the_8th_dwarf Samba Member
Posted: Sat Mar 20, 2021 6:04 pm Post subject: Can anyone recommend a long shifter than is comfortable to use? |
What I mean by comfortable to use is that you don't have to lean forward in your seat to reach the knob in gears 1 and 3 (I currently have a stock shifter in my 4 speed manual 69 bug). I've found that I can either lean back in my seat comfortably, OR reach forward to use the shifter and have control over my vehicle....which is a hard choice for me to make most of the time.
I know I can't be the only one with this problem. This EMPI shifter on jbug caught my eye, since it is angled back, but the "long" version is only an inch and a half longer than the regular one. They are currently out of stock, so if anyone can recommend a good alternative I would appreciate that.
I also couldn't help but notice this VW bus shifter, which looks pretty fly to me, although I'm not sure if it would be compatible. Anyone tried this? _________________
Quote: |
One of the most wrong things I've ever read on the samba since I joined. |
bug-man Samba Member
Posted: Sat Mar 20, 2021 6:11 pm Post subject: Re: Can anyone recommend a long shifter than is comfortable to use? |
checkout appletreeauto.com and put shifter extension in the search box |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Mar 20, 2021 6:41 pm Post subject: Re: Can anyone recommend a long shifter than is comfortable to use? |
Is your current shifter perfectly vertical? If so, you can replace it with an older bent one. You need to have a slot in your shift rod cup if you want the earlier bent-back stock shifter.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
KAmes Samba Member
Joined: February 16, 2014 Posts: 877 Location: Illinois
Posted: Sat Mar 20, 2021 7:55 pm Post subject: Re: Can anyone recommend a long shifter than is comfortable to use? |
Looks great but I would honestly tape a drumstick onto my shifter before I spent $600 on a damn shift stick. I ended up going with the screw-on extender that bug-man recommended - love the simplicity of that! _________________
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 572 Location: South of Raleigh
Posted: Sun Mar 21, 2021 8:24 am Post subject: Re: Can anyone recommend a long shifter than is comfortable to use? |
The easy way is one of those EMPI shifters. Quite a few of them listed on ebay right now. The harder way is an earlier angled shifter, in which case you need to remove the shift rod and slot it. About 50 years ago I did that on my 71 Ghia. You would need to use a grniding wheel, and keep in mind it needs to be a fairly close fit to the pin on the shifter ball, otherwise the shifter will want to rotate |
