22, 2021 11:06 pm    Post subject: Re: Ghia wire harness rubber question 1963 Reply with quote
The part number is 141 971 909
You will find it in the 58 low light parts book page 139 item 41
Grommet lower main harness
I looked at the more exotic supplier and none of them had it. It is a hard to find Ghia only part. I’d perfer to be wrong about that
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Big Mike Cbad
PostPosted: Tue Feb 23, 2021 8:51 am    Post subject: Re: Ghia wire harness rubber question 1963 Reply with quote
Thank you so much for the info. It's amazing the level of detail you know about these cars, very impressive. Really appreciate it.
sputnick60
PostPosted: Tue Feb 23, 2021 11:55 am    Post subject: Re: Ghia wire harness rubber question 1963 Reply with quote
You're not the only person looking for them..
https://www.thesamba.com/vw/classifieds/detail.php?id=2427346
You should contact Tylon and exchange notes on the topic
Nicholas
Big Mike Cbad
PostPosted: Tue Feb 23, 2021 3:22 pm    Post subject: Re: Ghia wire harness rubber question 1963 Reply with quote
Will do, thank you. I did search all over the internet with no luck. You were correct it is hard to find.
St_Rand
St_Rand is offline
PostPosted: Thu Sep 15, 2022 9:35 pm    Post subject: Re: Ghia wire harness rubber question 1963 Reply with quote
I am also looking for this part. I have my old one, but it is nearly falling apart.
St_Rand
St_Rand is offline
I am also looking for this part. I have my old one, but it is nearly falling apart. Any updates if anyone has found a source?
obus Premium Member
obus is offline
PostPosted: Fri Sep 16, 2022 7:59 am    Post subject: Re: Ghia wire harness rubber question 1963 Reply with quote
is there anything here similar?
https://www.steelerubber.com/marine/grommets-plugs-bumpers?p=3
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273
runamoc Premium Member
runamoc is offline
PostPosted: Sun Sep 18, 2022 2:34 pm    Post subject: Re: Ghia wire harness rubber question 1963 Reply with quote
Forgot the metal hole diameter but these go up to 1" (25mm) just make your own inside hole.
https://www.ebay.com/itm/223617273753?epid=1503903...BMwIuLqOpg
Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
