1970 Convertible Top Replacement
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
johnnyniceguy
johnnyniceguy is offline
PostPosted: Mon Jan 11, 2021 8:05 pm    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Thanks to all that contributed to this forum.
I cannot believe the how this will help me.
Volkstuning
Volkstuning is offline
PostPosted: Wed Mar 10, 2021 3:51 pm    Post subject: Reply with quote
Can anyone help with this part? Thanks
sputnick60
sputnick60 is offline
PostPosted: Thu Mar 11, 2021 12:25 am    Post subject: Reply with quote
Which part?
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Mon Oct 04, 2021 4:16 pm    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Since I am getting close to attempting to install my top and headliner, I've read through this whole thread, again..(ok 8th or 9th time).
First, was there ever a resolution on what happened to Vince? The thread mentioned no one had heard from him due to to some illness, but it fell off after that.
As I have done with much advice and examples of how to do things from other Samba Members, following their builds, I have printed off pages of things for my own workbook. So what I have done with this awesome Convertible Top Replacement is to cut and paste all of the pictures, instructions, and responses to questions in clarifying how to follow these step by step instructions. I took out all of the comments, questions, and kudos. I now have my Expert Convertible Top and headliner Install Workbook.
I've got this on a Word doc and can also save to pdf. If the moderators would like to post it somewhere I would be happy to send it, just tell me which address to send.
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
Braukuche
Braukuche is offline
PostPosted: Mon Oct 04, 2021 4:44 pm    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Jeff
Best of luck Jeff. I found the Achilles heel of the whole procedure are the crappy aftermarket wood headers which do not conform to the windshield frame and must be shaped to get the requisite gaps. Don’t settle for almost, there is no way to fix any unevenness in the edge of the wood.
Also, the pad must extend from the rear bow to the header and from the edge of one side to the other to get a smooth rounded top. It’s not clear when you get the pad as it looks square…
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
sputnick60
PostPosted: Mon Oct 04, 2021 5:24 pm    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
This doesn't answer the question, but Vince last visited the Samba on September 02, 2014. You can draw your own conclusion from that given how active and well regarded his contributions have been.
Nicholas
rbsurfguy
PostPosted: Mon Oct 04, 2021 5:37 pm    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Thanks Nicholas re Vince, I figured what the answer would be but didn't want to assume anything, and I did note it had been around 2013-2014 when he last posted. Sad.
Braukuche, I hear you, I worked out most of the issues already with my top frame and header, for now, my header was an original that I had to do some repair work on, noted on my build thread. I've had to make a lot of adjustments and know I will have more with padding and readjusting the weather strip rubber around the frame. Sure I could pay someone to do it, but as you and many others, trying to do as much as I can. I put a top on it around 25 years ago or so and it didn't come out too bad, didn't have near the experience/knowledge I have now, so more confident in my skills...Hey I got my windshield installed in 3-5 minutes, so....
Jeff
2012 Passat-Sold
68 Ghia Vert
68 Ghia Vert is offline
PostPosted: Tue Apr 18, 2023 11:14 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Does anyone know if these measurements work for a 68 ghia with Center crank.
G Falk
G Falk is offline
PostPosted: Sat Jun 14, 2025 5:45 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
I've been dealing with this same header bow issue as everyone is experiencing when replacing. My '58 original bow was completely unsalvageable. This car has been a long, several year process of rebuilding and as such I have made many parts purchases which I duplicated because I forgot I had already purchased! In this case, I had inadvertantly purchased 2 wood headers from M&T. Well, that was an expensive but worthwhile mistake as the first attempt at installation was a fail with too much taken off, split wood etc.
As it turns out, after installing the second poorly shaped bow, the fix to close the gap was to remove the leading edge from the first replacement bow and glue and screw it to the second. Now it's still a little tight on the ends, but I can continue to sand down until the 2mm gap is correct. But the center is almost perfect now. The beauty here was that the curvature was correct when attaching it to the second bow. A costly but necessary lesson to be able to have the top installed.
'58 black ghia 'vert
'58 amazon green ghia 'vert
'61 Samba Sold 3/27/20
'56 beetle amazon green 'vert Sold 7/19/21
'61 pacific blue ghia 'vert Sold 1/6/24 to FL.
'61 Turkis Standard sold 7/22
‘62 pacific blue survivor ghia sold to HI
'66 Velvet Green Doublecab sold
‘59 cognac ghia coupe
'61 Pacific ghia 'vert 42k orig. miles
'61 Mango Singlecab
'54 Barndoor Deluxe
'54 strato silver beetle ragtop
'58 PGSG Standard
Page 10 of 10
