Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Tue Feb 23, 2021 12:07 pm Post subject: Re: Gas cap seal? |
I have the 100mm fuel filler and had no seal. So grabbed a disposable plastic lid from some take out container that was in the recycling. The lid was more or less the exact right size/ outer diameter, so i just cut the middle out to make it a 'ring' and stuffed it into the gas cap.
Seals perfectly 1 year later. Cap spins on and off smooth as silk too.
Fairly surprised actually, it was just supposed to be temporary. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Feb 23, 2021 12:15 pm Post subject: Re: Gas cap seal? |
yeah, I've made my own, but then found that BUGHAUS in Tulsa sells the correct seal and bought that - i'm always on the lookout for a crummy-looking 100mm cap in thesamba classifieds, with a nice seal to use on my tanks - as a spare, for next time - have fun - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
JPB1 Samba Member
Posted: Tue Feb 23, 2021 10:25 pm Post subject: Re: Gas cap seal? |
Hi Dave,
Yes using both the cork and blue gasket is impossible - too thick as you indicate.
I carefully dissected a cap the other day, what we have is a thin gasket that allows the blue gasket to rotate. This is positioned under the blue gasket.
The combined thickness of the blue/paper-like gasket is way less than the combined thickness of both cork and blue rubber...so it should work nicely
So halfway there.
I'll report back later
JP |
Dave Samba Elder
Joined: July 11, 2002 Posts: 2693 Location: The Forest Moon of Endor, in the Redwoods
Posted: Wed Feb 24, 2021 9:51 am Post subject: Re: Gas cap seal? |
JPB1, thanks for the reply...so the gas caps do, in fact, come apart? I've been pulling on the corrugated piece under the cap, and on the locking tangs, to no avail... _________________ 2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter" |
bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Thu Feb 25, 2021 2:11 pm Post subject: Re: Gas cap seal? |
I got mine from Valentin at rentabulli ([email protected]). He sent both cork and rubber seals! _________________ 1954 Barndoor
1955 Oval |
Dave Samba Elder
Posted: Thu Feb 25, 2021 4:58 pm Post subject: Re: Gas cap seal? |
Thanks, all, what I am trying to find out is (1) do the Oval-era caps come apart? and (2) what would make the tangs on the cap not engage the stops on the tank? _________________ 2003 Samba Chummie Winner- Best Story
Dave Samba Elder
Posted: Fri Feb 26, 2021 9:22 pm Post subject: Re: Gas cap seal? |
got it apart.... MAN there is a lot of parts in something as simple as a gas cap !!!! _________________ 2003 Samba Chummie Winner- Best Story
Dan22 Samba Member
Joined: August 30, 2019 Posts: 470 Location: Battle Ground, WA
Posted: Fri Feb 26, 2021 9:45 pm Post subject: Re: Gas cap seal? |
Post some pics if the insides of that thing. It would be interesting to see, and perhaps it can help others some day.
How did you end up opening it up?
Cheers! _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Dave Samba Elder
Posted: Sat Feb 27, 2021 1:21 pm Post subject: Re: Gas cap seal? |
I pried all the little corrugations inwards, taking care not to mess up the outer edge of the cap, after that, everything pretty much just came apart. I'll try to get some photos later.. _________________ 2003 Samba Chummie Winner- Best Story
Dave Samba Elder
Posted: Tue Mar 02, 2021 4:04 pm Post subject: Re: Gas cap seal? |
There was a lot more in there than I thought there would be... _________________ 2003 Samba Chummie Winner- Best Story
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Dave Samba Elder
Posted: Thu Mar 04, 2021 11:42 am Post subject: Re: Gas cap seal? |
yes, the tangs are tweaked, that is why I chose this one to dissect this one. There isn't much to the little stop on the neck of the tank, so having the tangs at the right place is important.. _________________ 2003 Samba Chummie Winner- Best Story
