evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Tue Feb 23, 2021 1:42 pm Post subject: T1 transmission core, any parts worth saving? |
I cant help but ask as I don't want to destroy anything useful or of any value.
I was looking for a transmission case to be able to run my engine on a stand before I install it.
Anyways, I found one for free but when I picked it up it turned out to be a complete transmission core.
The number on transmission case is AO496588 (pn 113.301.103) there is also the number 36 above the part number. From what I read online this came out of a 1971 Karman Ghia and has 3.875 ring gear.
it is worth trying to save anything from this, are any of the parts/gears hard to find? assuming they are in decent condition? _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
c77owen Samba Member
Joined: July 07, 2017 Posts: 454 Location: Kansas City, MO
Posted: Tue Feb 23, 2021 2:16 pm Post subject: Re: T1 transmission core, any parts worth saving? |
Reverse gears in good condition are always in short supply as well as gear carriers right now |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15278 Location: Deep in the 405
Posted: Tue Feb 23, 2021 2:38 pm Post subject: Re: T1 transmission core, any parts worth saving? |
Good cores are getting hard to find. I'd bet if there are any transaxle rebuilders near you they would give you a junk case and a few bucks for it. You can set the engine on the floor and hook the complete transaxle up and start it. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Tue Feb 23, 2021 2:44 pm Post subject: Re: T1 transmission core, any parts worth saving? |
Ya, I kinda don't even like the idea of cutting a good original case in half if I can avoid it.
On the other hand I guess most of it could be junk anyway. It looks like it may of been sitting in a shed for a while, it doesn't have any oil in it.
So I'm not quite sure how I would determine if this core is "good" _________________ 1967 Bug ( the daily rod )
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Feb 23, 2021 3:03 pm Post subject: Re: T1 transmission core, any parts worth saving? |
Is it a "Single Side cover" case? those are stronger cases
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Tue Feb 23, 2021 3:14 pm Post subject: Re: T1 transmission core, any parts worth saving? |
earthquake wrote: |
Is it a "Single Side cover" case? those are stronger cases |
It's not _________________ 1967 Bug ( the daily rod )
Cusser Samba Member
Joined: October 02, 2006 Posts: 31268 Location: Hot Arizona
Posted: Tue Feb 23, 2021 4:23 pm Post subject: Re: T1 transmission core, any parts worth saving? |
Cusser wrote: |
The main shaft can be used as a clutch disc alignment tool. |
That's the plan _________________ 1967 Bug ( the daily rod )
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Tue Feb 23, 2021 4:33 pm Post subject: Re: T1 transmission core, any parts worth saving? |
For a daily driver rebuild ,the rebuider is only going to replace parts that are effecting operation. The replaced parts may come from a used box. The box you want to scrap may be better than the one you plan on using.
You could sell the internals on Ebay if you wanted. No one is going to sell the Ring and Pinion for scrap if they rebuild transmissions. |
Posted: Tue Feb 23, 2021 5:16 pm Post subject: Re: T1 transmission core, any parts worth saving? |
This isn't a freshly pulled core. It's pretty rough. The outside of the case didn't look bad but inside is another story. I just pulled the side covers off and the bottom of the case is very corroded. Someone could probably use it but only if they were desperate. The gears in the middle of the case, I guess the differential, is very rusted. So I figure the rest of the internals may be in similar shape.
I'm going to just cut the case in half... _________________ 1967 Bug ( the daily rod )
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Tue Feb 23, 2021 6:43 pm Post subject: Re: T1 transmission core, any parts worth saving? |
evanfrucht wrote: |
I'm going to just cut the case in half... |
If you're gonna cut it. Cut it down the center of the differential housing.
That way in the future. When you decide to make an engine starting stand. You can use the side cover studs to mount the housing to the stand.
The hack that cut mine didn't leave me any meat to mount the bell housing to a stand.
But then, I can't bitch too much. I only paid $20 for the thing. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Tue Feb 23, 2021 6:56 pm Post subject: Re: T1 transmission core, any parts worth saving? |
3.88's are getting harder to find, some builders are bead blasting and seeing the condition afterwards if the rust is light enough. My guess is that isn't going to be the case with yours, but something to consider on future run ins.
Input shaft can be clutch alignment tool
1-2 hub and 3rd gear or even 4th gear (splined sides) can be pinion holding or rotating tools
3rd gear can be used as a press tool for early 113 style gears.
Pinion bearing housing for the big pinion bearing is useful for removing the pinion bearing off of 3.88's
Input shafter coupler can be modified for trans jig turning tool
Probably other ways I have used different parts as well. An old bearing race sanded down on the outside makes it easier to set up a differental sa well. _________________ T1 IRS Rebuild Book on Lulu.com
http://www.lulu.com/shop/tim-marshall/t1-irs-transaxle-book/paperback/product-24055997.html
As seen in Volks America Issue 14 Page 11 (Full page review) |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17273 Location: Left coast, Canada
Posted: Sat Mar 06, 2021 2:55 pm Post subject: Re: T1 transmission core, any parts worth saving? |
evanfrucht wrote: |
The number on transmission case is AO496588 (pn 113.301.103)... From what I read online this came out of a 1971 Karman Ghia and has 3.875 ring gear.
Your trans is NOT from a 71 Ghia, and it doesn't have a 3.88 R&P. Your trans code starts with A0, not AO. _________________
