Madscientist2 Samba Member
Joined: February 15, 2020 Posts: 7 Location: Massachusetts
Posted: Wed Feb 24, 2021 5:38 pm Post subject: 8 doweling a stock crank and flywheel-needed? |
I’ve built up the case already on a 1584 cc engine. Put in a performance cam, ratio rockers, porting the heads, dual ICT carbs, and other updates. I didn’t update the crank or flywheel to 8 dowels. From what I’ve learned the engine should produce about 75 HP. I do not plan to rev it higher than 4500 rpm. Questions: do I need 8 dowels? And, since the crank is already installed in the case halves, if I should 8 dowel, can the crank be drilled when in the case. No heads or cylinders installed yet. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 70725 Location: Long Island, New York, USA
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 2582 Location: Georgia
bsairhead Samba Member
Joined: October 08, 2008 Posts: 1664 Location: viroqua wi.
Posted: Wed Feb 24, 2021 6:25 pm Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Torque it properly. |
Posted: Wed Feb 24, 2021 7:10 pm Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Torque of 250 ft-lbs, or more? |
Posted: Wed Feb 24, 2021 7:14 pm Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Should the gland nut be installed with loctite? Standard washer or oversized empi washer? |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 3984 Location: deepest, darkest Switzerland
Posted: Wed Feb 24, 2021 11:59 pm Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Get a better gland nut and wash her. |
madmike Samba Member
Joined: July 11, 2005 Posts: 3750 Location: Atlanta,Michigan
Posted: Thu Feb 25, 2021 4:45 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
If its for a off road buggy then yes on more dowels  _________________ 65 Baja (sold)
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag/Street bug 2276 'Turbo' 11:85 @113 MPH
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's |
oprn Samba Member
Joined: November 13, 2016 Posts: 6430 Location: Canada
Posted: Thu Feb 25, 2021 4:59 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Stock torque value is fine as is the stock 4 dowels. With the cam change you in all likely hood have not increased the engine's torque from stock. The only way you will brake the dowel connection with that engine is to get stupid on the clutch with big sticky tires.
I have put together quite a few stock 1584s in the past with the stock parts and torque values, no Loctite and have never had one fail. _________________ I never finish anything, I have a black belt in partial arts! |
Posted: Thu Feb 25, 2021 7:04 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
I did get the empi chromoly gland nut with a large cupped washer. First time I put it together, the washer lost its cupped shape and got flat. The head of the nut dug into the washer quite notably. So when I put it together the last time I used the empi nut but with the stock washer. On the other question, this is not for an off road application |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 1791 Location: Rapid City, SD
Posted: Thu Feb 25, 2021 9:38 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
I have never built an engine WITHOUT doing the 8 dowels, but I have taken apart quite a few bone stock 4 dowel engines with messed up cranks and flywheels.
Brian _________________ www.type-emotorsports.com |
oprn Samba Member
Posted: Thu Feb 25, 2021 11:36 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
You cannot blame the stock flywheel connection without knowledge of history of the failure. Some guys can break a crowbar in a sandbox! _________________ I never finish anything, I have a black belt in partial arts! |
raymon covey Samba Member
Posted: Thu Feb 25, 2021 11:43 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Are you going to do burn outs in the parking lot LOL !!!!!!!! |
Posted: Thu Feb 25, 2021 1:26 pm Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
oprn wrote: |
You cannot blame the stock flywheel connection without knowledge of history of the failure. Some guys can break a crowbar in a sandbox! |
I am not blaming a shitty mechanic, or abuse, just pointing out an inherently weak connection, known to fail even on stock engines. This guy has done things to his engine that will hopefully increase the power over a stock engine, making the already weak connection even weaker. I agree, and have seen guys who can break anything. Those guys are helpless regardless of what is done to their junk.
Porsche used 8 dowels on their engines that were a similar output to what his engine might be. Maybe they knew what they were doing??
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1180 Location: Marshallville Ohio
Posted: Thu Feb 25, 2021 1:43 pm Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
I have seen too many stock gland nuts strip out and ruin 4 dowels.
Fault of many things...
I always 8-dowel. I have the fixture and can do the crank and flywheel as a unit. I can even do it with the motor assembled.
Always use a Chromoly gland nut too.
Just extra insurance that it will never fail.
Cheap and easy to do.... |
Posted: Thu Feb 25, 2021 1:47 pm Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Ohio Tom wrote: |
EXACTLY!! _________________ www.type-emotorsports.com |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3548 Location: SANDY VALLEY, NEVADA
Posted: Fri Feb 26, 2021 2:08 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Make sure the dowels don't stick up past the flywheel or it wont torque proper.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Kelly J. Nolte 3/20/53 - 11/6/08
http://www.rememberingkelly.com/
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
nsracing Samba Member
Joined: November 16, 2003 Posts: 8475 Location: Northern Virginia
Posted: Fri Feb 26, 2021 4:59 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
The more the marrier to me. They sell 8-dowelling kit. GEt one. If you have a drill press, then you are golden.
8-dowelling helps the crank/flywheel mating a lot. YOu can use a stock glandnut too. Or upgrade to the HD kinds.
Hope this helps. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 5263 Location: Videbaek Denmark
Posted: Fri Feb 26, 2021 5:11 am Post subject: Re: 8 doweling a stock crank and flywheel-needed? |
Madscientist2 wrote: |
As menthioned, 8 dowels is a good thing, but not absolutely nessessary, and not for the power window you are in. That said I would definitely replace that Empi gland nut and washer. Another item from that company that I will never use in its current quality. Scat, CB and even the HD ones AA sells are OK.
The reason to use the larger washer is that you apply clamping force to a much larger surface which reduce the risk of the flywheel bananing ever so slightly at the mating surface. Also, with a quality gland nut you can safely increase torque to 280 ft lbs. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
