Replacing Speedometer - Disconnect battery first?
VW-Drew
VW-Drew is offline
PostPosted: Thu Mar 11, 2021 10:06 am    Post subject: Replacing Speedometer - Disconnect battery first? Reply with quote
Ode to the person who says there is never a stupid question. When replacing the speedometer in a bay bus, should one disconnect the battery first?
75 Westfalia Project
63 Camper, 73 Bus, 77 Camper (Green), 77 Camper Automatic (Mustard), 83 Vanagon
(Former Samba user from a while back. Can't remember the email I used / username, etc)
[email protected]
Samba Peckerhead
PostPosted: Thu Mar 11, 2021 10:12 am    Post subject: Re: Replacing Speedometer - Disconnect battery first? Reply with quote
i would. lots of live uninsulated terminals under there
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
timvw7476
timvw7476 is offline
PostPosted: Thu Mar 11, 2021 12:57 pm    Post subject: Re: Replacing Speedometer - Disconnect battery first? Reply with quote
yes. disconnect.
once tried it with volts involved & you can energize the drag cup & ruin the return spring. no I will not post the stupid story here. : l
added plus: the vibrator for the fuel gauge in also in peril when you try this.
VW-Drew
VW-Drew is offline
PostPosted: Thu Mar 11, 2021 12:58 pm    Post subject: Re: Replacing Speedometer - Disconnect battery first? Reply with quote
Thank you both
Magion
Magion is offline
PostPosted: Thu Mar 11, 2021 1:00 pm    Post subject: Re: Replacing Speedometer - Disconnect battery first? Reply with quote
battery should be disconnected every time something electrical related is being worked on. What is the harm in doing that? It only takes a second to do it. Yes here is a lot of uninsulated terminals
1975 Campmobile
