Lee Hedges Samba Member
Joined: November 09, 2000 Posts: 810 Location: San Diego
Posted: Wed Feb 24, 2021 4:16 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Good question, Dave! I measured the original tunnel tar board material and it's 1/8" thick. The floorboard mats are 0.5" thick. Scott Taylor recommended the Design Engineering Thick Damping Material #050230 because it's close to the same texture, is easily cut & formed to compound surfaces, and is a bit more than 1/16" thick. He says it out-performs the original material & should be fine. I found it on Amazon for $58 (24x54) but found I'm going to need two to adequately cover the tunnel & chassis VIN plate areas.
Posted: Sun Feb 28, 2021 5:40 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
With the topside of the chassis completed I installed the front seats to get an idea of what the ice blue vinyl & blue cloth would look like inside. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7527 Location: Santa Cruz
Posted: Mon Mar 01, 2021 4:14 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Lee Hedges wrote: |
I'm at this stage in my build as well.
Was thinking it might be prudent to trim the tarboard insulation to match factory.
Digging for pics of this are is a bit tough, and few take pictures of this area.
I do have this one i took of pan insulation parts on my '67:
Wonder is anyone has more of these pictures? _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Mon Mar 01, 2021 4:57 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Fortunately I've been working with other early T34 owners along this process to get references. In this situation I was able to get detailed images from Scott Taylor's uber-restored 1963 T34 Coupe. He documented the insulation for the tunnel, both sides. Those with your great pic will definitely help me cut the insulation pieces to closely match the originals. Sad that only the panels under the rear seat will ever be seen, as the tunnel is covered with carpet. |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Tue Mar 02, 2021 7:59 am Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Either way. This looks great. Love the attention to these details guys. Cant wait to see all of them - well I do get to see Lees since he lives 20 min away. But Clatter and Scott - love the restos brothers. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Tue Mar 02, 2021 11:23 am Post subject: Re: San Diego Nov61 T34 #0 001 200 |
I fixed the wrong DEI part number ad. Sorry for the confusion. I ordered another one today (2nd) for $64 to have enough to complete the tunnel area. |
Posted: Mon Mar 08, 2021 6:07 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Flipped the chassis over to the bottom and (based on Pedro's advice) added two coats of glossy black enamel. Next will be cutting the tarboard panels for the tunnel. |
Posted: Mon Mar 08, 2021 6:20 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Over the weekend Francisco applied the first paint. Sea Blue L360.2 is the lighter & greener version of Sea Blue. Single-stage enamel was purchased at TCP Global in San Diego for about $185/gallon and two gallons were needed to apply four coats. The interior areas will be done first, then the roof in Blue-White (in a day or so), then the exterior (in a week or two). The camera did not accurately capture the Sea Blue color, instead these pics are a bit more green. |
Jason37 Samba Member
Posted: Mon Mar 08, 2021 8:42 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Really starting to come together! |
andybla Samba Member
Posted: Tue Mar 09, 2021 1:09 am Post subject: Re: San Diego Nov61 T34 #0 001 200 |
this is very nice |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
Posted: Tue Mar 09, 2021 11:00 am Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Lee Hedges wrote: |
That Sea Blue#2 is a royal PIA to paint, as it changes color with the light. BTDT. While I love the color, I really hated spraying it.
Yours definitely looks good. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Mar 21, 2021 4:35 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Spent a few days installing the insulation boards from Design Engineering #050230 onto the tunnel & rear seat wells. It cuts easily with a razorblade, scoring & bending the pieces to be cut. I used a roller to pressure the tarboard onto the metal. And it sticks really well but it tore in several places when readjusting the pieces. Overall it went on well & I'm happy with the results. The tunnel will be completely covered by carpet. The areas underneath the rear seat will only be visible when the rear seat is removed. |
Posted: Tue Mar 23, 2021 2:43 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
must be nice to build on such a neat chassis |
Posted: Tue Mar 23, 2021 3:30 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Restoring a T34 from the frame-off is a daunting experience that is not for everyone. If I could have bought this 1962 complete & together I would never had separated it. But it came to me completely disassembled, stripped, & parts in 1000 different places over a decade before I bought it.
Having Pedro, Jack, & Eric as amigos going through similar restorations is a real gift. These guys are the most knowledgeable on early Type 3s & have so much hands-on experience. They are always willing to volunteer their time, advice, & parts to keep the project moving forward. It also means they do not allow half-assed restoration work, which slows down the progress.
Today, for instance was reinstalling the rotary heater system. Should be easy, right? Well the parts are NLA & NOS are ridiculously expensive, so it took two years to find the rubber Anthracite collar/bib & the NOS red dot knob. But once the parts have been found, installing new parts on a clean chassis is the fun part.
Working this build step-by-step has been an unforgettable experience. And this particular T34, the oldest survivor in the world, is worth restoring. So I'm committed to finishing it & giving my best effort. |
veltror Samba Member
Posted: Tue Mar 23, 2021 4:53 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
This is a fantastic thread. Keep up the good work Sir! |
Posted: Wed Mar 24, 2021 10:22 am Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Yeah, Pedro and Jack being close by IS a big help. Pedro having just done 2 type 34's is also a big help, as he knows the cars, and is familiar with them and their little quirks. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Mar 24, 2021 6:39 pm Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Bobnotch wrote: |
Yeah, Pedro and Jack being close by IS a big help. Pedro having just done 2 type 34's is also a big help, as he knows the cars, and is familiar with them and their little quirks. |
He's the Type 34 Guru _________________
t3kg wrote: |
1964 1500 S
gregson1 Samba Member
Posted: Sat Mar 27, 2021 9:16 am Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Inspiring, Lee--really nice job!
This car is definitely worth the effort and I can't wait to see it. |
Posted: Mon Mar 29, 2021 8:53 am Post subject: Re: San Diego Nov61 T34 #0 001 200 |
Next step on the chassis resto was the long gearshift bar & shift assembly. This long metal bar is purposefully bent to get around the other components in the tunnel. Removing the old gearshift coupler allowed the tube to be pulled-out through the front access hole. I cleaned & sanded-down the shaft then applied grease for a smooth fit. The new nylon bushing & clip as well as the new coupler came from Wolfsburg West. Pedro came by for the installation. The bushing with clip was pushed into the L-bracket inside the tunnel by hand. Then the long tube was inserted at the front & aligned with the hole, sliding easily down to the rear. Next was to install the gearshift lever, lubricated for smooth action. The 1962 Sea Blue cars had Satin Blue rubber parts for the gearshift lever & ebrake boot, and the gearshift knob is the solid ivory one. |
