BFB Samba Member
Posted: Sat Mar 06, 2021 9:34 pm Post subject: shifters |
im sure this has been discussed but what's yalls opinion on shifters? like any better than another?
honestly the only ones ive ever seen / driven are either stock vw, the old cast aluminum short throw, or the " mini" chrome empi ones.
oh, i do have some old , aftermarket shifter that has the 2 finger ring reverse lock out lever in my baja. not sure who made it & its seen better days, but still a more solid unit than others ive driven.
at one time i looked into a sequential shifter but couldn't see spending the money on it. _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Mar 06, 2021 9:56 pm Post subject: Re: shifters |
I have a older EMPI trigger shifter [Hurst copy] in my car and it works fine, I don't know what the new one are like though.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
wheel607 Samba Member
Posted: Sat Mar 06, 2021 10:17 pm Post subject: Re: shifters |
Hurst.....1970.....moved it to new beetles many times ....still shifts like new. |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Sun Mar 07, 2021 2:37 am Post subject: Re: shifters |
I have a Hurst in the FG buggy. And a short shift kit in the bug. For the money/time argument its the way to go, makes a huge difference. I went this way, until I run across deal, that can't be passed up. And that deal has to pretty sweet for me to act on it. I have no complaints. Don't forget the new bushing and rear linkage. _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Mar 07, 2021 5:01 am Post subject: Re: shifters |
Rich, That 'two holer' ya got sounds like an old Empi
I've had purdy good luck with Scat's & old Hurst's _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
mark tucker Samba Member
Posted: Sun Mar 07, 2021 4:41 pm Post subject: Re: shifters |
i HAD THE BUGPOOP WITH THE BUTTON. IT WAS OK TILL THE BUTTON STARTED GIVING ISSUES.. I REPLACED IT WITH THE SCAT DRAG FAST INTO REVERSE GEAR SHIFTER...WITCH i REWORKED SO IT WOULD WORK RIGHT,( THEY NEED A ADJUSTABE GATE FOR REVERSE AND BIGGER MOUNT HOLES WITH BIGGER WASHER TO COVER THAT HOLE SO THE SHIFTER CAN BE FINE TUNED TO THE CAR AND TRANS. AFTER THAT I LOVED THE SCAT SHIFTER, SHORT THROW, NEVER MISS A GEAR, SHINNY, NICE "T" HANDLE, BUT...THAT T HANDLE GETS TOO HOT IN THE SUN AND TOO COLD IN THE WINTER...SO i MADE A "T" HANDLE COVER FOR ALL SEASONS...NO HOT NO COLD. ( THE CAST ALUMINUM SHIFTER'S NEED TOE "ball pivot" REWORKED SO IT IS ROUND...THEN THEY SHIFT MUCH NICER!!!! |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Sun Mar 07, 2021 8:37 pm Post subject: Re: shifters |
Vintage Speed is the bomb. I’m not a “T” handle kinda guy...
_________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Mar 07, 2021 10:58 pm Post subject: Re: shifters |
67 Sunroof wrote: |
When you get the car running and driving. You're gonna love that shift lever.
I have one and it works fantastic.
My trans builder stated, "Trans warranty is only applied to Berg or stock VW shift levers." Until he drove my car with the VS shift lever.
He changed his mind on shift levers after that. He really like the VS shift lever.
The lever is very precise in shift pattern and easy to install and maintain.
Make damn sure that you have the shift rod coupler tight and the grub screw safety wired.
Or you'll be disappointed in the missed shifts. I missed that when setting mine up and had a few scary moments on steep uphill down shifts.
Have fun with it. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sun Mar 07, 2021 11:04 pm Post subject: Re: shifters |
I'm currently a stock shifter kinda guy but the vintage speed one did catch my eye. I was actually going to post that earlier but I figured "what's the point" since I have no real experience with it.
I'm attached to my old worn out shifter and push down style reverse for now tho _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Posted: Sun Mar 07, 2021 11:15 pm Post subject: Re: shifters |
evanfrucht wrote: |
I'm attached to my old worn out shifter and push down style reverse for now tho |
A buddy and I looked at a 66 today.
He asked me to test drive the car and give him an assessment on the car over all.
I told the seller that I haven't had to push down on a lever for quite some time when backing the car out of his garage.
It was a weird feeling to make that move after over three years of pulling up on the reverse ring to select reverse.
It's easy to get used to! _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon Mar 08, 2021 6:38 am Post subject: Re: shifters |
Yeah I did a lot of research on the shifter too.
From an engineering standpoint (which I am NOT😂) I don’t like that the boot doesn’t fit over the base?! Wouldn’t you think dirt would get stuck down in there and eventually get cruddy??? _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Mar 08, 2021 7:05 am Post subject: Re: shifters |
I have had the EMPI Trigger Shifter, Bugpack T-handle, Berg w/Ball handle, and a Scat Dragfast
After all of those over the years, the Scat was the best in my opinion. It is also funny that I am currently running the EMPI shifter because I had it left over and didn't like the Berg unit...and I am not trying to beat up the Berg shifter. It is a really nice unit, but even with the "extra bend" option, I had to reach/bend to shift. It was just a tad too short.
Anyone try the Coolrydes shifter? |
pupjoint Samba Member
Posted: Mon Mar 08, 2021 10:08 am Post subject: Re: shifters |
txoval wrote: |
Berg makes the 14" version . i had the same issue like you |
Posted: Mon Mar 08, 2021 10:14 am Post subject: Re: shifters |
the VS shifter reverse is a direct copy of the reverse style found in many modern cars. i like it a lot.
kingkarmann Samba Member
Posted: Mon Mar 08, 2021 10:30 am Post subject: Re: shifters |
I have an Flat4 Empi Eliminator copy. I'm not much for a T-handle either.
Switched to a ball.
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Mon Mar 08, 2021 10:41 am Post subject: Re: shifters |
67 Sunroof wrote: |
From an engineering standpoint (which I am NOT😂) I don’t like that the boot doesn’t fit over the base?! Wouldn’t you think dirt would get stuck down in there and eventually get cruddy??? |
I don’t like the urethane ball end either. How quickly does that wear out? _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Mon Mar 08, 2021 1:28 pm Post subject: Re: shifters |
The “ball” was the Porsche upgrade. I decided to get it. It was available with and without. Apparently it makes shifts much smoother. Which I couldn’t tell you as I haven’t driven the car in like 4 years???😂😂
It sits in the garage under a WW cover.😡
Yeah I prefer BALLZ.
SHIFTER BALLZ!!! _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
toxicavenger70 Samba Member
Posted: Mon Mar 08, 2021 1:35 pm Post subject: Re: shifters |
I rebuilt my shifter linkage and ran the stock one for a while with a short shift plate. It worked okay, but not great. I have a og Hurst Copper now and I love it. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
