I destroyed transmission input seal trying to remove, now what?
oscarsnapkin
oscarsnapkin is offline
PostPosted: Tue Feb 23, 2021 8:29 am    Post subject: I destroyed transmission input seal trying to remove, now what? Reply with quote
Chalk it up to a case of “while I have this apart I might as well change this...” So I have my transmission sitting on a bench because I wanted to clean up and grease the clutch operating shaft while I have the engine out. I figured, while I’m in here, I might as well change the trans. input shaft seal. I tapped the seal puller into the seal, and I had a nice tight grip on it. I had to pull as hard as I could and it didn’t budge. All I did was tear the seal apart. I tried getting at it from a few different angles, but it is too difficult to access. I even put a ding in the transmission surface near the seal, but it is outside of where the seal sits, so it shouldn’t be a problem as long as I smooth it out before ‘hopefully’ pressing in a new one. The puller below is similar to what I used. I tried tearing it out with needle nose vise grips and a small screwdriver, but I don’t think I’m getting anywhere and I’m worried about causing more damage. Any thoughts? Is there a different type of puller that might work better? I was thinking about trying to use a needle bearing puller on a slide hammer, but I think the puller might be too big. I wish I would have left the stupid thing alone.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
Cusser
Cusser is offline
PostPosted: Tue Feb 23, 2021 8:35 am    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Screw in three screws
Use a Vise-Grip pliers, pull on the three screws, working from on screw to the other
raydog
raydog is offline
PostPosted: Tue Feb 23, 2021 9:13 am    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
There's no turning back now. Do what Cusser said, or start picking away or cut at the rubber part of the seal and remove the bits to better see the metal housing. You can also use a sacrificial screwdriver. Heat up the tip and form a hook on the end of it . Get it in behind the seal, hook on to it and pull around the perimeter.
MrGoodtunes
MrGoodtunes is offline
PostPosted: Tue Feb 23, 2021 10:01 am    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
oscarsnapkin wrote:
There's an awful lot of crunge all around the outside circumfrence of the old seal, and it's sort of welding (or at least sort of holding) seal in place. Use a knife to scrape that crap outa there, maybe even push the pointed end of your strong thin knife between seal and inside of cylindrical housing it's in. And don't be afraid to tap the seal a wee bit inward to help break it loose, so it's ready to move back in place and then out.
Cusser
Cusser is offline
PostPosted: Tue Feb 23, 2021 10:20 am    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Hook tool might help; such as Harbor Freight. I find these quite handy.
Meiang
Meiang is offline
PostPosted: Tue Feb 23, 2021 10:21 am    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
You can use a camshaft/crankshaft seal puller attached to a drilled washer (this slides over the output shaft) and then use a bearing puller attached to the washer to extract the seal.
A good tip is to slide some acetate sheeting between the seal and the shaft to protect the shaft from any damage form the pullers.
miller0358
miller0358 is offline
PostPosted: Tue Feb 23, 2021 4:24 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
I always had good luck with using just the screws
infiniteLoop
infiniteLoop is offline
PostPosted: Tue Feb 23, 2021 4:40 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
What about using a soldering iron like a windshield remover tool? Go around the circumference at one spot so you can peel the rest out. Also , a heated end of a screwdriver would work if it was filed down not to damage the bore.
goober
goober is offline
PostPosted: Tue Feb 23, 2021 5:22 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
If all else fails it might be easier to remove the side cover, differential and unscrew the input shaft to get it out of the way.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Tue Feb 23, 2021 6:05 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Reminds me of a song I heard once about going through someone’s butthole to pull a molar.
This is actually a cotter pin or key puller, it’s strong. The object here is to insert this about a half inch and get behind the seal and pull. You might try at 6 o’clock then 12 o’clock. Sometimes after years they get stuck but this tool never fails.
Here’s a better pic
So the name of the game here is get behind the seal rather than pick at the surface and having a hook type tool will aid you in doing this.
Here’s the old seal you can see where the hook got a bite on it.
Use a German Elring seal and lube the seal and shaft when going back in. Even a little lube around the perimeter. Never try to seal a dry hole😀
platatomi
platatomi is offline
PostPosted: Tue Feb 23, 2021 8:50 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
The seal has an outer metal ring behind that rubber surface. What ended up working for me after it was torn up was hooking the spike from the seal puller up under and behind that ring at around the 12 o'clock position on the seal. It popped out the first pull.
'69 Beetle daily driver, fixing things as I go...
Update -
No longer daily driver but still fixing things...
PostPosted: Wed Feb 24, 2021 12:48 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Excellent sign that one off😀
AutoMechanic
AutoMechanic is offline
PostPosted: Wed Feb 24, 2021 2:15 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Either the screw or pick method would be best. I would get some other picks than the Harbor Freight ones though those are like butter they break very easily.
oscarsnapkin
PostPosted: Thu Feb 25, 2021 3:05 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Thanks for all the tips. I’m gonna have to put it on hold for a bit to I figure something out. This sucker is stuck. I tried a cotter pin puller as suggested, and all it wound up doing was bending the tool. Screw technique didn’t work either, screws just pulled out when I really tugged on them. I’ve been cleaning all the rubber out with a small pick to expose more of the metal. I think my best bet is going to be something that attaches to a slide hammer. My pilot bearing puller is just a tiny bit too big and I’m worried it’ll damage the shaft. The car is nowhere near running so I have plenty of time. I’ll update when I have success (or catastrophic failure) in case some other poor soul has the same problem down the road. This is what it did to my cotter pin puller.
This air chisel attachment looks awesome, but I can’t justify $92. Thanks again for the great info.
- 1973 Thing
Dark Earth
Dark Earth is offline
PostPosted: Thu Feb 25, 2021 3:45 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
I think somebody glued that thing in with some really tough stuff. If it were me, I'd drill out the front face of the seal so you're only left with the part that's glued in. At that point, you'll be able to drive something skinny in between whats left of the seal and the trans case. Whats left of the seal will bend easier with the front material removed. Then it will be a matter of peeling it out. The only danger is damaging the trans case, so you have to be careful. Whoever glued this in left a ticking time bomb.
My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ Anxious
infiniteLoop
PostPosted: Thu Feb 25, 2021 4:37 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
If you can force the seal outer ring all the way in and have room ,than you can crush it down with pliers and remove it.
Or maybe you could make your own mini bushing cutter.
AutoMechanic
PostPosted: Fri Feb 26, 2021 7:48 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Wow sorry those methods didn’t work. Hopefully you can get it all the way out. Smile
74 Thing
74 Thing is offline
PostPosted: Fri Feb 26, 2021 10:56 pm    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
Screw with a slide hammer?
Blue69Baja
Blue69Baja is offline
PostPosted: Sat Feb 27, 2021 10:55 am    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
No matter what you do you have to be careful not to scratch the outer contact surface of the seal. If you scratch the aluminum seal contact surface.
The screws have always worked for me and my bud!
69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original..
oscarsnapkin
PostPosted: Wed Mar 17, 2021 7:21 am    Post subject: Re: I destroyed transmission input seal trying to remove, now what? Reply with quote
I owe you a beer my friend. After spending tons of time trying to dissect this seal and trying to split it to get it out, I gave the screwdriver technique a try. I had it out in about 10 minutes. I bought a cheap Hatbor Freight flat head, heated it up and made a hook at the end. With the help of Vise Grips and a hammer it was out. I did bang up the bore a bit when I initially used the seal puller, but it seems to be near the outside edge, not where the seal sits, so I should be OK. I’m assuming I should put some Permatex or something similar on the new seal just to be safe. Any recommendations? Thanks a million.
- 1973 Thing
